Old 05-07-2019, 12:48 AM   #1
2turbotoys
Salaminizer
2turbotoys's Avatar
Default Repairing early M46 shift lever reverse lockout
Has anyone successfully repaired an early M46 shift lever? Specifically the reverse lock out. I have no spring action on the ring you pull up. Fixable or replacement time?
1978 242, getting prepped for LS
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 05-07-2019, 01:16 AM   #2
It's fixable but you may need to update some of the parts. There were several revisions over the years. Do you know if the pull rod is a round rod threaded at one end and bent 90° at the other (#8 in the first pic) or a flat metal piece with a bend at the ends (#15 in the second pic)?
The easiest way to tell is to find where the screw in the ring is located. The early setup has a setscrew going in from the side (#9, 1st pic). The later setup has a screw that goes in from the top (#16, 2nd pic).
There's an even later setup that uses a plastic strap which is what you may end up with but everything changes. I have some parts for the early reverse setup.
Old 05-07-2019, 02:45 AM   #3
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
If this is for the green 1978, that car may've been updated to the 1979-on shifter parts, since it has the shorter shift lever than it came with.
Old 05-07-2019, 04:25 PM   #4
2turbotoys
Salaminizer
2turbotoys's Avatar
It is for the green '78, and it appears you are correct about the shifter. I have the later setup with the screw (#16) that goes in from the top.
Old 05-07-2019, 04:40 PM   #5
This kit has everything you need to update to the late style.
https://www.ipdusa.com/products/7955...lar-repair-kit
Old 05-07-2019, 05:23 PM   #6
2turbotoys
Salaminizer
2turbotoys's Avatar
Thanks, ordering now.
