Old 05-04-2019, 12:54 PM   #1
bmos
bmos's Avatar
Default Aux Jack
I have a 1991 Volvo 740 Turbo that came to me with an aftermarket radio. After some searching, I managed to find a compatible stock radio (CR-718 supposedly out of a 1994 940) that works great (other than having to swap the accessory power wire pin to get the antenna going up/down). I'm trying to figure out how to get an aux jack with this setup before I resort to a 12v FM transmitter. Any thoughts?
The GROM adapter for 94-00 Volvos is apparently just for the 850s and has too small of a CD plug on the back.
bmos is offline   Reply With Quote
Old 05-04-2019, 01:24 PM   #2
240240
Cocaina space cowboy
240240's Avatar
What's wrong with the radio you already have?
Originally Posted by Cwazywazy View Post
I believe the D24 was designed by hitler himself.
Old 05-04-2019, 01:27 PM   #3
bmos
bmos's Avatar
The aftermarket one? I've yet to find an aftermarket radio that looks right to me in 80s/90s cars and definitely not one that works with the optional graphic EQ (which was one of the things that initially drew me to the car). I never really adjust it but it's very retro. I've been driving around listening to community radio and cassette tapes for about a year and a half now, just trying to expand my options without losing the period-correct vibe.
Old 05-04-2019, 06:46 PM   #4
Jack
junkman
Jack's Avatar
Get an alpine from the 80s
Old 05-04-2019, 08:51 PM   #5
bmos
bmos's Avatar
Did any retro radios have aux jacks? What would people even have plugged into them? It also wouldn't work with the Volvo graphic eq. Unless I get a killer deal on a rad vintage McIntosh I'm pretty set on using a 700/900 series radio with a full 780 swap being the holy grail.
Old 05-04-2019, 11:48 PM   #6
HRPufNStuf
HRPufNStuf's Avatar
I have a module that plugs into the oem rear remote cd changer plug on my 91 780 that allows you to plug in an Ipod.
Patrick
HRPufNStuf is offline   Reply With Quote
Old 05-05-2019, 07:14 AM   #7
bmos
bmos's Avatar
Patrick
Are you referring to the pre-lightning 30-pin connector from the 2000s? Is there a brand name?
Old 05-05-2019, 07:13 PM   #8
Jake_NZ
Jake_NZ's Avatar
Just use a cassette adaptor
'80 Volvo 242 GT / '83 Volvo 244 GLT / '87 Volvo 760 / '88 Volvo 245 Propcar / '89 Volvo 245 Propcar / '89 Volvo 245 GLT / '95 Volvo T5R / '04 Volvo S40 2.4i
Jake_NZ is offline   Reply With Quote
Old 05-06-2019, 08:20 PM   #9
HRPufNStuf
HRPufNStuf's Avatar
Yes, the 30 pin connector.......prolly why i havent used it for several years since everything I use now has a lightening.
I believe it was USSPEC or something.....I think I may even have the manual somewhere.
Looks like it is discontinued since the latest IOS is not compatible.....
https://www.usaspec.com/volvo-allmod...999-parts.aspx
Old 05-07-2019, 12:38 PM   #10
jwernerny
jwernerny's Avatar
If you are willing to lose using the cassette for cassettes, you can probably mod the radio to give it an aux input. It's a quick and simple mode, basically you cut the signal lines from the cassette board (inside the unit) and solder in an aux cable. I did it to one of my 960 radios over a decade ago, and it is probably described somewhere on this site.
To use the aux, simply input a cassette into the system and let it play. That triggers looking at the correct input. I used an endless cleaning tape in mine.
In fact, if you want, PM me. I think I still have that radio in my garage, and would have no problems passing it on to someone who will use it.
John Werner
* 1992 944T * 1988 764 GLE V6 * 2002 WRX Wagon (needs motor) * 2006 Honda Odyssey *
jwernerny is offline   Reply With Quote
Old 05-07-2019, 01:43 PM   #11
cleanflametrap
cleanflametrap's Avatar
Does your CR-718 have an 8-pin DIN EQ jack with a dummy shorting plug in it?
-Art
Old 05-07-2019, 03:16 PM   #12
Jake_NZ
Jake_NZ's Avatar
If you were going to go though this trouble - wouldn't you just put a switch in line with the signal lines from the cassette?
So you can swap between the cassette and the AUX jack?
Also, maybe so you could hard wire switch off the motor.
Old 05-08-2019, 08:39 AM   #13
bmos
bmos's Avatar
Next up is a 13 pin DIN connector to aux adapter that I found on Amazon. no clue whether it will work or not but I figured it's the least intrusive option and worth trying before I modify my radio/EQ wiring.
Thanks for the link/info. I haven't had any Apple stuff since the iPhone 4S so I'll keep that option in my back pocket for now.
I actually pulled my radio out and disassembled it to see how complex this would be to implement and it's definitely one of my alternate options. I'll be in touch if my next plan does not work out.
Yes, although it doesn't have a shorting plug as I actually have an equalizer. (I have a shorting plug in my glove box but I'm not using it). This is a very interesting possibility, thanks for sharing!
If you put a switch on the outside of the radio which turns on and off the micro switch which is activated when you put a tape in, all of this will be accomplished quite simply and without losing the use of your cassette player.
Old 05-08-2019, 11:11 AM   #14
cleanflametrap
Mine all have no EQ, so the jumper plug makes a non-intrusive connection. The 5mm jack has switching, so the radio/tape input to the amp is switched by plugging in the aux cable. The EQ line level is much better suited to the ipod/phone level, and allows the volume control to have a normal setpoint and range.
To use this with the EQ, you'd have to interrupt the cable to it, either with plugs and jacks or surgery.
Old 05-08-2019, 02:48 PM   #15
jwernerny
jwernerny's Avatar
Because the cassette transport in the unit was bad, and I was done with 1980's tech. :-)
I think we used 1990's portable CD tech in that car.
Old 05-09-2019, 03:08 PM   #16
philski o'flood
philski o'flood's Avatar
philski o'flood is offline   Reply With Quote
Old 05-09-2019, 03:47 PM   #17
240-FAN
Originally Posted by philski o'flood View Post
You got one of those Phil? $14.99 shipped to the Mid West?
240-FAN is offline   Reply With Quote
Old 05-09-2019, 06:14 PM   #18
HRPufNStuf
HRPufNStuf's Avatar
Where do I buy these bits......or is this patch cable available ready made somewhere?
If building your own, is there a wiring diagram to follow in soldering this up?
Might be time to bring the 780 radio into the 21st century.
Patrick
Old 05-10-2019, 07:59 AM   #19
cleanflametrap
@Patrick
The numbers on the pic are Digi-Key numbers from 10 years ago. Here's an old post where I put up some pinouts in a Brickboard thread on 7/9 radios. https://www.brickboard.com/RWD/volvo...io_system.html
Old 05-10-2019, 08:13 PM   #20
bmos
bmos's Avatar
Unfortunately the off-the-shelf cd to aux adapter just blew the 5amp fuse in the radio. I guess I'll be following in your footsteps by inserting the audio via the eq jack.
Thanks for the link!
Old 05-11-2019, 10:16 PM   #21
HRPufNStuf
HRPufNStuf's Avatar
@Patrick
Thanks,
Found the part numbers, but they seem to want to sell them in Costco sized quantities.
Ill keep looking for small quantity suppliers.
Patrick
Old 05-12-2019, 07:37 AM   #22
bmos
bmos's Avatar
Thanks,
Patrick
I bought a single CP-1380-ND from them just the other day, can't speak for the digikey 3.5mm jack as I already have one.
Old 05-25-2019, 07:02 AM   #23
bmos
bmos's Avatar
So after some trial and error with wire size, I'm happy to say that I was able to add a 3.5mm jack without losing the EQ. I just took the wiring information cleanflametrap posted (I really appreciate it!) and interrupted the left and right audio out wires between the radio and eq with the 3.5mm jack. Ground is connected to both circuits all the time and audio in is connected like stock. Interrupting the audio in wires would be slightly better for the sound quality but I like being able to use the EQ even when my Bluetooth adapter is connected.
1991 Volvo 740 Aux Jack Retrofit Adapter Cable
