Old 05-09-2019, 07:29 PM   #1
oemoilleaks
Default 142 GT Cluster - Dead Fuel Gauge
Has anyone ever used the guts from a stock cluster to repair a dead fuel or temp gauge on a GT cluster?
The arc and need are different in the stock gauge but I was wondering if there's a way to get the electronics to swap over.
(it's not the voltage regulator... the temp gauge works)
oemoilleaks is offline   Reply With Quote
Old 05-09-2019, 07:31 PM   #2
oemoilleaks
Old 05-09-2019, 07:31 PM   #3
oemoilleaks
Old 05-09-2019, 07:32 PM   #4
oemoilleaks
Old 05-10-2019, 12:07 PM   #5
jwernerny
jwernerny's Avatar
I vaguely remember something about the sender being different or something with the rallye cluster in my '70 145. I do remember I used to fill based on mileage, not not on the gauge because the gauge didn't work.
John Werner
* 1992 944T * 1988 764 GLE V6 * 2002 WRX Wagon (needs motor) * 2006 Honda Odyssey *
jwernerny is offline   Reply With Quote
Old 05-10-2019, 12:09 PM   #6
jwernerny
jwernerny's Avatar
Found this thread about the fuel gauge: https://forums.tbforums.com/showthread.php?t=301665
Old 05-10-2019, 12:36 PM   #7
GT gauges use stock senders. It's only the Rallye gauges that require special senders.
Contact Roger. I think he was able to modify the stock fuel and temp gauges to repair the GT gauges.
Old 05-10-2019, 03:43 PM   #8
oemoilleaks
The senders aren't the problem. The gauge is dead at this point.
Unfortunately, this is a Roger cluster. I'd send it back to him but only if he would undo the "upgrades" he's done... the LED ring lighting is too bright and honestly pretty annoying.
Old 05-10-2019, 04:03 PM   #9
71142volvo
71142volvo's Avatar
You have to get your fuel sender re-calibrated. It's NOT your gauge. I sent mine to Tri-Starr in upstate NY. Also, if you turn the dial down on the dash, you can adjust the brightness of the lighting.
Congrats on the dash, Roger does a great job!
71142volvo is offline   Reply With Quote
Old 05-13-2019, 02:50 PM   #10
oemoilleaks
The fuel sender shouldn't be an issue. I had a voltage regulator go bad and short the gauge. since this is the GT cluster all the sending units are the exact same as the stock cluster...
I thought you only had to change stuff for the RALLYE cluster.
Old 05-14-2019, 02:24 PM   #11
71142volvo
71142volvo's Avatar
I thought I changed with the GT cluster.....I could be thinking about my Rallye cluster
Old 05-14-2019, 02:29 PM   #12
Tfrasca
Tfrasca's Avatar
My GT fuel gauge worked with my stock early 142 sender.
Old 05-14-2019, 10:49 PM   #13
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
Best to eliminate the low hanging fruit first. Check the resistance of the sender before you tear apart the cluster, it should be high resistance when empty and very low resistance when full. 282ohm +/-48 empty and 40ohm+/- 5 full
I attached the pages on this from the 140 greenbook
File Type: pdf 140 greenbook fuel gauge_compressed (1).pdf (121.2 KB, 1 views)
