![]() With my new motor I know my AW71 wont live long. So I want to start planning and buying stuff I need. Car is 90 240 and I want to keep it automatic. Who making adapters for Gm trans? What GM trans are working out the best behind redblock. Like have a trans that be good for 450hp and streetable. Have a good friend that has a trans shop, he keeps saying powerglide. I cant see a glide being very streetable. Anyways Thanks A Million for help.
90 Volvo 240-my current setup. B230ft rebuilt -8.8 comp. -Stage 3 rsi cam 3 inch ex.-GTX3076r turbo ballbearing. ebay intercooler-3 inch IC piping- Oil cooler with 10an hose. port stock intake (weak, having a custom intake by viking fab.) Megasquirt 2-1300cc injectors (running E85) 530 head with big valves ported and assemble by culberro sons car- 93 240-15g turbo-chipped-95,000 miles. Slick car Leave feedback- http://forums.turbobricks.com/showthread.php?t=355413 |
![]() i have looked at this one but i dont know if it actually holds that much hp https://www.levelten.com/Level_10_PT...1800-3000p.htm
#3 | |
![]() Quote:
#4 |
![]() With a gm trans, take your pick. I've had a 700r4 with a shift kit and converter that took constant abuse from a 400whp setup regularly without any issues. I think a few here have run the 200r4 with similar results. If you have a controller, a 4l60e will work as well. If you're trying to go for more power than that, a built turbo 350 will treat you well and are pretty easy to come by, or a stock af turbo 400, 4l80e.
Whatever you do, get a converter that will work right. When I first used the 700r with a redblock, I used a 4.3 v6 converter just because that's what I had, it was a dog until it got some boost. PTC spec'd a converter for me and it completely changed the truck. |
#5 |
unbalanced chemical
![]() Join Date: Jun 2002
![]() my 200r4 has been a rock star in my 11 sec 744. Gear ratios are also damn near the same as the AW71. The biggest issue I have with it is the annoying kickdown cable. Because of that I would prob go with a newer GM trans that I could just wire up to MS to control shifts.
#6 | |
![]() Quote:
#7 |
![]() 8hp70
Never have i ever .... Seen a 242 with two motorcycles in the back ![]() |
#8 |
unbalanced chemical
#9 |
![]() Join Date: May 2007
#10 |
![]() Thanks for the info guys. Man I wish I did this few years back instead of dinkin around with M47s and now AW71's. Oh well Thanks going to get adapter and TC adapter ordered. Then Ill decide on which trans. I just assume run with a trans comp.
