Old 08-11-2019, 10:49 AM   #1
xmlhack
xmlhack's Avatar
Default Wheel spacers on 140
I came across some 17 x 7 5x108 wheels. The center bore is identical to factory wheels and fits the black volvo center caps perfectly, EXCEPT, for the fronts! The grease caps push them out. So im thinking about spacers. What’s the max thickness i can go on a spacer without changing out my wheel studs?
72 Volvo 142E
xmlhack is offline   Reply With Quote
Old 08-11-2019, 10:52 AM   #2
Depends on the thickness of the wheels.
Old 08-11-2019, 11:04 AM   #3
xmlhack
xmlhack's Avatar
Oh, yeah, right. Alright, what the heck. If I have to remove my front hubs to install longer studs, i check/repack my bearings, and do a brake job while im in there.
Hey, RWC, and chance you know the hub diameter for shopping spacers?
Old 08-11-2019, 11:14 AM   #4
Not a clue 140s wheels aren't hub centric, although the stub in the rear axle is the same as 240s.
Old 08-11-2019, 03:23 PM   #5
These studs and spacers should work on a 140.
We sell a 16.5mm that clears the front hub
https://www.bneshop.com/collections/...-wheel-spacers
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 08-11-2019, 03:33 PM   #6
I had a similar problem when the aftermarket wheels hit the caliper on my 140. It just needed a thin spacer to clear but I was concerned with the amount of thread engagement so I got a set of these ET/Ultra style lug nuts that have a thin threaded shank.
https://www.sfxperformance.com/parts/GOR68188-20.htm
Old 08-11-2019, 04:25 PM   #7
GeneralBurrito
GeneralBurrito's Avatar
Not trying to steel the thread, but are 240s hubcentric?
Old 08-11-2019, 04:29 PM   #8
Yes and no.
Old 08-11-2019, 05:35 PM   #9
GeneralBurrito
Alright
Old 08-11-2019, 08:44 PM   #10
xmlhack
xmlhack's Avatar
Default Creative solution
That’s creative. I might just check that out. Thanks for sharing.
Old 08-12-2019, 05:10 AM   #11
OttoB
I ve heard that 240 grease cup allows a little more clearance than 140 cups. I not have tested that personally.
