Old 11-10-2020, 05:06 PM   #1
doleary
Default B230f mls head gasket thickness question
Have a 84 242 with a 92 b230f block h beams and forged pistons, going 16v head and hx35, pistons are stick out of block 15 thou, anyone have recommendation for head gasket thickness? . I would say I want to go for conservative boost but most likely end up turning it up way to much. Any advice would be greatly appreciated. Thanks in advance, Dan.
doleary is offline   Reply With Quote
Old 11-10-2020, 09:35 PM   #2
klr142
Turbo, what?
klr142's Avatar
You can use a stock headgasket with the pistons sticking out that much and it'll be perfect. Stock gaskets should be .047" thick which gives you .032" piston-head clearance. That'll be great for spinning up to 8000rpm if you'd like. You would also get the benefit of using the stock gasket as a fuse in case something goes wrong.
If you really want a Cometic, the .045" or .050" would be safe and still get you into a good quench clearance between the head and pistons.
Old 11-10-2020, 10:51 PM   #3
doleary
Thanks for the info man, I had been playing back and forth with the idea of going with a stock one as this is the first time I'll be tuning with megasquirt I will probably blow my engine up lol but we will see !! Thanks, Dan.
Old 11-11-2020, 01:51 AM   #4
klr142
Turbo, what?
klr142's Avatar
You’re very welcome! Basically, the goal is between .030-.040” clearance between the pistons and the head when they’re all the way up. Or, .8-1mm. If you aren’t revving past 6k you can likely get away with tighter, but the main benefit is already there when you’re at less than .040” gap.
Old 11-11-2020, 08:05 PM   #5
doleary
Revving to 8k sounds fun =), and you sound like you really know what your talking about, thanks again !!
Old 11-11-2020, 08:17 PM   #6
klr142
Turbo, what?
klr142's Avatar
Happy to help!
