Old 05-05-2019, 11:50 AM   #1
billkaz
Bomber Dream
billkaz's Avatar
Default Crank/Camshaft seal installation tools
Timing belt is coming up soon, and I'm planning on replacing the front seals while I'm in there. I've already purchased new seals from my local Volvo dealer.
Any thoughts on seal installation tools? Or can you get by without them?
1992 240 Wagon
2006 Mazda6 Wagon
billkaz is offline   Reply With Quote
Old 05-05-2019, 01:54 PM   #2
300+hp on the shelf club
You can get by without them if you are careful. I have done so many and hope to replace more belts so I bought the tools. They are nice and the tools are still sold by venders like Baum tools and Volvo sells them too.
If you don't use the tools. Be sure to clean the surfaces very well so the lip of the seal doesn't get damaged going on to the shafts.
Old 05-05-2019, 09:18 PM   #3
84B23F
84B23F's Avatar
Mechanic's Pick and Hook Set works fine for removing seals there.
I've used plastic/metal pipe whose outer diameter just covers outer metal area where seal seats, so seal is flush with its housing when done. I've done this for years with other vehicles, including FWD vehicles (CV shaft seals). It should not take much hammer pressure, but it needs to be uniform across pipe used.
Old 05-05-2019, 09:38 PM   #4
Rusty_ratchet
Rusty_ratchet's Avatar
Robert DIY sells a version of the seal installation tools. I've done the job with and without the tools. I prefer putting new seals in with the tools.
Rusty_ratchet is offline   Reply With Quote
Old 05-06-2019, 07:00 AM   #5
DET17
Reformed SAABaholic
Best low $ tool I've seen to pull the seals from the engine is a paint can lid opener...... tiny hook on the business end is perfect for reaching in beside the rotating shaft. User end looks a bit like a beer bottle opener Damned amazing quick removal!
I had a machinist buddy lathe up the proper sleeve to install the new ones; uses the center bolt to pull the seal into position.
OEM gray Volvo types..... I won't install the red Elring ones again, leak prone.
Old 05-10-2019, 06:36 PM   #6
quillc
yv1a.com
quillc's Avatar
http://www.sirtools.com/volvo.htm
I have all of these seal tools. A nice square installation compared to the shaft makes the seal last longer.
Chris
www.yv1a.com
