Old 05-08-2019, 11:34 AM   #26
oifish
I'm feeling extra zazzzy
oifish's Avatar
I tried both raising and lowering the center bearing and neither helped. I got fed up and took it to a euro shop. They said the shaft is fine, and likely the problem is in the axle. They don't really want to mess with the axle. So I guess that changes the focus... Anything I should look at in the diff/rear axle that could cause this?
1990 Volvo 744T M46 - Daily Driver - ( ͡° ͜ʖ ͡°)
1996 Chevy C1500
__________________________________________
Buy/Sell Feedback
oifish is offline   Reply With Quote
Old 05-13-2019, 03:26 PM   #27
-Measure runout. Ok?
-Remove driveahaft, rotate 180 degrees and reinstall. Is it better?
-You can also see if you have any luck adding hoseclamps. The tail of the clamp is clipped off.
