![]() As the title suggests, looking at alternatives to the TD04-19T.
Will be going on a B230FT and the target is 300-400bhp. The biggest advantage to the Mitsu is it’s a direct bolt on to my manifold, however I’m happy to have adapters made up if I feel it’s worth it. |
![]() probably depends on your budget. I ran 19t for quite a while and liked it. But with my new motor Im running a Gtx3067r on a header. I wanted to run a Evo turbo but never got around to the manifold for it.
90 Volvo 240-my current setup. B230ft rebuilt -8.8 comp. -Stage 3 rsi cam 3 inch ex.-GTX3076r turbo ballbearing. ebay intercooler-3 inch IC piping- Oil cooler with 10an hose. port stock intake (weak, having a custom intake by viking fab.) Megasquirt 2-1300cc injectors (running E85) 530 head with big valves ported and assemble by culberro sons car- 93 240-15g turbo-chipped-95,000 miles. Slick car Leave feedback- http://forums.turbobricks.com/showthread.php?t=355413 |
![]() Truthfully I don’t want to spend huge amounts of money, somewhere in the £4-600 area.
#4 |
Making Volvo Parts Fit
![]() Join Date: May 2008
![]() I don't see making 300 on a 19T - they are pretty much at their limit on T5's around that. Too small of a hot side, unless you find the later angle flange used on the 2000R . Good rod-bender. Maybe it doesn't build so quick on the 4cyl, 8valve....
#5 |
![]() V8... Mine makes an easy 350+HP.
#6 |
Dann sind wir Helden
![]() Yeahbut duz it go psshht when you let off the go pedal?
"i will destroy all of you!" -Sheldon Plankton Booty Scooty https://youtu.be/i4oAOZ8nbq4 |
#7 | |
Owner: DeathWagon
![]() Join Date: Jul 2005
![]() go with a small t3 variant.. the old school t3/t4 50trim will make 400hp and is fairly cheap..
91 245GL Dumpin Doughnuts Battle Wagon Chumpcar ![]() 93 245GL Street Beater ![]() |
#8 | |
![]() Quote:
I have a T3 that came off of a Sierra Cosworth which I’m using on another project, don’t mind throwing it on as long as it performs, can’t seem to find any compressor maps for it! |
#9 |
![]() Join Date: Jul 2002
![]() I maxed out a 19T on my b230F on a dyno tuning session, 268 wheel, 296 lb/ft of torque @ 24 psi. power went down with higher boost.
If you want to run around 220-240 wheel, its a decent match. Beyond that you should go bigger. EFR all day long.
#10 | |
![]() Quote:
What was it making at the crank? And what was it like to drive? |
#11 | |
![]() Quote:
It was fast enough to be fun but thats highly subjective. Crank numbers are irrelevant unless you have an engine dyno for tuning ![]() Im sure I could get a higher peak # if I went with a bigger cam and bigger valves but it was well matched to what I wanted the car to be. |
#12 | |
![]() Quote:
What are you running now? I’m looking at holset as they seem great value and are in budget! Last edited by The_Geoffrey; 11-18-2020 at 04:27 PM.. |
#13 | |
![]() Quote:
https://stealth316.3sg.org/images/t3-60trim-cfm.gif 2wd Cossies had a .55 trim Using this turbo (4x4) since 8 years. Love it. Would just change to Evo 16G6 if I could find a manifold...
regards Mathias [Austria] |
#14 |
![]() What about Holset hx35?
#15 |
![]() 16T and 20 psi made about 260 hp but it was limited by knock and gasoline. We tried RE85 and it really helped a lot. 296 hp
#16 | |
![]() Quote:
I’ve had a look at these and they look great value for money and seem to get great reviews, my only concern is the twin scroll exhaust housing, not sure how that would fair bolted onto a stock 90+ manifold. Originally my goal was 250bhp at the wheels on standard internal with all other supporting mods. Now I’m chasing 350bhp and I’ve been told 19T isn’t big enough. I’d be more than happy at 250bhp but if I want to go for more then it means another turbo, would rather just get a big enough one to start with! |
#17 |
![]() HY35 I can recommend for the 90+... a little smaller housing than the HX and single scroll...
Mine (10cm) easily did 1 bar at 3000 rpm on a milled 90+, stock engine with D cam and LH... This was something else compared to the 18T I had before. This will work very well on a 90+, 8v and 1.5 bar. Don't get scared by the "big turbo's don't spool" remarks, every time I upgraded turbo's I was pleasantly surprised. Go big or don't try. ![]() HX35 will give a little worse spool on a 90+ because you don't use the twin scroll and the housing is bigger, but it will make more power. |
#18 | |
![]() Quote:
#19 | |
![]() Quote:
Had a little look online for one today and could only seem to find them on eBay from China, not sure how I feel about that tbh. Where did you get yours from and what wheels are you running? It seems there’s an endless combination on the holset turbos! |
#20 |
![]() Keep in mind that the larger the turbo, the more the power band will shift upwards - to the point where the stock trans gearing isn't going to make the car pleasant to drive as a DD. Then you get into changing cams, adjustable timing gear, playing with FD ratios, and other stuff just to make it pleasant to drive again in the lower & mid range. Will end up costing way more than 4-600 quid.
The advantage to sticking with the 19T, or a 16G etc., is that they spool & build torque early. Unless you are going to drag or highway race this thing, that is way more satisfying from a driving perspective than high HP numbers, in my experience... |
#21 | |
![]() Quote:
Volvo 745 - IPD springs, 25mm/19mm swaybars, K-cam, LH2.4, M90 swap, 3.54 \w racingdiff lsd, track/daily ------------------------------------------------------------------------------------- I sell LH2.4 Chips for Europe! |
#22 |
![]() For that budget, you can get a genuine nearly new Holset from eBay or Compressor Racing or the like here in the UK. Something like a HE221, HX30, HX32 (rare), HE250. HE300 or HX35 might be more than you need, but can be found with the smaller ~50mm induced compressor instead of 54/56/60mm ones, and with a smaller turbine housing they spool well. Also, Martin Leaf (Viking Fabrications) has recently started offering up pipe adapters with or without external wastegate (good idea with Holsets as internal gates are small) flange.
https://m.facebook.com/Viking-Fabric...3788523378217/ |
#23 | |
![]() Quote:
The mitsu turbo was better from 2000-3000rpm, after that it's a whole different story. I disagree with the remark that mitsu's are more satisfying to (daily) drive than a decent turbo in 50-54mm range. Maybe the case with an automatic transmission, but certainly not with a manual trans. I guess it's subjective as well. |
#24 | ||
![]() Quote:
On this occasion it’s not a daily and I want it to be fun and a bit of a hooligan if I’m honest so I’m happy to go with something bigger like a HY35 or similar. It will have all the supporting mods that you mentioned to help move the power and around and make it more drivable so there’s no additional cost as far as that’s concerned. Quote:
Just dropped Compressor Racing a message so hopefully they can find me one or something that performs in the same way. Like the look of the Viking Fabrications stuff, love the idea of bringing the turbo forward in the bay, be interesting to see what effect extending the manifold to the turbo has on performance though. |
#25 |
![]() Good luck with it, hopefully I'll see it one day at a Volvo meet after this covid bollocks.
