Old 08-11-2020, 04:20 PM   #51
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
Old 08-11-2020, 07:58 PM   #52
SquareD
An Anomaly
SquareD's Avatar
I think your 940 has been rolling around in the yard again.
1994 945ti | 15g @ 15psi, Turbosmart EBC, AEM Failsafe WB, 3"/2.5" exhaust, do88 intercooler, iPd cam, STS cam gear, Ostrich LH tune, sbabbs EZK chip, green giants, K&N, Yoshifab CCV/Can/Cap, iPd SS brake lines, TME, Eibach, BNE, Koni suspension, iPd sways, iPd panhard, TME upper/CT lower braces, forged BBS RG-Rs, Michelin Pilot SS, ecodes, V90 bits.
Old 08-11-2020, 08:02 PM   #53
Wilford Brimley
I always go for the unique my man...the wheels are next
Old 08-11-2020, 08:03 PM   #54
SquareD
An Anomaly
SquareD's Avatar
Looking forward to the Ronal Bears...
Old 08-11-2020, 08:28 PM   #55
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
That would be a power move.
I sell chips for LH 2.4!
Old 08-11-2020, 08:58 PM   #56
Wilford Brimley
Or dick wheels?
Old 08-17-2020, 04:18 PM   #57
Wilford Brimley
I took a little more coil off the back to level it. I need wheels mine are gross.
Old 08-17-2020, 09:44 PM   #58
LC4CARL
Aero challenged
LC4CARL's Avatar
I think that cool kids put their front license plate on the passenger-side sunvisor.
@PDXvolvo on IG
B21FT with a T3/T4, STS coil-overs, T5 trans.
Old 08-17-2020, 09:57 PM   #59
Wilford Brimley
I know I had on the passenger side it kept falling suppose zip ties could fix that
Old 09-04-2020, 07:52 PM   #60
Wilford Brimley
From then to now so far...just did a degrease and pressure wash, happy with the results
Old 09-05-2020, 03:49 PM   #61
Quin
ಠ_ಠ
i think the two things you should do next are wheels, and some sort of extremely stupid aftermarket headlights.
Old 09-05-2020, 05:55 PM   #62
I think you should add coolant.
Old 09-05-2020, 06:29 PM   #63
Wilford Brimley
It just has water just wanted to make sure it wasnt leaking everywhere before I put coolant back in, and quin, I just painted the ****ty wheels black but yeah I want wheels and just was gonn use a headlight restore kit
Old 09-05-2020, 10:41 PM   #64
Wilford Brimley
I do like the wheels in black
Old 09-08-2020, 12:01 AM   #65
LC4CARL
Aero challenged
LC4CARL's Avatar
Old 09-20-2020, 11:20 AM   #66
Wilford Brimley
So I'm pretty bummed about the g80 unlocking over 25..makes driftos not much fun...I read the write up about removing the weight but it could be dangerous? What are thoughts on just cutting some of the weight off? I still want to be safe at 60 because it rains A LOT here....I also would like to enter a corner at faster than 20mph too though
Old 09-21-2020, 05:24 AM   #67
Quin
ಠ_ಠ
it's not dangerous. personally i think you should weld it in place, if that's an option. that's what i did, and never found it unpredictable.
Old 09-22-2020, 03:24 PM   #68
Wilford Brimley
I have a welder I mean it's an option....if welding it is the plan I might just do that
Old 10-21-2020, 11:12 PM   #69
Wilford Brimley
Nothing crazy happening got some 440cc injectors so just need chips and I'll put those and the 3"amm on. Did the 3m headlight restore thing, still need a sealant but it's a big difference
Old 10-22-2020, 08:57 PM   #70
Wilford Brimley
Pretty happy with the lights.
Old 10-22-2020, 09:10 PM   #71
LC4CARL
Aero challenged
LC4CARL's Avatar
Shiny brights!
Old 10-22-2020, 09:37 PM   #72
Wilford Brimley
Chicks dig being able to see in the dark
Old 10-22-2020, 10:04 PM   #73
Wilford Brimley
Old 10-23-2020, 01:12 PM   #74
LC4CARL
Aero challenged
LC4CARL's Avatar
Needz moar blue.
Old 10-23-2020, 08:43 PM   #75
Wilford Brimley
They're 6000k right where I like them, same thing on the sub
