Old 05-11-2019, 11:38 PM   #1
hessam69
Default Power door lock unlocks but doesn't lock
Hi,
On my 940, the left rear door central locking system unlocks properly, but it doesn't lock. I have tried lubricating the moving parts, and I can feel the motor trying to lock but not quite enough to move enough to completely lock. All other doors lock and unlock fine.
I have connected the lock motor up to a battery and it locks and unlocks perfectly.
Could there possibly be a wiring problem?
Thanks
90 240
90 240
90 240 wagon
91 240 wagon
90 240 parts car (parts for sale)
86 240 parts car (parts for sale)
84 240 parts car (parts for sale)
92 940 parts car (parts for sale)
91 940 parts car (parts for sale)
79 244
74 164E
Old 05-12-2019, 03:40 PM   #2
300+hp on the shelf club
I would try checking the wiring inside the door panel going into the car through the rubber accordion wiring tubing. If the motor is working. Double check the linkage and make sure it's easy to move and has a proper movement to provide the unlock.
I think the right front door uses the same motor so you could also swap and see if the problem follows the motor.
