Deck Height
Well, that's how you learn.
I copied Dave Barton's specs, essentially, because A) he seemed to have everything worked out and B) his numbers were easily accessible and presented in a manner that seemed friendly and advisatory.
Maybe I should have built for more squish. I didn't know then and I'm learning now.
I have heard the rationale (a la B23ET) that it's better to go with more static compression and less boost. At this point, since the pistons are being made, my only options are to shave the head or block to make a smaller combustion chamber if I decide to go with a higher CR. Just as a what-if, I guess shaving the block would be a better move since it would give more squish and more CR? If I then wanted to drop the CR back down, I could have a little removed from the pistons at the machine shop, too, right?
Stealth FI, I appreciate your comments even if it does seem that I'm disappointing you by not having fully understood your copious previous efforts to bring the merits of tight squish to the fore. In other words, there was just too much information there to comprehend all at once. You say I can do whatever I want; it's my engine. What would you do in my place at this point? Since you've gone this far, just let me know what your straightforward recommendation would be knowing the dimensions that are built into my engine at this point. Again, I'd appreciate it. And, as you'll conclude your recommendation, I can take it or leave it, but I'd really like to know what it is.
The engine's not set in stone at this point. As I see it, it'll have lots of displacement (2600+ cc), should make better torque down low due to longer stroke, should be fine to rev to 6000 rpm, and should be fairly bulletproof considering the beefiness of the crank and the sound sonic check I had done. It seems like if I'd understood squish better, I might have opted for zero clearance between top of piston and top of deck. I also might have decided to run a slightly higher compression ratio. In fact, the settings that I have now involve a lower piston-to-deck distance than Ross Pistons recommended. I think that with the 30/1000's overbore, I'll have slightly better flow out of the valves than a stocker, too.
In any event, I'll dyno the car before and after the new engine goes in so we can make some comparisons.
Thanks, everyone, for your input. It gets a bit contentious at times, but I still have the opportunity to build this engine for its optimum power, so I definitely welcome your comments.
