Old 11-12-2013, 03:09 AM   #251
Alex Buchka
8 cylinders
Alex Buchka's Avatar
In order for it to be calibrated it would need a standard to be calibrated to. In this case the standard is what Bosch decided it to be. According to the data sheet (http://www.finjector.com/verkkokaupp...0280130085.pdf) the resistance value should be within a +-5.4% deviation from the nominal curve.
I'm a little disappointed the data sheet only has one data point and a relatively vague plot but in the grand scheme even getting that information is loads more than you can expect from Denso or Magnetti Marelli.
Old 11-12-2013, 04:18 AM   #252
Johann
Johann's Avatar
Link(Ecu) says there's only 1 degree difference in the operating range between these two sensors.
Here's the info of the 039
Johann is offline   Reply With Quote
Old 11-12-2013, 04:24 AM   #253
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
The time constant and nominal resistance are drastically different though, so not sure that it matters.
At any rate, NTC sensors obey a specific curve defined by a specific formula. The typical approach is to just manually obtain enough datapoints to solve for the constants in the formula you can have as many datapoints along the curve as you want, by just plugging values in the formula.
The true "calibration" data for such a sensor would be these 3 constants, as this is equivalent to not just giving the curve, but the mathematical formula for the curve. They are unique to every single sensor though.
-Kenny
Old 11-12-2013, 07:18 AM   #254
Karl Buchka
Yeah, this whole curve business is a little annoying to me. I've been thinking about removing the thermistor and installing an RTD element instead.
Old 11-12-2013, 09:02 AM   #255
Johann
Johann's Avatar
Don't make it more than it is..
Old 11-12-2013, 09:44 PM   #256
Karl Buchka
Forgot the snap rings for the turbo at the shop. Can't assemble it until this weekend. Blah.
Old 11-16-2013, 12:31 AM   #257
Karl Buchka
Capped off the old PCV port on the manifold.
Shifter is bolted up. It niiiiice.
The modified compressor housing looks like it'll work.
Picked up a Walbro 255 from Poik earlier. Finally got that in the mail. I also got a couple of really nice 0-7bar pressure transducers from my buddy Daniel. I'll be using one for oil and one for fuel.
Old 11-16-2013, 03:13 AM   #258
2fast242gt
Do you have a cobalt?
love that shifter!
1983 242dl
*6.0 lq4 swaped* Build thread
Old 11-16-2013, 11:19 AM   #259
Daviticus
This is coming along nicely. I'm really loving that shifter as well.
Blue 1979 245, Khaki 1988 244.
Go read performance subforum for like a month.
Daviticus is offline   Reply With Quote
Old 11-16-2013, 11:47 AM   #260
Råda
Volvoretard/Partshoarder
Råda's Avatar
coming together very nice, much jelly
Jonas
Old 11-16-2013, 12:38 PM   #261
Daviticus
I'm mostly interested to see the power output and powerband with those 16v pistons - I have a set to toss into my FT block for the 16v swap but was hesitant to stuff them in.
Old 11-17-2013, 03:09 AM   #262
Karl Buchka
Thanks guys!
Yeah, I'm also looking forward to seeing how this combo works out.
Bolted up the VEMS panel. The factory kick panel cover fits perfectly over top of it. I was going to crimp and connectorize the bulkhead connector, but I forgot the pins and crimper at work. Doh.
Turbo is re-assembled and installed.
Spent way too long ****ing with that stupid piece of **** snap ring on the compressor housing. After much swearing, breaking one of the tangs off the snap ring, more swearing, and a ****ty "custom tool", I got it in place.
I also spent a bunch of time going through the green manuals to get some of the less than stellar wiring sorted out. Some of the wires around the washer pump have flaking insulation and need to be replaced. I also need to do some connector splicing since I've bolted on different headlights and turn signals.
At this point I'm slogging through all the little **** jobs that need to be done but aren't visible.
Old 11-17-2013, 03:57 AM   #263
Arn02
Arn02's Avatar
Ah those. The ones that keep on coming like pop ups on a pr0n site.
Ambitious but rubbish.
The 245 GT
The Euromurican
Arn02 is offline   Reply With Quote
Old 11-17-2013, 04:06 AM   #264
Kestrel
Kestrel's Avatar
Now that... is a piece of work. I love it.
Old 11-19-2013, 07:03 PM   #265
Duder
Comes with a free Frogurt
Duder's Avatar
That is a super sweet custom tool. Those snap rings can be a giant pain to get in and out. If your special tool fails, get a pair of these:
Knipex 44 21 J21. I use these whenever I'm working with a compressor snap ring. They work.
http://www.knipex.com/index.php?id=1...453&artID=1673
Old 11-19-2013, 07:06 PM   #266
Karl Buchka
They look like they're too small. The HX35 snap-ring is about 200mm in diameter.
Old 11-19-2013, 07:32 PM   #267
Hodginsa
Always
Hodginsa's Avatar
200mm!
I have a really nice pair I bought awhile ago that look like those pictured above, worked well for my GT35R, but it is only about 100mm I would say.
http://idlehandsproject.com - Keep me busy.
Hodginsa is offline   Reply With Quote
Old 11-19-2013, 07:40 PM   #268
Glad to know I'm not the only one that is ready to kill a bitch while messing with one of those snap rings.
Old 11-19-2013, 07:59 PM   #269
84 Blue 240
84 Blue 240's Avatar
I have been brought into fits of rage by turbo snap rings. I think I pounded a broken carb I had lying around into little pieces with a sledge after trying to take a comp cover off.
Originally Posted by manjiman View Post
I just wanted to know if the '87 740 turbo came with a differential? If so, which one?
1984 245 with Getrag Swap
84 Blue 240 is offline   Reply With Quote
Old 11-19-2013, 08:01 PM   #270
Falcone
Falcone's Avatar
I use these on hx snap rings. I think they were 50 bux. They do internal/external rings.
Thanks for inspiring the volvo community.
K-Town Brick Militia________94 854 The BBQ
I was us up all night with a rusty hammer trying to build a fence around these magic beans my dreams have gathered
Falcone is offline   Reply With Quote
Old 11-19-2013, 08:21 PM   #271
Duder
Duder's Avatar
Well shoot, I guess I've never tried those pliers on giant novelty-size Holset snap rings. I know that they do work for all the Garrett snap ring compressor housings. Anything bigger than a GT35R gets a bolted connection.
Old 11-19-2013, 10:04 PM   #272
shaved240
shaved240's Avatar
I always struggle with the dam compressor ring on the dam hx40. it's scary as hell when that thing slips off the channel locks with a ton of force. sometimes i'll get the snap ring on the compressor housing easy, sometimes it'll take me literally an hour to get it on by myself. It really easy if you have two people, one person with snap rings, the other person with a flat head guiding the ring into its slot.
1988 244: b230f+t, M46:PARTED
1995 960: SOLD
1994 945: SOLD
Old 11-19-2013, 10:54 PM   #273
Captain Bondo
I use the same thing as Karl basically. Two pieces of 1"x0.375" flatbar, each, about 40" long, with a pivot in the middle, and small bolts through the end ground to fit the snap ring.
When the bolts get mangled I replace 'em. Best tool.
Old 11-20-2013, 01:02 AM   #274
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
What you capped off is the idle port. looking awesome, the na 16v pistons will work fine.
Megasquirt Tuning!
Old 11-20-2013, 09:48 AM   #275
Karl Buchka
Thanks for clarifying. I kinda don't care what the port was for.
I'm not wild about the lack of E85 out here, but pump gas should get me enough power to have plenty of fun.
