Randomletters
- Apr 12, 2011
- El Paso, TX
A few days ago, I started getting a loud metal on metal banging on my left front wheel over sharp bumps. I jacked up the car to take off the wheel to take a look... and discovered that even with my jack fully extended, the tire is still on the ground. I had to lift up the tire to get it off. And then I looked and discovered the top of my spring was an inch and a half below the shock tower.
Now obviously, this is not supposed to be the case, but nothing else is obviously wrong. What is supposed to keep the lower control arm from extending down too far
Also, when I put the car back down, that wheel stayed stuck up to the fully extended spring position until I pushed down on the car.
