Old 11-20-2020, 02:59 AM   #1
RichGT
RichGT's Avatar
Default Will she blow?
https://imgur.com/gallery/JpgEwpT
Note the odd chirping/ ticking noise?
Motor has cleaned up 531. Head is decked, valves lapped (not by me), lash correct. Running the mis-ground iPd turbo cam from many years ago, was running at 2 deg advanced for years in stock 530 head. Timing seems off, I have modified dizzy to allow for the out of alignment keyway. Matches the original bad distributor, with new hall sensor wiring
89 b230ft, Lh2.2, leads, plugs, TPS reset and idle adjusted, new water pump, heater bypass valve, bypass hard pipe, yoshi turbo drain, phenolic inlets spacers.
Vac is good, vacuum lost in time with that chirp/tick. Any suggestions?
'80 GT, M46
'89 740ti, M90
RichGT is offline   Reply With Quote
Old 11-20-2020, 03:11 PM   #2
The tick sounds like an exhaust leak. Chirp is likely overtightened belts. Also, reset your idle base settings. Also also, sounds like it's firing on 3. Definitely make sure the timing belt isn't off a tooth.
Old 11-20-2020, 04:06 PM   #3
RichGT
RichGT's Avatar
Yeah does sound like it’s on 3, thanks
Old 11-20-2020, 05:11 PM   #4
LC4CARL
Aero challenged
LC4CARL's Avatar
Possibly an intake valve issue? Does the vacuum gauge swing dramatically? Compression OK?
@PDXvolvo on IG
B21FT with a T3/T4, STS coil-overs, T5 trans.
Old 11-20-2020, 05:52 PM   #5
RichGT
RichGT's Avatar
Yep, vac gauge to zero, I’ll be pissed with the machinist if that’s the case! Compression good
Old 11-20-2020, 08:02 PM   #6
90volvo
pull plug wire off one at a time. When you find the one that doesnt change anything. Thats the bad cylinder but, diffently sounds like something foreign in cylinder. I wouldnt run it anymore than you have to and pull head off. Good luck
B230ft rebuilt -MS-Turbo-E85
1985 240 Work in progress.
Old 11-21-2020, 05:03 PM   #7
Unplug an INJECTOR one at a time to perform a cylinder drop test. Much safer.
Old 11-21-2020, 08:26 PM   #8
LC4CARL
Aero challenged
LC4CARL's Avatar
Remember that cool tool in shop class that would allow you to drop a cylinder at the touch of a button?
What is "out of alignment keyway?" Sounds bad...
Old 11-21-2020, 09:58 PM   #9
RichGT
RichGT's Avatar
The keyway where the distributor drive dog fits into the cam. The early turbo cams from IPD where ground 20 deg out of alignment from correct ignition timing. No time for this with work being busy before Xmas. I will report back with findings
Old 11-21-2020, 10:12 PM   #10
James M
Bored member
James M's Avatar
Nah, I enjoy the sweet sweet feeling of 20k volts hopping from my elbow to the strut tower
Old 11-21-2020, 10:37 PM   #11
Btdt. No recommend.
Old 11-21-2020, 10:46 PM   #12
Dropping a fuel injector is also safer for the kitty.
