Old 11-17-2020, 03:32 PM   #76
klr142
Turbo, what?
klr142's Avatar
The MM/Inches conversion makes it handy, haha.
Old 11-17-2020, 04:22 PM   #77
Avtovaz
yes, so ive got the head ported, and i did some of the chamber work tonight too, they are looking to be around 47.5-48cc atm, will have to remeasure. Then ill have a look at the exhaust manifold, get the head skimmed and put it back together.
when the head is done ill post some more pics, then decide where to go with the amount off!
thanks again for the help.;
Avtovaz is offline   Reply With Quote
Old 11-17-2020, 04:49 PM   #78
klr142
Turbo, what?
klr142's Avatar
I hope it will do the trick! Definitely confirm piston location and dish volume before deciding on how much to remove from the head.
Are you definitely going to use a stock type headgasket still, or will you be going to another thinner gasket?
Looking forward to some more pictures and the final result!
Old 11-17-2020, 05:39 PM   #79
Janspeed
maybe also have a go at gasket matching every transition going from intake >> head >> exhaust
Every edge standing proud in the airstream is an obstruction and will hurt flow.
I don't know if you are using the stock volvo airbox but in stock form that is also restrictive. Remove the cold weather airflap and drill lots of holes in the bottom of the airbox (that's pre-airfilter!)
Is the engine still using the idle air control valve? What is it doing at wide open throttle? Is the ECU opening that thing up as well? Maybe that can be used to get in some more air?
Old 11-17-2020, 05:50 PM   #80
Avtovaz
yes will measure everything defo, and ill be asking for advice before the skim for the right CC for the cam etc, i have no idea! The cometic head gasket looks ok, ill clean it up and that can go back on. i was just worried with this being its 4th time! Having said that, the price of the new gasket and the price of a "DNF" [did not finish] on a rally, the price of a new gasket wins. but will see what its like close up first.
jan, i can match the head>> exhaust, but modding the inlet is not allowed for the rallying i do, so ill leave that well alone... no mods to the inlet what so ever, not one... id never do such a thing.
... ever.
ive got an elbow comming from the inlet, into an ally pipe up to a cone filter to where the bmw ps pump is mounted on my set up. so there is no volvo parts there after the inlet. The idle valve, i had problems on a rally once with this, i think it was a Chinese copy part, i blanked it off, and the engine idled better and the tuner didnt take the extra time to sort its tune out.
thanks again for all the advice!
Old 11-17-2020, 06:16 PM   #81
klr142
Turbo, what?
klr142's Avatar
We don't run an idle motor either. The engine idles around 1200-1300rpm when warm, but that's fine for a race car and helps increase camshaft life anyway.
On our headgasket, we normally use the Hylomar gasket dressing to help it seal. So far, it hasn't been a problem on any of the cars we've re-used it(one of them three times, two others, twice). That being said, for peace of mind, you could get a replacement. I just would NOT recommend a stock gasket if your pistons are indeed flush with the block's deck. You ideally will have between .030-.040" clearance there, or slightly less, but not much if revving the engine to 7000 and beyond. Our current engine has around .025" clearance on the tightest cylinder on the piston center line, so excluding piston rock(roughly measured, I'm no machinist).
Old 11-19-2020, 05:16 PM   #82
Avtovaz
so hopefully tomorrow after work ill get the exhaust manifold and down pipes off the car. The head isnt finished, but the chambers are worked , and the ports are worked too. i want to polish the chambers some, and then its ready for the skim.
I measured teh chambers at 48cc each one.
I got it fairly accurate first time by doing one chamber, then using masking tape made the outline and copied it the the next one etc.
I havnt measured the cc of the piston, but its the same as a b230E if anyone knows the size of the dish on that one? Anyway, with the compression calculator, if i say 3cc for the dish, piston comes to the top of the bore, and i go for 44cc chambers, its like 12:1. if i change the 3cc to 0 it dosnt make much difference. I put 41cc of fluid in one of the chambers tonight, and measured that, and i need to skim 1mm from the head.
Is there a limit to how much you can skim? i think im still under 2mm, but just want to make sure.
ive booked it in already for the rolling road in january, there is a long waiting list for the guy!
thanks again for the help!
Old 11-19-2020, 05:55 PM   #83
I wouldn't worry until your over 4mm removed off the head.
Most of the dyno shops here are booked out 2-3 months as well. Everyone is really busy right now!
Old 11-19-2020, 06:02 PM   #84
Avtovaz
thanks, its unreal, everyone must be building their cars, waiting for the covid stuff to finish... cant wait to get the car out again!
thanks
Old 11-19-2020, 06:27 PM   #85
klr142
Turbo, what?
klr142's Avatar
Nice work! I may have some b230E pistons in the back of the shop somewhere but my measurements will be rough if I can find them. I guess it's not so easy to measure when they're in a motor that's installed at a slant, hah.
I also get 12.1:1 with 0 deck height, 3cc dish, 44cc chamber, 96mm bore, 80mm stroke and a 97mm gasket that's .027" thick.
It's 12.8:1 with 41cc chambers and the same info as above(or with flat topped pistons and 44cc chambers).
As far as how much to shave off, Erland says he normally takes off 3mm and shoots for 16+ bar of cranking compression. The amount he takes off, I am sure, varies depending on the cam and rest of the build, but that was his response to me when discussing our setup with a 264° at .050" camshaft(ENEM C2 copy?). We have around 3mm removed on our 405 head on the General Leif with no issues, yet, after 3 endurance race weekends this year. You previously said you have 1.8mm off, so another 1mm would still put you at just under 3mm off. If you feel like your compression ratio is too high, you can put a slightly thicker headgasket on. A .030" or .036" will still both be within the good piston-head clearance goal of .030-0.040" and lower the compression to 12.66:1 or 12.4:1, respectively.
Go for it! I look forward to the results.
Old 11-20-2020, 04:21 PM   #86
Avtovaz
i had a look at my engine today, it has the dish in the pistons, i also have another block, and the dish is much deeper. I could nto measure them. I found the pistons come to the top of the bore, dead on, but there is some lash in the piston to bore, so it can come out of the bore in effect! i presume if it missed before, it will do again even if i skim the head?
also the exhaust manifold, its got one m8 size hole, and the rest are like m10? is that right? it can fit quite ok or quite badly with out knowing it.
thanks!
Old 11-21-2020, 03:54 AM   #87
klr142
Turbo, what?
klr142's Avatar
That is all correct. The larger hole is normal I think. Also, shaving your head more won’t bring the head closer to the pistons. The headgasket determines how close they are. Your valves will be closer, but likely not a problem.
Old 11-21-2020, 09:05 AM   #88
shoestring
shoestring's Avatar
These B230A/E pistons have my ears pricked up. KG advertises the dish as 0.6mm deep, and the F piston as 2.2mm deep. That would put the A/E volume somewhere around 2.5cc, all things being equal except the depth. If I fired a set of those in the B230FNA (that's the code we've given to the engine in the race car), we're talking 12:1. I like.
Do you guys know if the bore variations are the same across all versions of the same engine family? That is to say, is a "C" or "D" bore in my B230F the same as a C or D in a B230A/E? I would assume so, but I continually find that "they're all the same" bites me in the ass every time.
Old 11-21-2020, 05:13 PM   #89
Avtovaz
i think somewhere i read they are 3cc, but cant remember. i dont know about bores etc.
so i know as of the cam this is a kinda broad question, but what cc do i really want to make the chambers?
Im going to take a pic of the chambers, brother can scan it in, and give me a cm2. I know the chambers are not straight sided, but itll give me a good idea to work out what to skim off the head.
head is now ported, to what standard i dont know lol, also the exhaust has had some working to it too, i recon itll free up some more bhp defo.
thanks again for all the help.
Old 11-21-2020, 06:40 PM   #90
shoestring
shoestring's Avatar
I'm not really sure what you mean here?
Old 11-21-2020, 06:49 PM   #91
Avtovaz
the cam is 300deg, i dont know its exact figures, but the cam affects the compression. So, i dont know what size to make my chambers, what compression ratio to go for.
Old 11-21-2020, 09:57 PM   #92
shoestring
shoestring's Avatar
What I think is that you should shoot for a dynamic compression ratio of 8.0:1 to start, which is probably going to be more static compression than you'd think. That will require you get valve timing events from the manufacturer. If you've already got the cam, they should help you with that.
I'm not really sure why we focus on static compression ratios. I do it too. Maybe it's because they're easy to measure. In reality, what you want is a proper relationship between the cam and compression ratio.
Old 11-22-2020, 02:51 AM   #93
klr142
Turbo, what?
klr142's Avatar
Definitely because SCR is easy to measure/calculate. You can adjust ignition timing to suit as needed for your camshaft’s duration(within reason).
DCR is hard to calculate because valve timing isn’t advertised.
Regarding the 300 degree cam, we still have no idea what lift that’s measured out at, so it’s basically worthless information. Except for camshafts that are being sold by the same company, we have no idea what that means.
Old 11-22-2020, 07:01 AM   #94
Avtovaz
ok i see, ive emailed kl racing to see if i can get any more info on the cam. I dont want to skim the head and take too much off, im in no rush atm to get it sorted.
Old 11-22-2020, 04:10 PM   #95
Avtovaz
not much use but the reply
Hi
the info is on the webpage:
Dur på körspel 300 grader
Kamlyft 12,9mm
Nockvinkel 108 grader
TDC lyft ca 4,5mm
Ventilspel 0,35mm
Thanks
Best regards
Krister Lood
Old 11-22-2020, 07:27 PM   #96
grumpy dad
Hi
there you go in english
Major on driving 300 degrees
Comb lift 12.9mm
Cam angle 108 degrees
TDC lifts approx. 4.5mm
Valve clearance 0.35mm
grumpy dad is offline   Reply With Quote
Old 11-23-2020, 04:04 AM   #97
SkeTchy-MechAniC
SkeTchy-MechAniC's Avatar
Yep, Also asked them for more info.. I responden that the guy who grinds these cams should have it. It would be nice if they could ask him or bring me in contact.
No response.
Never have i ever .... Seen a 242 with two motorcycles in the back
SkeTchy-MechAniC is offline   Reply With Quote
Old 11-23-2020, 08:36 AM   #98
Janspeed
Not sure from a material and cooling passage perspective.
But there are 2 things you do need to consider:
A. skimming an OHC head brings the cam closer to the crank.
But the belt lenght and teeth patern stays the same and they still have to mesh.
This means that the cam timing will retard if you do nothing about it. (the effect of cam retardation is that the powercurve will shift to higher up in the rev range)
You can compensate for the head skimming by using an adjustable cam pulley.
B. The length of the cam belt stays the same so when you use it on a skimmed head the cam belt tensioner needs to take up more slack to get to the proper tension.
Make sure you still have enough adjustability on that tensioner to get to the necessary tension. Maybe you need a shorter cam belt. It has been a long time ago but i seem to remember that a Ford Pinto OHC belt fits (same inter-teeth distance, same teeth shape, same width) and is a bit shorter
Old 11-23-2020, 02:28 PM   #99
klr142
Turbo, what?
klr142's Avatar
If only the people at KL Racing would tell us WHAT LIFT the 300° of duration is measured at, we might have SOME idea of what the heck that camshaft is good for. It won't tell us valve opening/closing though, so you can't calculate a rough dynamic compression number until Culberro sends a camshaft to Shoestring for measuring.
Regarding shorter timing belts(you will need one if you aren't already using one but I'm sure you are): https://forums.turbobricks.com/showp...8&postcount=11
Old 11-23-2020, 03:28 PM   #100
Avtovaz
you can add to that list VAZ 2105 cam belt, its the same as the pinto one, and i asked for that in the shop to get " oh its the same as a pinto one !!!" LOL!
I think im going to get 0.040" taken from it, and itll be in the right ball park.
