Old 05-10-2019, 02:01 AM   #1
xDread92x
xDread92x's Avatar
Default Volvo 240 Cluster Bulbs Blowing Out
For a while my cluster bulbs have been burned out. Removed two bulbs and they were blown. Had a good spare and placed them in. Turned lights on and nothing happend. Took cluster out and bulbs were blown.
Fuse 16 not blown and in tact. About a year ago my right tail light (which i know is in the wiring of cluster) stopped working. Couldn’t get it to work so took it to a shop and they rigged it up to work but unsure what they did.
Soon after my cluster bulbs quit working. Culprits I believe could
be:
Bulb failure relay, cluster electronic board somehow, or possibly wiring issue somewhere causing bulbs to blow but not fuse.
Thanks
Image and video hosting by TinyPic
xDread92x is offline   Reply With Quote
Old 05-10-2019, 02:18 AM   #2
300+hp on the shelf club
If the shop bypassed the bulb out relay they may have affected the cluster bulb wiring somehow? Just a guess. The light wiring for the center stack is also on the cluster circuit so if that wiring is wrong it could affect the cluster bulbs. A bulb can also burn out if it gets overheated. Are you sure you're installing the correct wattage?
Old 05-10-2019, 08:07 AM   #3
57plymouth
57plymouth's Avatar
Time to hit ebay for some chinesium LED bulbs.
Sven, the 1991 245
Old 05-10-2019, 08:19 AM   #4
cleanflametrap
cleanflametrap's Avatar
Originally Posted by xDread92x View Post
... Had a good spare and placed them in. ...
Assuming you're dealing with an 86-93.
Nothing external made your bulbs quit. Just age. The filaments are so brittle, just removing and installing them will break them. My pillage of pnp bulbs yielded this mess of duds, which probably were all working when the car was scrapped.
You wonder why I kept them, I suppose. I figured I could find 3W capsules to resistance weld into the bases, but could only find 5W halogen capsules. Many have successfully found LED replacements for these, but I can't offer any experience with that.
-Art
Old 05-10-2019, 08:20 AM   #5
cleanflametrap
25% more?
Old 05-10-2019, 10:21 AM   #6
xDread92x
xDread92x's Avatar
So is it really just the bulbs?
Even if i order some more, can i expect those to blow too?
Whats proper installment for the bulbs? Can they be installed incorrectly?
Old 05-10-2019, 10:48 AM   #7
cleanflametrap
I think you will be fine if you use new bulbs, which I believe may have come down in price from historical levels. Halogen bulbs don't need to be oriented in any special direction, just insert and twist. I imagine the LED replacements have to be put in with the polarity correct unless they've become more user-friendly these days.
Old 05-10-2019, 02:01 PM   #8
xDread92x
xDread92x's Avatar
Okay well ill give some new bulbs a try
Old 05-10-2019, 02:43 PM   #9
57plymouth
57plymouth's Avatar
Originally Posted by cleanflametrap View Post
25% more?
I replaced every bulb on my car except the head light bulbs and the bulbs inside the toggle switches for under $50.
Old 05-10-2019, 03:44 PM   #10
cleanflametrap
After midnight today, maybe under $62.50.
But your figure surprises me because I'd swear I haven't spent $50 on non-headlamps of any type in 20 years on 12 cars. Better half shakes her head like this and mutters something about cheap...
(more pnp plunder)
Old 05-17-2019, 01:14 AM   #11
xDread92x
xDread92x's Avatar
Hey All,
So I placed the new bulbs in. Its doing the same thing it did when I bought the car. The left bulb over clock and speedo works. But the bulb over the fuel and temp gauge doesn’t come on immediately. If i smack that side of the dash the bulb comes on sometimes.
What could this be?
Old 05-17-2019, 08:18 AM   #12
57plymouth
57plymouth's Avatar
Probably the contacts on the bulb are not solid to the contacts on the circuit board on the cluster.
Old 05-17-2019, 12:12 PM   #13
xDread92x
xDread92x's Avatar
The bulbs turned in pretty tight so they are not loose. Maybe pressing the connectors closer together may help?
Could it be the actual circuit board on the cluster?
Thanks
Old 05-17-2019, 12:20 PM   #14
xDread92x
xDread92x's Avatar
Thanks
Old 05-17-2019, 03:01 PM   #15
cleanflametrap
Thanks
Are you using truly new bulbs? An old bulb will have a break in the filament that sometimes makes contact and lights. You probably have experienced that with headlights before.
If you are indeed using fresh bulbs, then the possibility the loose connection is on the circuit board somewhere is best checked by removing the cluster to the bench and powering the lamps with 12V where you can wiggle things, and trace the circuit to locate the culprit. Here's one way to get power to the lamps on the workbench:
(from some notes on replacing an odometer gear)
Knowing how fragile the halogen lamps are, I made sure they lighted before re-assembling the cluster. The power is applied to the lamp's contact and ground was made to the 10 ohm resistor at the top left. Don't be confused by the LED, its lead just provided a handy transition from alligator clip to thin probe.
Old 05-18-2019, 12:25 PM   #16
xDread92x
xDread92x's Avatar
Ok i will take look at the board and see if i can get it working
Old 05-18-2019, 10:38 PM   #17
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
Are all of the dash grounds hooked up? Bad grounds are the often the cause of unnecessarily firing the parts cannon.
VP Autoparts may have new, known good bulbs in stock, worth checking.
Old 05-19-2019, 02:57 AM   #18
xDread92x
xDread92x's Avatar
Yea i have been through the dash multiple times everything seems normal. It was like this when i bought the car. I havent had time to mess with it again but im going to check the circuit board it may just be old or damaged. Corrosion maybe?
