Old 05-10-2017, 02:00 PM   #1
DME
vague member
DME's Avatar
Default Jumping low pressure switch
The AC is not working in my '84. It's a factory conversion from R12. I have charged it but the compressor is not kicking on.
Is there any risk to my jumping the connections for the low pressure switch to text the compressor? I had a log splitter explode in my years ago and I am ultra gun shy about repeating the "machine exploding in face" experience.
Thanks
Dave
DME is offline   Reply With Quote
Old 05-10-2017, 02:06 PM   #2
EivlEvo
I don't have an answer for you, but I did this with switched power on my 93 (which is a different system) that I assumed didn't work, so I was fighting an uphill battle anyhow.
In my car it takes a second or two for the magnets to fire.
Old 05-10-2017, 03:46 PM   #3
Grr baby, grr
I had to jump the one out on my 780 to get the compressor to run enough to charge it.
Old 05-11-2017, 08:16 PM   #4
To old for this
Try checking the green wires at the pressure switch with a test light or volt meter.
To old for this is offline   Reply With Quote
Old 05-11-2017, 08:23 PM   #5
Cwazywazy
Cwazywazy's Avatar
It'll be fine. I did it in one of my cars to make sure the compressor worked before I charged it.
I don't know what I have
Old 05-11-2017, 09:27 PM   #6
gsellstr
Vintage anti-ricer
gsellstr's Avatar
You're fine to jumper them, common practice to test or charge some systems. All the switch does is jumper them under the correct pressures anyway. Just don't leave them jumpered.
RIP
74 144 B20
90 745Ti
Old 05-11-2017, 09:57 PM   #7
HiSPL
HiSPL's Avatar
Because you might burn up your compressor.
It still won't splooge on your pretty face.
Beets taste like buttfeet.
Old 05-15-2017, 12:47 PM   #8
DME
vague member
DME's Avatar
Well that didn't work.
Sigh
Old 05-15-2017, 12:50 PM   #9
EivlEvo
Sigh
What didn't? It's an electromagnet. If power is applied, it magnetizes.
Old 05-15-2017, 12:53 PM   #10
DME
vague member
DME's Avatar
The compressor did not run.
Old 05-15-2017, 12:59 PM   #11
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
Bummer. Bad compressor clutch.
-Stephen
#mclovethesenuts
Old 05-15-2017, 01:20 PM   #12
DME
vague member
DME's Avatar
Actually, ****.
I remember that last time I was under the car I saw a green wire hanging down, not attached. Spade on the end. It was on the driver side about half-way into the engine bay. I totally blanked on that, must be spending too much time enjoying my divorce.
Any tips on where that bad boy might go?
Old 05-15-2017, 03:09 PM   #13
TestPoint
TestPoint's Avatar
At the compressor end it should find a male spade to attach to. The udder end goes to the thermostat control in the dash.
Ford V8 Conversion Manual -
Old 05-15-2017, 03:23 PM   #14
Cwazywazy
Cwazywazy's Avatar
Yeah, supply 12v directly to the compressor. In my car the thermostat was bad and needed replacing.
Old 05-15-2017, 07:43 PM   #15
To old for this
Make double sure the compressor is grounded.
