Old 09-14-2018, 03:23 PM   #1
jvluntzel
Default Crank position sensor relocation (Ideas)
Just had a thought and was curious since I have a regina car and if I even wanted to go bosch that would mean engine out because of CPS on flywheel....stupid....
Has anyone heard of a front mounted CPS on the crank pulley like bmw and others do?
Thanks everyone!
jvluntzel is offline   Reply With Quote
Old 09-14-2018, 04:31 PM   #2
KL Racing has what you're looking for.
This pulley accepts a trigger wheel. The related parts for the sensor, brackets and trigger wheel are shown.
https://shop.klracing.se/sv/artiklar...v-3-spar-.html
Old 09-14-2018, 09:21 PM   #3
bent-grill
my solution was to attach it to the back of the crank pulley thusly.
I still need to time it, weld it to the hub, make a bracket to hold the sensor, and clearance the timing belt cover because I didn't think that far ahead. it's not the greatest solution but i'm going to make it work.
bent-grill is offline   Reply With Quote
Old 09-14-2018, 11:05 PM   #4
Broke4speed
Broke4speed's Avatar
I mounted one to the front of my B21 crank pulley, worked great with megasquirt. I had converted from a BW55 to an AW71L, using the original flywheel, so I had no CPS slots. My 84 was originally a carbed B21A.
1984 B6304S/AW30-40 w/Poi-Shift.
Old 09-14-2018, 11:49 PM   #5
Dirty Rick
Dirty Rick's Avatar
Keep the tooth count to 36, a MS2 system runs into limitations with high tooth counts at upper RPMs.
Bent-grill - that is a fine solution.
Old 09-18-2018, 09:27 AM   #6
jvluntzel
Thanks everyone! Any idea on tooth count for if I wanted the Rex/Regina system to work?
