Old 07-29-2020, 01:24 PM   #101
TurboDutch
Great big thank you for Piet!
TurboDutch is offline   Reply With Quote
Old 07-29-2020, 03:55 PM   #102
vlr7
vlr7's Avatar
Amazing. Things are moving fast here. I've been "logging" with obd gauge, which is better than nothing but real logging feature is something else Cant wait to try it out.
vlr7 is offline   Reply With Quote
Old 08-01-2020, 11:31 AM   #103
Broke4speed
Broke4speed's Avatar
Hey, thanks Pietvolvo! :D
I just saw this, I'm going to add the known stuff to the XDF
This is great!
[edit]First post updated![/edit]
1984 244/ B6304S+T / AW30-40 w/Poi-Shift.
Old 08-01-2020, 03:20 PM   #104
TurboDutch
Did you also add the logable bin, adx and maf size converter?
Old 08-01-2020, 08:48 PM   #105
Broke4speed
Yes, although you could have downloaded it to see, lol.
I added everything, since the loggable bin and ADX are pure gold .
Old 08-02-2020, 11:57 AM   #106
vlr7
vlr7's Avatar
Ok i tried the logging and it works. I mapped this 150kw bin on a 132kw enigine. I think there is some improvement already. But engine died several times, maybe its because i dont have lambda probe attached at the moment. Will try to use wideband and its simulated signal. Bigger issue is i cant get the data with any other obd device now. I know the engine must be running. Also are all the 5 visible input channels active in this bin?
Edit:my log
Old 08-02-2020, 01:40 PM   #107
TurboDutch
Great that it's actually working!
Engine is probably stalling when no NB yes.
From our experience the NB simulation is not working that great. It's better to have proper NB sond.
About the obd it should work pre-start, maybe you need to switch of contact first and then try.
Did you manage to make a log? Do you want to share?
Old 08-02-2020, 01:58 PM   #108
pietvolvo
No, without a lambdasond attached it won’t keep running
The OBD functionality should work with the ECU in prestart mode. (Engine off, ignition switch on)
If the engine has been running, you have to turn the igntion switch completely off first (zero position)
You could try the NB simulation though, sometimes it works depending on the make of the WB controller.
Which of the inputchannels can be used depends on the hardware of the ECU and which sensors are attached to the ECU in the S90
pietvolvo is offline   Reply With Quote
Old 08-02-2020, 04:03 PM   #109
Broke4speed
This is so cool! Thanks Pietvolvo! .
Old 08-06-2020, 03:54 PM   #110
TurboDutch
Edit:my log
Thanks for the log, looks like you had monitors running during the log?
Looking forward to more footage, when you got everything up and running.
