Old 11-10-2020, 06:08 PM   #1
Jack
junkman
Jack's Avatar
Default 16v head plus WHAT 1mm larger valves ?
starting to do some porting work on 16v head and looks like 1mm larger valves should go in without a problem
what are you guys using for valves? before I go read threads that go nowhere...
I vaguely remember someone talking about e30 m3 engine valves
I love you even more Jack.
Old 11-11-2020, 12:21 AM   #2
Jack
junkman
Jack's Avatar
crickets
maybe this will get you talking
Old 11-11-2020, 05:39 AM   #3
SkeTchy-MechAniC
SkeTchy-MechAniC's Avatar
KLracing sells them in a couple of sizes
Never have i ever .... Seen a 242 with two motorcycles in the back
SkeTchy-MechAniC is offline   Reply With Quote
Old 11-11-2020, 01:37 PM   #4
culberro
culberro's Avatar
If going up a size on the 16v, I'd just do the intakes.
KL Racing has some, their quality is all over the place on the 8v stuff: https://shop.klracing.se/sv/artiklar...rostfritt.html
You can also have Manley, Ferrrea, SI, etc make you custom valves. Ferrea will be about $50/valve, Manley is usually ~$40 for stainless, SI can sometimes be around $20-30 depending on what they have to do. I wouldn't hesitate to run SI valves on an NA engine btw, they held up great in the 16v rally car.
Old 11-18-2020, 03:37 AM   #5
klr142
Turbo, what?
klr142's Avatar
Are your goals over 250hp for the build? Penta cams aren't going to get you there, if so.
With great porting and proper cams, Erland Cox says people are getting around 280hp with 50mm carbs/ITBs on 2.3L bottom ends still using stock valves.
Old 11-18-2020, 03:41 AM   #6
SkeTchy-MechAniC
I've got the 8v KL valves in my build. Hasn't run yet but looked fine when machining. Will probably order there when i'll start building my 16v
Old 11-18-2020, 07:16 AM   #7
Jack
junkman
Jack's Avatar
I’m ordering some stainless valves that will have to get machined down.
Old 11-18-2020, 04:55 PM   #8
klr142
Turbo, what?
klr142's Avatar
Why are you doing this?
Old 11-18-2020, 06:57 PM   #9
Jack
junkman
Jack's Avatar
I don’t have a wife
What do you mean?
Old 11-18-2020, 07:18 PM   #10
klr142
Turbo, what?
klr142's Avatar
First of all, !
Second, why are you putting in larger valves? Do you have goals of 300hp with this build and aftermarket camshafts to match? Even without a wife, the stock sized valves flow plenty for most builds and are not a limitation.
Old 11-18-2020, 09:08 PM   #11
Jack
junkman
Jack's Avatar
First of all, !
bent valves on this head so while Im there .... then one thing leads to another ...
It's mostly just a technical exercise for me to see how well it does.
just getting started on #4, mostly cleaning the crappy casting marks. Might go with 6mm valves
about 1mm taken off the top and sides. The opening is restrictive but then it opens up
Old 11-18-2020, 10:08 PM   #12
122power
dude
122power's Avatar
Just get stock valves. I highly doubt youll exceed the stock potential of this head to need bigger valves. Itll be one tire fire in an amazon anyway.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 11-18-2020, 10:25 PM   #13
Jack
junkman
Jack's Avatar
Inb4 partout
Intake valves are way smaller; not sure why they did that
I don’t get why not go with bigger valves
Old 11-18-2020, 10:54 PM   #14
culberro
culberro's Avatar
just getting started on #1, mostly cleaning the crappy casting marks. Might go with 6mm valves
You started on cyl #4, at least going from your 2nd picture. Lol, and your 1st picture
Inb4 partout
Intakes are larger than the exhausts, but +1mm is a good way to go. 6mm valve stems would be sweeeeeet!
Old 11-18-2020, 10:55 PM   #15
Jack
junkman
Jack's Avatar
Lol
See someone is paying attention.
Old 11-18-2020, 11:17 PM   #16
122power
dude
122power's Avatar
Ok do et, do et
Old 11-18-2020, 11:36 PM   #17
Jack
junkman
Jack's Avatar
Originally Posted by 122power View Post
Ok do et, do et
Don’t tell me how to live my life
Old 11-19-2020, 01:23 AM   #18
aristg
El Greco Capitano
aristg's Avatar
standard sized valves sold by klracing, l-m-r, acm mostly exhaust though
some nice threads with lots of info and links:
http://forums.turbobricks.com/showthread.php?t=244033
http://forum.savarturbo.se/viewtopic.php?t=19725
aristg is offline   Reply With Quote
Old 11-19-2020, 02:14 PM   #19
dalek
Benchracer Tribe
dalek's Avatar
What about exhaust valves if you want to turbo? Stainless will suffice or need to go to inconel/sodium filled?
Feedback!
Old 11-19-2020, 03:05 PM   #20
Jack
junkman
Jack's Avatar
Stainless valves on both sides. I’m not going turbo with this head
