Old 05-03-2019, 10:14 PM   #1
volvoboy90
sanna kärlek är svensk
volvoboy90's Avatar
Exclamation Lh2.4 +t 244 start misfire die
Good evening everyone, I am having yet more problems with my 240. Lh2.4 244+t t5 manual swap with ostrich tunerPro stock ezk. New distributor cap rotor and spark plugs. Plugs I pulled were black. As title suggests, I can get it to start, but it misfires badly and dies shortly after. Smells VERY rich. I was going to spring for another ecu to try out, but I want to get an idea of what you guys might think is going on. Thanks in advance.
Originally Posted by TrickMick View Post
HEY...we're all in this "Volvo stuff" together here @ Camp TBrix...
keeping the "oldies but goodies rockin' down the road"...
*PICK YER POISON*...either put a raw egg under your gas pedal
and tip-toe around town - *OR* learn to live with the GREAT FUN of
sucking unsuspecting "other brand drivers" into the educational benefits
of NEVER underestimating a "grandpa car" again....hee, hee....
RIP TrickMick You'll be missed
volvoboy90 is offline   Reply With Quote
Old 05-03-2019, 11:50 PM   #2
c1800
Check out the coolant temp sensor
Old 05-08-2019, 04:19 PM   #3
volvoboy90
volvoboy90's Avatar
Replaced it today, with intake mani gasket. Pulled the fuse for the ecuto reset it. It does exactly the same thing.
Old 05-08-2019, 04:28 PM   #4
culberro
culberro's Avatar
Do you have a resistor pack or high-z injectors? If you haven't added one or the other, the injector drivers in the ECU are going to be pissed.
Old 05-08-2019, 04:52 PM   #5
volvoboy90
volvoboy90's Avatar
High z injectors. Ran pretty great for until I put dielectric grease on the coil to distributor cap cord. I have since replaced the distributor cap and rotor. Seems to be getting good spark from the coil.
Old 05-08-2019, 05:17 PM   #6
What do the plugs look like? This is exactly the symptom I had recently with a Bertone 780. It had clogged injectors from sitting too long with this ethanol gas we use.
Old 05-08-2019, 05:33 PM   #7
volvoboy90
volvoboy90's Avatar
It hasn't been sitting. I just replaced the spark plugs because of this. The plugs I pulled looked black and smelled like gas. Smells super rich when trying to start.
Old 05-08-2019, 06:53 PM   #8
Unplug the injectors and see if you can keep it running pulsing brake cleaner into the throttle.
Old 05-08-2019, 07:10 PM   #9
An open circuit coolant sensor can make it super rich for starting. Did you make sure the wiring was good by checking it with a meter? You can measure the resistance of the sensor on the computer connector. Back probe the contacts and meaure the sensor.
Old 05-08-2019, 07:20 PM   #10
volvoboy90
volvoboy90's Avatar
I have not, I replaced the sensor today, but due to neighbor problems, I only get about 15 minutes to mess with my car or I get threatened with eviction.
Old 05-11-2019, 07:35 PM   #11
volvoboy90
volvoboy90's Avatar
Ecu was kaput. Got a spare today and fired right up.
Old 05-12-2019, 03:49 PM   #12
Good one! Takes less than 15 minutes to replace, too.
