Old 04-03-2016, 09:26 PM   #151
LC4CARL
Aero challenged
LC4CARL's Avatar
You guys are too good...
Life begins at 10PSI.
Old 04-03-2016, 09:26 PM   #152
LC4CARL
Aero challenged
LC4CARL's Avatar
Had to do it...
Old 04-03-2016, 09:30 PM   #153
Originally Posted by 77volvo245 View Post
The tailight on the left might be from a 81-84
Early had a short single filament bulb holder on the bottom.
[No Fogs]
Old 04-04-2016, 01:33 PM   #154
LC4CARL
Aero challenged
LC4CARL's Avatar
Trans mount. I could not access the upper nut (#4). There were some bolts on the bracket (#5), but the one I pulled was quite long and I was afraid to go further out of concern that I might separate the case or something.
Old 04-04-2016, 01:42 PM   #155
Don't worry be happy it's just 2 bolts go ahead and pull it after you support the transmission.
Old 04-04-2016, 03:24 PM   #156
LC4CARL
Aero challenged
LC4CARL's Avatar
Sweet. Hopefully it doesn't dump my Redline goodness on the ground.
Speaking of that, the trans is shifting progressively better. No longer prolonged grinds into reverse and first on a cold start. Still not a "fast" shifter, but hey. Looking forward to swapping in the metal shifter bushings.
Old 04-04-2016, 03:32 PM   #157
Did you try adjusting the 1st / reverse shift gate?
Old 04-04-2016, 05:55 PM   #158
ChillChris
I just adjusted that on my car, and I have to say it feels 10000x better for it.
ChillChris is offline   Reply With Quote
Old 04-05-2016, 12:22 AM   #159
LC4CARL
Aero challenged
LC4CARL's Avatar
Sounds promising. How do I do it?
Old 04-05-2016, 12:35 AM   #160
Lift the shift boot up loosen both sides with an 8mm socket a little then, move gate back 1mm then do the same to other end, and resnug both.
Repeat till 1st 2nd & reverse operate smoothly.
Old 04-05-2016, 01:15 AM   #161
Kjets On a Plane
Kjets On a Plane's Avatar
^Maybe replace the hooped shift bushings while you're at it?
As long as you are suffering with that miserable boot have fun with the likely rubbed through reverse lamp wiring and trying to get the boot back in without pulling or ripping the carpet.
How PSI a stock can support?
Always Be Crushing!
Old 04-05-2016, 03:09 AM   #162
sbabbs
sbabbs's Avatar
What I do is snip the corners of the carpet.
Old 04-05-2016, 04:10 PM   #163
LC4CARL
Aero challenged
LC4CARL's Avatar
Thanks guys! I'll give it a go.
Scored some used lights, a working speedo, a grille and various clips and fasteners today. Slow and steady wins the race...
Old 04-06-2016, 10:39 AM   #164
LC4CARL
Aero challenged
LC4CARL's Avatar
Old 04-08-2016, 03:56 PM   #165
LC4CARL
Aero challenged
LC4CARL's Avatar
Hitting the Craigslist and local salvage yards for bits and pieces. Lift gate struts are finally in. Found this sweet hitch plug and some clean trim panels and wiper arms (with the plastic covers intact). Also the radiator support grommet for the air intake and a front bumper extension post, etc. Got stuck in traffic for an hour with no overheat. Yeah!
Old 04-08-2016, 06:37 PM   #166
LC4CARL
Aero challenged
LC4CARL's Avatar
Is there any benefit to running a "torque strap" (cable) from the top of the engine to an anchor someplace? For the modest power, these engines do move around a bit.
Old 04-08-2016, 11:55 PM   #167
LC4CARL
Aero challenged
LC4CARL's Avatar
How is the spare tire anchored? I found a rubber strap with two hooks in the salvage yard, but I'm not sure if it's for the spare.
Old 04-09-2016, 12:17 AM   #168
amerbritcan
Hnnnnnng
amerbritcan's Avatar
Yup that's it. Hooks into little slots in the metal.
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 04-09-2016, 12:59 AM   #169
LC4CARL
Aero challenged
LC4CARL's Avatar
Alright. Can you help me with a photo? I'm stuck.
Old 04-09-2016, 01:04 AM   #170
amerbritcan
Hnnnnnng
I've never taken a picture of my trunk haha, also it's probably quite a bit different in wagons, never needed to access my spare in either wagon I had.
Edit: Mayyybe this'll work
http://www.google.ca/search?q=volvo+...&sa=N#mhpiv=16
Old 04-09-2016, 01:11 AM   #171
There's a rectangular cut out low in the pinch weld up front, and another in the back inner panel up high.
Old 04-09-2016, 11:34 PM   #172
LC4CARL
Aero challenged
LC4CARL's Avatar
Well, I'm embarrassed to show my dirty car next to your pristine car, but here goes:
I am 90% on the lower anchor point.
Not so sure on the upper. I did find this cut out in the fender pinch weld. The only discrepancy is that the band is slack in that position. If this is the correct location, an adjustment of the band would be simple enough.
To get the band snug, I've got it attached to this rail on the quarter, which doesn't look quite right.
Old 04-09-2016, 11:45 PM   #173
LC4CARL
Aero challenged
LC4CARL's Avatar
Very cool. I did find this:
Looks like my new (used) jack is supposed to go in there too.
Old 04-09-2016, 11:57 PM   #174
That was my 83 when I cleaned some surface rust, primed and painted the butt cheeks with white appliance epoxy.
Old 04-10-2016, 12:13 AM   #175
LC4CARL
Aero challenged
LC4CARL's Avatar
OMG!
