An EGR richens the fuel mixture by chemically reducing the compression ratio.
Removing the EGR without a retune will leave a motor in a very lean state.
Another thing many dont realize is that an EGR does not do anything at higher power levels.
Ha ha ha. Weird that the ignition box controls the EGR yet you say it will make the motor lean for more fuel if you delete it. You'd think the ECU control it then. So if you got egr it advances the ignition?? I deleted it and drove around with the check engine light on for a few months before I swapped to a NON egr EZK ignition box.
Lets see what is a non egr non turbo lh2.4 ignition box number? 169?
146 is egr I believe, red label is egr.
Having done this myself, I will tell you that you have to change BOTH the EZ116K and the LH unit. Yes, the EZ controls the egr solenoid and the check engine light, but change just the EZ116K and it'll detonate LIKE A SUNUVAB*TCH. The fuel delivery of an egr LH box is insufficient, apparently.
I like the -951 and -169 boxes, but that's me. I didn't know about -169 egr, so I'd have to clarify -169 non-egr.
I picked up 2 mpg combined doing this, so I ain't mad at it.
That?s what comes in a 1993 240 from the factory. A 951 ECU paired with a 169 EZK.
That’s what comes in a 1993 240 from the factory. A 951 ECU paired with a 169 EZK.
Kool, so what NA LH 2.4 ECU fuel box is the non egr one? Pink label 561? When you say you swapped yours out from the EGR one, what number was that and you replaced it with a non egr 951? Have you ever loaded up different NA fuel bins and compared the fuel maps? Ha ha ha.. Didn't think so..
What I do is swap out the EZK chip in the chippable ezk with a no rev limit race NA EZK chip. Wanna race 2 mpg more boy?
Ha ha ha ha ha ahahahahha...
Was that for California as well? I wonder what the application of the -933 was, then, having believed it was the 9xx version of the EGR -556. Zack says turbo, but I wasn't sure that was correct. Not too many of those around here.
^^ That post above was ridiculous. You can't change the compression ratio via an EGR system. It does change the mixture content.
