Old 05-10-2019, 01:38 PM   #26
84B23F
84B23F's Avatar
Originally Posted by dbarton View Post
Volvo red blocks are pretty notorious for having low oil pressure at idle when oil is hot (exasperated by hot summers days).
I've never had this issue.....but here is my simple idea:
Modification Footnote - If I was doing a modification, I would install a Primer Button above 240's fuse box, so that I could manually prime the fuel pump, or if needed, to "limp home" while depressing this button.
RE: Simple magnetic inertia switch
In the 60s, MGs had a rollover sensor to cut off fuel...
KISS - Primer Button above fuse box on 240:-)
