Old 05-19-2017, 05:31 AM   #1
Otto Mattik
Otto Mattik's Avatar
Default AW70 on last legs
92 240 wagn 230k mi AW70
I purchased wagon for a low price over a year ago, knowing the tranny was failing & have since flushed it 3 times and added Lucas. My point is, lately it has gotten a bit worse during the 2 to 3 shift and it doesn't want to stay in overdrive or jumps back into 3rd on the slightest incline.
Any chance the overdrive solenoid could be part of the problem ?
* I've been looking for a "known" AW71 but no luck, and found an AW70 from a rear ended car w/ 93k mi. But still hoping for an AW71
Originally posted by Jack
_________________________
Old 05-19-2017, 06:37 AM   #2
John242Ti
manofewords
John242Ti's Avatar
Is the kickdown cable binding or out of adjustment? That's what I'd check.
-J
1982 242Ti - black, M46. 1985 245Ti - blue, M46. 1989 745Ti - red, Aw71.
Formerly Blue245Ti, 245GT-Turbo, and, originally 242GT-Ti.
Old 05-19-2017, 11:00 AM   #3
coalminer
You flushed it 3 times and added Lucas?
Did you also clean/change the oil strainer in the pan?
I would also try a different overdrive relay.
Checking the kick down cable is a good idea too.
Does the transmission slip, or merely have problems shifting and staying in gear?
coalminer is offline   Reply With Quote
Old 05-19-2017, 12:15 PM   #4
Khrrck
Professional Amateur
I've had overdrive issues before, the only symptom (presuming the solenoid is the only point of failure) is that the transmission will never shift into 4th.
'87 240 budget wagon.
Old 05-19-2017, 02:53 PM   #5
Try a new kickdown cable first. Mine was acting similar. Slipping, usually no OD...kickdown cable fixed it.
Old 05-19-2017, 10:50 PM   #6
Otto Mattik
Thanks gents, the PO had kickdown cable replaced at a local Volvo dealer (like many other parts).
I don't know much about kickdown cable, but will investigate (Slipping occurs mainly on 2 to 3 shift).
* First flush produced a nasty grey/brown color. 2nd flush was much better. 3rd flush was conversion to Dex VI & result is bottom end torque improved
Old 05-19-2017, 10:54 PM   #7
Otto Mattik
* Have not done pan/filter, but found records of PO having it done in past
* Slips on 2 to 3 shift and wants to jump back to 3rd gear on slightest incline
Old 05-21-2017, 12:55 AM   #8
Otto Mattik
Yep thanks gents !
I created some slack on kick down cable & things instantly improved ! After a test run I did a bit more, & even better. First try I created apprx 1/4-3/8" slack, then next time another 1/8". 2 to 3 shift slip also improved (or was it rainy weather helped cool trans ?)
Old 05-21-2017, 01:40 AM   #9
One could check pressures.
Old 05-22-2017, 01:59 AM   #10
Otto Mattik
ok researching thanks
Old 05-22-2017, 06:42 AM   #11
DET17
Reformed SAABaholic
Exact specs for that trans. cable adjustment (as you have learned, it matters) can be found on the UK Volvo 700/900 Maint. Pages. Adjusted mine 5 years ago, never had to touch it. You can also find the direct link near the top of the BB homepage.
Old 05-22-2017, 09:45 AM   #12
I haven't done much of it myself, but there are threaded test ports on the side of the transmission to test the pressures.
Old 05-23-2017, 02:42 AM   #13
Otto Mattik
Thanks, after a third adjustment (created slack) a grand total of 1/2-5/8" the car has no downshift issues(*also not certain but it seems to have stopped slipping ? Or possibly something else going on)
A) I suspect that the downshift cable may not have ever been adjusted properly (?)
B) I tried downshift button, & it still works perfect
THANK YOU
Old 05-23-2017, 02:43 AM   #14
Otto Mattik
OK, yep saw that, looking into it. Thanks for advice on kickdown, made all the difference !!
Old 05-23-2017, 02:56 AM   #15
Otto Mattik
-J
Thank you
Old 05-23-2017, 03:56 PM   #16
Great! My 86 740 still shifts great and doesnt slip a year later after I replaced my kickdown cable. The lube goes away in the sheath and they can bind. I recommend blasting oil down in it if you decide not to replace it.
Old 05-23-2017, 04:19 PM   #17
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
^This.
I do that once a year with some decent spray lube.
-Stephen
#mclovethesenuts
Old 05-24-2017, 01:03 AM   #18
Otto Mattik
Thanks I will do the lube as well
