Old 05-02-2019, 11:48 AM   #1
drift256
Default 90+ Manifold porting
-Hey guys, I recently picked up a 15G that I will be swapping in a few weeks. While I've got the manifold out I was to port it a bit along with the exhaust housing on the 15G.
-My question is should I purchase a T3 turbo gasket and port the housing and manifold to match that, then use the T3 gasket when I mount the turbo? I haven't taken the turbo off yet so I don't know what the gasket looks like. I want to make sure I have all the necessary parts before getting started.
-Also, should I go ahead and get a gasket set for the manifold to head, and a new one for the turbo the the downpipe? Thanks for the help.
drift256 is offline   Reply With Quote
Old 05-02-2019, 12:09 PM   #2
Jerd
Jerd's Avatar
Search and you will find many pictures and discussions covering this topic already.
https://forums.tbforums.com/showthread.php?t=233098
Originally Posted by Roy 940 View Post
Her is the pics, as said...
Old 05-02-2019, 04:57 PM   #3
drift256
Yes I have read through that thread. What I need to know is if you then use the t3 flange when you reinstall the turbo on the manifold. Thanks.
Old 05-02-2019, 05:07 PM   #4
Sjeng
Sjeng's Avatar
Just use the OE volvo gasket. No reason to use a T3 gasket.
Also, do not port it as big as shown above. Unless you think killing gas velocity is a good idea.
It will be fine when you match the manifold to the turbine inlet, in my opinion.
Old 05-02-2019, 07:32 PM   #5
Jerd
Jerd's Avatar
Like Sjeng said use the right gasket. Or just use Rtv...
Good opinion. Porting to that extent would probably promote scavenging of the exhaust gasses along with a decrease in velocity.
Old 05-02-2019, 08:03 PM   #6
Does your 15g have the volvo shelf on the turbine inlet? Then I would use the T3 gasket as a guide to make the hole as large as the gasket opening. Then mount the turbo without a gasket fitted to the shelf on the manifold which is made to mount up to Volvo turbos without a gasket.
Old 05-02-2019, 08:55 PM   #7
drift256
I’ll take a look at it. I believe it’s a 15g from an 850 but from what I remember it was a flat mounting surface.
Old 05-03-2019, 12:54 PM   #8
F*ck 12
I sprayed my turbo/manifold interface with engine paint per my machinist's recommendation. It doesn't seem to leak even with the boost turned up to 25psi
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 05-03-2019, 01:03 PM   #9
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
if the 15g is a volvo unit, you don't need to port anything-it's already oval. I'd like to see some ebr numbers before and after on these sort of massive port jobs right there at the collector... I suspect it's a rather large waste of time.
Megasquirt Tuning!
Old 05-03-2019, 09:20 PM   #10
boostin'xr4
OV FIRE
boostin'xr4's Avatar
I dont see how porting the manifold like that would kill exhaust velocity with how high the EBR with that tiny 15g would be. I would suspect the manifold out flows turbine housings nearly double that size.
'74 145 - B20, M40, Weber 38DGES
'82 244t - B21ft, MS, E85, H cam, 50trim, T5 swap, etc.
'94 945t - MS, E85, 1500cc's, top mount, 6262, Cd009, etc.
boostin'xr4 is offline   Reply With Quote
Old 05-12-2019, 12:34 AM   #11
klr142
Turbo, what?
klr142's Avatar
Erland Cox says you don’t want to do this. There’s no reason to take a small hole, make it twice as large, only to neck back down into a small hole again. That makes an expansion chamber to slow the gasses down but then try and speed them back up again by restricting them down into a tiny snail. A better thing to do is to keep the small 90+ opening and make the turbo’s inlet the same size by filling it in. But, that’s obviously more complicated than just removing material.
Old 05-12-2019, 06:49 AM   #12
740atl
educator monkey
740atl's Avatar
Thank you!!!
Old 05-12-2019, 03:53 PM   #13
klr142
Turbo, what?
klr142's Avatar
Haha, sure! He posted it on here somewhere, but it’s hard to search for...
