Old 07-26-2018, 08:31 AM   #1
PAULDRIVER
Default 1966 amazon estate resto/severe mod
I love standard cars, but i love more modified specials,
I dont want to offend any volvo purists as my project is quite extreme,
Ive recently aquired a 1966 amazon estate from evil bay,
My intention was to find one in a poor state for not a lot of $, as i want to use all running gear from a newer car,
I found one
It is totally knacked all over, some fiend s used silver roof flashing to repair rot, as well as silicone, putty, blue tac, fibre glass, riveted plates etc.....
seams are all swelled and non existant, it is basically on life support now !
Im disecting the full volvo floor as it is BEYOND REPAIR, and using a 323i bmw floor,
I can use M3 six speed evo trans, and evo rear end,
Also ive a 960 24 valve motor lyin around that will fit nicely
Will put some pics up if anyones interested ?
WHALE OIL BEEF HOOKED
(use Irish accent)
PAULDRIVER is offline   Reply With Quote
Old 07-26-2018, 09:24 AM   #2
Tfrasca
Tfrasca's Avatar
Of course you should post pictures!
Old 07-26-2018, 12:27 PM   #3
PAULDRIVER
A few pics of the amazon, just arrived back to base here
Old 07-26-2018, 12:32 PM   #4
PAULDRIVER
a few more .......
Donor car 1998 323i BMW SIX CYLINDER
Old 07-26-2018, 12:39 PM   #5
Tfrasca
Tfrasca's Avatar
Amazon looks crusty. Perfect to cut in half.
Old 07-26-2018, 12:47 PM   #6
PAULDRIVER
323i BMW, Now a lot less !
More of volvo..
A posts were rotten, a panel you can see into car as it wasnt present
A post we part repaired to put some strength back in, most of floor and bulkhead dissolving, as are floor to sill panels, but we wont be needing those as you will see
BMW trimmed a bit more off its sides, ready for amazon to be lowered into place
Old 07-26-2018, 01:23 PM   #7
PAULDRIVER
Some more....
Time to get serious with the grinder
Nicely does it...
1x front end cut off
1x front end for sale, please enquire... seriously all funds re couped go back into the build
Not a lot of pics but its floor s been totally removed as you can see..
We put the ramp under the roof for lowering it, as there is no strength left anywhere at all now, we braced it first as we didnt want it to fold in two as it went up
We split the bmw factory floor seams, and put its rear end into position for a look and a measure.
volvo lowered onto bmw rear floor, (nice)
Side view
Arch and sill were filler/bondo so no probs as we will be replaced new, plus bwm rear arm mount is a small issue later on,
After lots of measuring, and re measuring, and one more final measure, we tacked it in its resting place
All braced up, you are going no where !
Old sill we removed, offered up to see whats happening, we will use all new panels so 100 per cent
So solid we raised it on the ramp, no issues, and we were all over t moon
Inner sills need to be ready for lowering body down, front of floor will be trimmed and put under soon,
Not far off really
Old 07-26-2018, 01:31 PM   #8
PAULDRIVER
More...
New sill, quick peek
Look at difference, new arch, and fillered/ bondo d, actually a replacement arch
thats all for now, it will be rolling on 4x wheels in the next day or so,
Will post pics of our progress
Old 07-26-2018, 01:35 PM   #9
PAULDRIVER
Yes we swept most of it up, rust clouds were not at all amusing in our unit
Old 07-26-2018, 01:37 PM   #10
What happened to the C63??
Old 07-26-2018, 01:45 PM   #11
PAULDRIVER
Car was badly repaired so i sold it, was well p!ssed, been on lookout for a volvo since,
No 242 s could be found, so i decided on an amazon
I want some decent power out of a six cylinder 24 valve volvo motor im about to turbo
Old 07-26-2018, 06:29 PM   #12
nel621
That is one huge project. Should be nice when done. Did you see the project car where a guy put a 142 body on top of a V70 chasis and drive train?. I can't find the thread, but you may consider doing the same. Volvo on the outside and BMW on the inside.
Old 07-26-2018, 06:37 PM   #13
Tfrasca
Tfrasca's Avatar
Isn't that what he's doing here?
Old 07-26-2018, 06:42 PM   #14
PAULDRIVER
I didnt see it no ?
it will be a six cylinder 24 valve volvo motor , m3 evo six speed manual trans, as well as m3 evo diff,
on an e fourty six final drive
Old 07-26-2018, 07:25 PM   #15
nel621
Check this out.
http://forums.turbobricks.com/showthread.php?t=343188
Old 07-27-2018, 05:04 AM   #16
PAULDRIVER
Nice, i love 142 s.
Old 07-28-2018, 05:23 AM   #17
Jack
junkman
Jack's Avatar
Look great. Sell me the radio cover
I love you even more Jack.
Old 07-29-2018, 05:53 AM   #18
PAULDRIVER
A few more pics, inner sills are taking shape, and we trimmed the front section of floor, ready to move into position,
Next job is to fold some metal 4" x 70" strips 90 degrees, these will be welded to its inner sills for sitting the floor into its final place,, we will try our best to make it look neat, you will see tommorrow what i mean,
Also need to order some door skins as mine are full of filler / bondo and sit proud of its sills and look turd
Old 07-30-2018, 12:54 PM   #19
PAULDRIVER
A few more pics, we put the front half of floor into position in order to line it all up square
Some pics of the strips i folded, these will be welded to the inner sills, the floor will sit on top of them.
Brake servo and clutch servo are in the way so must be removed.
Bonnet / hood hinges needed to be made smaller, as it just would not fit.
Like a glove i believe, cant beat my trusty tape measure, no laser guided instruments here
Nice
Now we need to start making up a front end, wings / fenders ive got are not pretty and we will struggle a bit, lots of messing about now, and head thrash
Nice fit
Will put some more pics up asap as we steam on.
Old 07-30-2018, 04:41 PM   #20
nel621
Since you are going to be using the BMW suspension why not just put the BMW motor and tranny in. A lot less work than trying to mate the Volvo engine to another transmission.
Old 07-30-2018, 05:34 PM   #21
PAULDRIVER
M3 motors are silly $, Im using a volvo motor as ive one laying around, i chose to use the bmw as the trans and rear diff can take some power, and will bolt straight into any bmw of same year,
Plus im aiming for 800 ponies from my turboed six pot volvo motor, so will wipe most bmw s
Old 07-31-2018, 01:27 PM   #22
Between rebuilding, re-rodding, re-pistoning, and sleeving the Whiteblock won't you have spent more money than on a low mile S54 while having much worse cylinder head flow, fewer and more expensive gearbox options?
I mean a Whiteblock is very cool indeed, but I hardly believe that it's cheaper in the long run when you plan on having it put out that much power.
Old 07-31-2018, 03:30 PM   #23
PAULDRIVER
Too expensive are bmw motors, for same price i can buy some nice bits for my volvo motor
For what ive priced up, its not too bad at all to say its power output vs a stock bmw motor
My volvo motor i paid £350 for complete car, and still to take remains to my scrap yard for some more coin back,
Old 07-31-2018, 04:17 PM   #24
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
You don't need to sleeve a whiteblock. Closed deck conversion is worth doing but sleeving isn't a requirement as long as you're using the earlier, smaller bore blocks.
Rods and pistons, that's kind of the norm across the board for anything really.
Old 07-31-2018, 05:27 PM   #25
PAULDRIVER
I thought so about sleeving, turbo is most costly part
A few more pics...
tacked plate to make 100 per cent
We made a start on the front end.
Cut out for strut top but fits real nice
Same as opposite side
more to follow soon...
