Old 06-26-2012, 08:29 PM   #1
nel621
Default HG kit school me on the parts
Ordered the Erling HG kit and got it today.I recognize most of the gaskets but not the o-rings.Do you guys use all of the items in the kit for a staright head gasket swap?
line 1 4 medium o-rings ???
line 2 4 thin o-rings ???
line 3 4 thick[tube] o-rings ???
line 4 8 o-rings one side has a flat edge ???
line 5 1 small -o-ring ???
2 brasss washers-I guess crush washers for the oil filter
Next to the crush washers 2 clear tubes,opened at each end
then 4 thicker/wider o-rings-I 'm guessing injector seals
can you fill in the blanks?
Photobucket
Old 06-26-2012, 08:49 PM   #2
propav8r
Junkyard Smuggler
propav8r's Avatar
Top: 4 fiber washers. Not sure what those are for.
4 Thin O-rings: Outer K-Jet injector holder o-rings
4 Fat O-rings: Inner K-Jet injector o-rings.
8 things on next line: Valve Hushers/Absorbers
Small o-ring: Dipstick? Dipstick tube into block?
Crush washers: One for the temp sender? Maybe? Not sure about the other.
Not sure on the clear tubes.
4 thicker "o-rings" to the right of the clear tubes: Look like valve stem seals. Do they have a small spring/metal clip around them?
Originally Posted by andysbeta View Post
Go ahead, b******* yourself to death, you fascist swine hitler.
Originally Posted by smokeyfan1000 View Post
Large Size Tattoed Women are the best.
K-Jet to Megasquirt Article
Old 06-26-2012, 09:10 PM   #3
nel621
yes
Old 06-26-2012, 09:14 PM   #4
propav8r
Junkyard Smuggler
propav8r's Avatar
Then those are your valve stem seals. You only got 4 because they go only on the valve stems of the intake valves.
Old 06-27-2012, 08:36 AM   #5
johfraser
Clear tubes are for installing valve stem seals. They protect the seal from the keeper notch and the sharp corners of the valve stem top as you slide the seal on. You only need one but they give you an extra in case one gets damaged.
Old 06-27-2012, 07:18 PM   #6
nel621
Thanks.Do you guys use all these parts when you change the HG? The valve train is quite.
Old 06-27-2012, 07:20 PM   #7
jeblieWun
jeblieWun's Avatar
Indeed.
jeblieWun is offline   Reply With Quote
Old 06-28-2012, 01:44 AM   #8
MasterBlaster
Here's some spare parts I had left over.....
1990 740GL
Old 06-28-2012, 07:38 AM   #9
nel621
Then what is the point in buying a kit.Maybe just buy the ones you need?
