Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Hello Guest, welcome to the initial stages of our new platform! You can find some additional information about where we are in the process of migrating the board and setting up our new software here
Has anyone found the real deal, #3 Phillips direct replacement (McMaster Carr #?)
or have the dimensions of an original, so I can figure it out for everyone?
Well, since your pic from Scandix calls it a 1035423 (old number 945363), and eBay says a 945363 is 3/8 UNC, I brought up the other picture on Scandix and measured the pixels on the screen.
Expanded in my editor, the threads were 300 pixels high.
The screw was 560 pixels long (flat/oval head size is TOTAL length).
A little calculator play says 3/8 UNC x 11/16. Mcmaster shows a few types of 5/8 or 3/4 length, both using a #4 driver.
You can probably figure out exactly what you want from there.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
