Old 04-19-2019, 03:05 PM   #1
tomasss
tomasss's Avatar
Default Flywheel hairline cracks
I have unmounted the pressure plate and clutch from my 740T and found out there are harline cracks in the flywheel surface...now I am wondering if I should worry about it or if it is normal.
What do you guys think? (click the pic for full res)
Volvo 740 Turbo B204GT 1991 >project thread<
It's the oversteer that scares passengers. It's the understeer that scares the driver.
Originally Posted by Wren View Post
I would rather push a 240 than drive a V70.
lazy PRV engine? Check >this< out
tomasss is offline   Reply With Quote
Old 04-19-2019, 03:09 PM   #2
Jack
junkman
Jack's Avatar
That flywheel needs to be resurfaced unless you like to change your clutch often
/thread
I love you even more Jack.
Old 04-19-2019, 03:16 PM   #3
stick70
All the gauges
stick70's Avatar
As jack said, it's totally normal, but you should get it resurfaced. Any machine shop that does car stuff will handle it, shouldn't cost much over $100.
I can't speak to what will happen if you don't get it done, but it's easy enough to handle.
Old 04-20-2019, 12:11 PM   #4
283SD
Resurface it. It looks like a lot of clutch slippage to get it so hot to burn the surface.
Old 04-20-2019, 12:33 PM   #5
elmford1
elmford1's Avatar
Just finished mine. It was way worse stock clutch couldn't take it in 3 and 4
elmford1 is offline   Reply With Quote
Old 04-20-2019, 01:10 PM   #6
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
It looks like that car was driven by a clutch slipper, or had a poorly adjusted one. Before you took it out, did the clutch squeel or chirp on engagement?
Old 04-20-2019, 01:21 PM   #7
tomasss
tomasss's Avatar
I drove the car like 20 meters...from the tow truck to my garage but those two or three clutch engagements were ok, without any weird sounds.
Ok, going for resurfacing.
Old 04-21-2019, 10:56 PM   #8
11BC2
Depending on how severe The blueing is, that flywheel might be scrap, as the metal has been compromised. Resurfacing will only clean up the surface, not core(if you will) of the flywheel.
11BC2 is offline   Reply With Quote
Old 04-22-2019, 01:01 AM   #9
sbabbs
sbabbs's Avatar
If your just putting a stock stuff back in and not racing it should be fine if it cleans up with resurfacing. Problems happen when you try and use ceramic discs and go racing. Make sure you get the top of the dog dish ground down so the gap is within spec between the pressure plate mounting surface and the surface of where the disc rides.
1988 245 White slicktop M47 Wagon! Motor still out of it.
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 548K Melted motor..
1995 940 White racing wagoon. T25 .64 a/r m90 to put in
Old 04-22-2019, 11:33 AM   #10
Harry Tuttle
Agreed that with resurfacing that FW should work fine for daily street use.
Where is that spec to be found?
Originally Posted by dl242gt
It's always better to get into a turbo volvo and drive.
Old 04-22-2019, 12:29 PM   #11
They're boxy but good!
Location: See my real-time location on Maps: https://maps.app.goo.gl/xiryhjZzwpSvTtnn6
I would assume you would have to cut it the same amount as the mating surface.
"Over the hump of Truth and through the flaming hoop!"
-S.B. Squarepants
Old 04-22-2019, 01:18 PM   #12
sbabbs
sbabbs's Avatar
We'll my machinist in Creswel Oregon, Drummond automotive machine, he had a book or he just knew it. I never asked, but he did do both surfaces. Also only charged me 25 buxs. Bro deal. Others like big time shop in Portland say Bearing services would probably charge at least 100 maybe more. Bearing services charged me 550 buxs to lighten my dog dish flywheel that exploded at the track with a ceramic disc after it got way to hot doing 10 runs in a row 100 degree day. Nowdays I only run billet steel flywheels, cheaper then other BS..
Old 04-22-2019, 02:00 PM   #13
Harry Tuttle
Hmmmm... somebody must know that. What if it has been previously ground incorrectly? If I know the proper depth of the step I can check for that beforehand, and check my machinist's work afterward. It is hard for me to believe that any random machinist would know it.
Will search greenbooks...
Old 04-22-2019, 04:27 PM   #14
culberro
culberro's Avatar
Pretty sure the step height is spec'd at 25.0mm.
Old 04-22-2019, 09:29 PM   #15
Harry Tuttle
Old 04-24-2019, 05:33 AM   #16
tomasss
tomasss's Avatar
Some more pics just to justify myself why do I need to spend more money on it
It is indeed little bit blueish on the daylight, so I am preferably replacing it with a different one rather than resurfacing the current one.
Old 04-24-2019, 11:47 AM   #17
Jack
junkman
Jack's Avatar
oook
Old 05-10-2019, 09:01 AM   #18
tomasss
tomasss's Avatar
Guys...it's damn tough to find a good flywheel! Most of them is cracked even worse than mine...
The only one I have found not worse it >this< one but still I see that it has some heat spots and the surface is rough...any opinions about this one?
Old 05-10-2019, 09:35 AM   #19
iHateVolvoPeople
Have you posted in the wanted section?
Feedback Thread
Current:
93' 244T M47
90' 744 AW70
95' Camry A140E, 246k
99' Camry A140E.
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
90' 745 NA sold
93' 945T in burgundy
91' 745 Regina AW701 turbo (traded for 96 Camry wagon)
93' 245 M47
Old 05-10-2019, 10:17 AM   #20
It'll buff out.
Old 05-10-2019, 10:57 AM   #21
Jack
junkman
Jack's Avatar
It'll buff out.
This
Just get it resurfaced already
Old 05-10-2019, 12:18 PM   #22
tomasss
tomasss's Avatar
Yeah...that is bigger problem in this damn country than it seems. Barely anyone knows how to weld here, machining generally is a big no-no.
I will check if there is anything close by in Germany.
Old 05-10-2019, 12:57 PM   #23
iHateVolvoPeople
Might end up cheaper to just have a known good one shipped to ya. Not sure how expensive shipping is but people pretty much give these away I think.
Old 05-10-2019, 03:33 PM   #24
Says the guy who's too lazy to go to the post office.
Old 05-10-2019, 05:23 PM   #25
classicswede
Volvo upgrades
I would either just send it as is or spend on a TTV flywheel
