Old 05-11-2019, 10:26 PM   #1
xmlhack
xmlhack's Avatar
Default Fuel Pump Pressure - 1972 142E
Anybody know the fuel pressure requirement for the b20f. My car is a 1972 142e
71 Volvo 144S - The original
75 Volvo 242DL - College beater
92 Volvo 940GL - Workhorse
95 Volvo 855 - My first HPT
06 Volvo XC90 - Daughter’s Truck
98 BMW 540i - Commuter
72 Volvo 142E - Current project
xmlhack is offline   Reply With Quote
Old 05-11-2019, 10:34 PM   #2
Old 05-12-2019, 08:15 AM   #3
xmlhack
xmlhack's Avatar
TY. Mine was built in April 72.
I know the pressure is regulated but What pump will work thats not $450?
Old 05-12-2019, 02:33 PM   #4
planetman
planetman's Avatar
There are several cheap in price and cheap in quality universal fuel pumps you can buy from any auto parts store for less than $100.00 but I won't sell them to my customers, You will have modify the mounting and wiring to make them work and on sometimes, you need to add an inline fuel pressure check valve.
There are higher quality universal pumps and they need the same mods to make them fit and those cost closer to $200.00.
I recently started selling a copy of the original Bosch fuel pump that Datsun/Nissan still makes for their early copy of D-jet and it is almost an identical copy and it can be installed without cutting or modifying the original wires. You simply use a small tool to bend the retaining tabs on the female blade connectors and they slip out of the plastic insulator without cutting and you plug the wires directly onto the connections making sure you get the polarity correct. The new Nissan pumps cost around $335.00.
Eric
Torrance, CA 90502
planetman is online now   Reply With Quote
