Old 05-15-2019, 01:26 PM   #26
Duder
His Dudeness, El Duderino
Duder's Avatar
Originally Posted by vwbusman66 View Post
I'm debating yanking the engine and really don't want to without driving it first. If I pull it, I may be too tempted to plop something newer into it.
Stay on target....stay on target! Fix the B20 and get the car back on the road. Don't let it die and wither away in project car purgatory.
Old 05-15-2019, 01:44 PM   #27
boostin'xr4
OV FIRE
boostin'xr4's Avatar
What is the recommended flavor of that stuff nowadays?
Always used moly grease liberally. A 366 I built in one of my company trucks has 650k broken in that way.
'74 145 - B20, M40, Weber 38DGES
'82 244t - B21ft, MS, E85, H cam, 50trim, T5 swap, etc.
'94 945t - MS, E85, 1500cc's, top mount, 6262, Cd009, etc.
boostin'xr4 is offline   Reply With Quote
Old 05-15-2019, 01:52 PM   #28
JohnMc
JohnMc's Avatar
Hear, hear! Swapping a cam should take you part of a leisurely weekend day. The old pushrod motors are just far simpler to work on. Maybe all day if your definition of 'leisurely' is really on the leisurely side. Coupla hundred bucks, it's running again, and then you can drive it around while you ponder taking out the running B20 to put something else in.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 05-15-2019, 08:37 PM   #29
alschnertz
Enough already!
alschnertz's Avatar
Thought that 142 looked like it would be a decent driver with it's original drivetrain.
Now thinking it will end up being another unfinished "awesome project" car.
Old 05-16-2019, 12:17 AM   #30
vwbusman66
Eisen-Stein
vwbusman66's Avatar
Location: Kingsville, MD/Morgantown, WV/Your mom's house
Duder/John- b20 is staying in the car for the foreseeable future. I just don’t want to pull the engine because I’m lazy.
I got home from work at 6:15 and worked fron then till now trying to do a timing/serp belt on the beater p2r. **** fords
1971 142 M40/B20
Originally Posted by stick70 View Post
It's all just lifter noise til it comes out the side.
Old 05-16-2019, 11:10 AM   #31
planetman
planetman's Avatar
If you use the Volvo cam gear puller and the cam gear installation tools properly, you won't damage the cam plug.
If you need, I have both of those 2 tools available for rent.
Eric
Torrance, CA 90502
Old 05-16-2019, 11:43 AM   #32
Chuck W
Chuck W's Avatar
I was able to do the cam/lifter job while the engine was in the car. This was on a '75 240, so there *may* have been more room. I did have to pull the radiator to do it, though.
The lifter and cam looked like this.
'80 264GLE - (B21FT-MS'ed/M46)
'97 854 T5 (Eventually to be 5spd)
'77 242DL (B21F/M45) - SOLD '75 245DL SOLD '85 244GLT DEAD
'83 Tbird Turbo (2.3T/T5/MegaSquirt)
My feedback thread
Chuck W is offline   Reply With Quote
Old 05-16-2019, 01:30 PM   #33
JohnMc
JohnMc's Avatar
I've done cams with the motor in the car on a 544, a 122, and 1800, and a 140 as well. I'm pretty sure that part of the Volvo styling/design department's job was to make sure the grille opening was large enough and in the right spot for the cam to come out with the engine in place.
Old 05-16-2019, 02:54 PM   #34
planetman
planetman's Avatar
Volvo didn't think about camshaft access on the V6 260s and 700s.
Originally you would have to pull the heads to change the cams and a changing they be needing due to clogged oil passages, but someone came up with the idea to cut a large hole in the firewall so the cams could be removed without pulling the heads. Volvo even sold a large rubber plug to fill the hole afterwards.
Old 05-18-2019, 03:31 PM   #35
sksmith
sksmith's Avatar
vwbusman66,
I have the original cam from my 73. You are welcome to if for a small fee & shipping. I figure $50 should get it to you.
You would need to get some lifters.
At least it could get you going until you figure out what you are going to do engine-wise.
Let me know and I can send you some pics.
Steve
