Old 04-05-2019, 12:27 AM   #26
iHateVolvoPeople
Lord_Athlons daddy
Originally Posted by apachechef View Post
it is not under stress during daily driving, I can turn mine by hand, as anyone should be able to.
Are you serious?
You’re right they’re not under stress, but rust takes its toll. It depends where you’re from, I guess.
Feedback Thread
Current:
93' 244T M47
93' 245 M47
90' 744 AW70
90' 745 AW70
94' M-Edition Miata 5 speed, 93k
95' Camry A140E, 246k
91' 745 Regina AW701, maybe future turbo project
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
Old 04-05-2019, 03:23 AM   #27
Otto Mattik
Otto Mattik's Avatar
I would second the alternator/brushes. And belts.
Alt, v-belts, timing belt, water pump, radiator, radiator/heater hoses, fuel pump relay, fuses, crank position sensor, cap/rotor. Anything that can suddenly leave the car dead are worth considering as spares.
I like having a voltage gauge in the car to warn me of charging issues. It's come in handy a few times...massive oil leak from the cam seal onto the belts...worn brushes...worn out belts....dying battery that wouldn't hold a charge overnight.
I've had an ignition rotor fail where the center caved in and finally the car died and would not restart. Leading up to the night it failed, it would fail to hot-restart about once every week or two for a couple months. Even if you replaced it recently, I would definitely carry a spare. Coil, coil wire, and ign. module too if you have spares.
I carry a spare crank position sensor. The wiring harness is subjected to heat and the insulation often fails. This could easily leave the car dead on the road, but it's such a small inexpensive spare to carry, and only takes a few minutes to replace....if you have enough extensions.
I've always had a few extra radiator hoses and a length of small hose to patch up the hose to the overflow tank hoses if needed. Bring a few feet of heater hose and you can bypass the heater core if something were to happen to your heater hoses out on the road.
Hose clamps, coat hanger, bailing wire, zip ties, duct tape...the usual stuff for emergency fixes. Tire plug kit, air compressor, spare tire that holds air and has rubber on it.
Interesting, reminds me of the Winter Emergency Kit thread from the past season
Originally posted by Jack
_________________________
Feedback Link: http://forums.turbobricks.com/showthread.php?t=323689
Old 05-05-2019, 04:46 PM   #28
DD Ranch
DD Ranch's Avatar
How'd it go then?
Pics?
Florida Chapter VCOA
DD Ranch is offline   Reply With Quote
Old 05-05-2019, 07:03 PM   #29
iHateVolvoPeople
Lord_Athlons daddy
Originally Posted by DD Ranch View Post
How'd it go then?
Pics?
It likely broke down in the mountains and OP wishes he’d driven a Toyota there instead.
Old 05-05-2019, 10:38 PM   #30
darkmountain
Originally Posted by cmsuter View Post
Where at in NC? I'm in Charlotte and also play music
I am in Charlotte, I play in a couple of hc punk bands called Mutant Strain and Whispering man! What kind of music are you into?
darkmountain is offline   Reply With Quote
Old 05-05-2019, 10:40 PM   #31
darkmountain
Thanks for all the reply's. Last min changes literally day of caused me to not need to take my wagon. Im terrible at the internet.
Old 05-06-2019, 12:43 AM   #32
Jack
junkman
Jack's Avatar
:ban:
Old 05-06-2019, 12:12 PM   #33
iHateVolvoPeople
Lord_Athlons daddy
What did you drive instead?
Old 05-08-2019, 10:25 AM   #34
cmsuter
I'm a little all over the place haha. I play with a couple of R&B/Soul singers but just left a proggy/alt rock project recently. I do production and recording as well if you ever need something done
cmsuter is offline   Reply With Quote
