Old 05-10-2019, 08:50 AM   #26
Mbeas96
Mbeas96's Avatar
Didn't do much last night because of family things, but ran out there just now and the tps clicks when opened...in a few hours I'll check out the timing.
Old 05-10-2019, 01:09 PM   #27
DET17
Reformed SAABaholic
Clicking confirms the switch is making; however only peeling back the rubber boot will confirm if your ECU is getting the input! Check that all wires are connected to the TPS male terminals
Old 05-10-2019, 01:35 PM   #28
mocambique-amazone
Check the TPS and other stuff with the LED onboard diagnostic box. Fairly easy.
Most people only know the fault reading.
even more interesting are the other functions
2 times at 3sec and it will flash. on port 2 it is easy to check the TPS.
have a search in the word wide net.
good luck, Kay
Old 05-10-2019, 10:11 PM   #29
Mbeas96
Mbeas96's Avatar
ill have a look tomorrow when it isn't pitch black.
Checked timing today and it is still in time, didn't slip.
Checked spark on each output on the coil pack and saw no spark on 2 of them and very weak spark on the other 2. I guess that is why it runs like garbage. I guess time to work my way down the system.
Old 05-11-2019, 01:59 PM   #30
Dirty Rick
Dirty Rick's Avatar
Check power to the coils, check for voltage drop while cranking between the coil and B+.
Check for good ground at the igniter (power-stage).
Test fire the coil by grounding negative side?
Old 05-12-2019, 10:12 AM   #31
Mbeas96
Mbeas96's Avatar
Okay so I'm definitely a noob when it comes to working with a meter....which is why I've put it off for this long.
Coil pack has 3 connectors going into it. The middle is 12v constant which I measured 11.0 volts. 9.5 volts while cranking. The other two come from the igniter and I assume fire the coils. They both show 0.0 volts with key on and while cranking, but I know one set has to have some voltage going to it because the car runs. Just on 2 cylinders..
My brother gave me his miatas igniter from his working wasted spark setup and it has no change.
The two wires coming from the wasted spark board to the igniter, IB1 and IB2, gradually increase while cranking and within 3 or 4 cranks shows 1.5 volts.
I'm not positive that I have a good ground by just looking at it...I know you use ohms but I'm not sure how you measure that one..
Also not sure on how to ground the coil pack to test fire as the only wires go to the battery positive and the igniter.
Electrical problems are my worst fear because I have no experience besides wiring up the wasted spark board
Old 05-12-2019, 11:02 AM   #32
Mbeas96
Mbeas96's Avatar
Spark only on cylinders 2 and 3... So either IB1 or IB2 is not giving power to one side of the coil pack
There is voltage going to the igniter on both connections for the coil pack, only 1.5 volts though and idk if that is sufficient...
If it is okay for it to have 1.5 volts to the igniter, and i switched igniters with a known working one, does this mean there is a failure point in between the igniter and coil pack for that one bank of coils?
Since there is only one ground from the igniter and one bank of coils are working, i assume that means the ground is okay and there is a problem elsewhere
Old 05-14-2019, 08:40 PM   #33
Mbeas96
Mbeas96's Avatar
TPS tests good.
Swapped fprs, pressure is a tad higher but no change in how it runs
rewired igniter to coilpack and still no spark on cylinders 1 and 4. Wtf.
Before I go ripping apart my wasted spark setup....why would I have the same voltage coming from the ezk to the igniter on both outputs. But going from the igniter to the coil pack I have nothing. Really I couldn't get a reading from either output going to the coil pack, but there is "enough" spark to run the engine on cylinders 2 and 3
Old 05-14-2019, 09:18 PM   #34
2turbotoys
Salaminizer
2turbotoys's Avatar
Glad you found something, hope someone has an answer for you soon. I have no idea, never played with wasted spark.
2006 V50 T5 AWD 16 PSI +
Old 05-15-2019, 06:47 AM   #35
Mbeas96
Mbeas96's Avatar
Thanks for all the help! I tend to panic when things go wrong...but it can only be so many things. I posted in the ezk thread as well.
Old 05-15-2019, 07:18 AM   #36
DET17
Reformed SAABaholic
TPS tests good.
You really don't have power coming from the WS system in your EZK.... those are "logic signals". Google TTL, transistor type logic. I would doubt there is any issue with your WS chip; while I'm no EE, you would probably need an oscilloscope to see the square wave pulse train coming to your power stage. In my mind, your most likely suspect is either the PS itself, or your wiring between it and the coil pack. If the WS chip is delivering proper 1-4 spark control to your PS, then the failure is downstream.
What do your connections look like at both ends of your harness? Unwrap your black tape and post some pics......ignition wiring is nothing to half a$$ construct.
Old 05-15-2019, 08:43 AM   #37
Mbeas96
Mbeas96's Avatar
Lol as am I no expert either...and don't have access or the knowledge to use an oscilliscope.
That's disheartening to hear as I've swapped a working powerstage/igniter from my brother's running setup.
As of last night I clipped the solders, coming from the PS going to the coil, and just twisted them together to see if the car would run better. (Thinking a solder joint cracked somewhere causing bad connection)
The connector I have going thru the ezk
Is my next target. It is of pretty cheap quality but all of the solders are holding tight. I'm planning to reflow them and see if things change.
Old Yesterday, 05:31 PM   #38
Mbeas96
Mbeas96's Avatar
It's running on all 4!! Crimped on some relay connector butts that I had and pushed them onto the coil pack. Fired instantly and runs smooth! I didn't let it run long because I now need to go back thru and resolder everything I cut and twisted together.....
But it's running!! I'm estatic right now!
