Turbo'd 24erty4er
- Oct 22, 2004
- Vancouver,B.C., Canada
I seem to recall that the large bolt ( 32mm? ) that holds the oil filter housing to the block on 7/900 turbos is no longer available from Volvo, anyone know the size and if there is something available after market - did not find a replacement at FCP but there must be an equivalent washer out there somewhere. I am going from the later 940 design and putting in a separate early 960 oil cooler with fabricated oil lines so using the earlier 740T adapter.
Fortunately I also installed solid engine mounts so routing the lines should be easier.
