Old 05-12-2019, 06:43 AM   #1
smoothdurban
I do my own stunts
smoothdurban's Avatar
Default 15G Idle ring.
Hey.
I just finished a 15G swap on my B230FT and I noticed a ringing type sound and idle.
The turbo is used, I bought it from a member here a few months back. I know on the hot side of the turbo there is a cup or sorts that separates the turbine wheel from the cartridge. Is it possible this is rattling around. Perhaps I didn`t clamp the hot side housing to the cartridge sufficiently when I reclocked it.
when I blip the throttle it goes away and returns when the engine speed returns to idle.
1983 242 Turbo w m46 142,000 km's B230FT LH2.4
1991 240 Wagon w m47 Winter DD 440,000 km's!
2005 S40i Sedan w M56 Summer DD with 140,000 km's
Old 05-12-2019, 10:32 AM   #2
dbarton
Dejected by Volvo
dbarton's Avatar
Are you certain where the sound is coming from precisely? Try using a length of hose or tubing up to your ear and try to find precisely where the noise is loudest.
Dave
Old 05-12-2019, 11:48 AM   #3
iHateVolvoPeople
Sounds like you got a junk turbo like the past 3 turbos I’ve bought off of TB.
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
Past:
80' 242gt m46
88' 245T m47
92' 945T AW71
94' 945T AW71
Old 05-12-2019, 01:06 PM   #4
smoothdurban
I do my own stunts
Dave
I`ll check with a stethoscope next time I run it, it seems pretty certain its coming from the turbo.
Originally Posted by iHateVolvoPeople View Post
Sounds like you got a junk turbo like the past 3 turbos Iíve bought off of TB.
Yikes! Last 3? If that`s the case any recommendations on where to buy a good cartridge?
Old 05-12-2019, 06:33 PM   #5
Mbeas96
Mbeas96's Avatar
I went to a jy and got my 16t. You can examine the shaft play before you pull it! And usually a decent amount cheaper too
Old 05-12-2019, 07:23 PM   #6
smoothdurban
I do my own stunts
Thats always an option but I am ok with buying something new (and paying for it) I just dont trust any of the ebay $168 cartridge specials.
I am about a 2.5 hour drive from Cherry Turbos in St. Thomas so I dropped them a line what I am looking for. I am curious if there are an other reputable online sources.
Old 05-12-2019, 09:30 PM   #7
Mbeas96
Mbeas96's Avatar
Yeah I wouldn't either for 168 bucks lol. There was a thread on here not long ago that someone had bought just that from ebay and it was spewing oil everywhere within 500 miles
Old 05-13-2019, 10:02 AM   #8
iHateVolvoPeople
I also rebuilt a blown 15g from here with a cheap $30 kit (huge mistake presumably) and then paid another $60 to have it ‘balanced’ and when i went to pick up the turbo from the balance shop it was still disassembled. It had small divets: one one the compressor wheel and one on the turbine wheel. Guy at the shop just told me to ‘line them up by eye and tighten it up’
In hindsight, you don’t need to balance a factory turbo that you rebuilt since the compressor wheel and turbine wheel (with shaft) are balanced separately from the factory. That’s what i was told at least. I should’ve just bought a better rebuild kit and rebuilt it and let it be. My $30 rebuild lasted 1500 miles.
Also, people should stop selling junk turbos on here.
Old 05-13-2019, 10:12 AM   #9
drift256
Default 15g
I've got a 15g that makes a ringing sound on the cup with I spin the exhaust wheel. I only noticed it when I took the housing off to port it. I'm hoping it stops when I reassemble it.
drift256 is offline   Reply With Quote
Old 05-13-2019, 10:13 AM   #10
propav8r
F*ck Edgar
propav8r's Avatar
Did you take it apart? A compressor or turbine fin brushing on their respective housing might make the noise you're describing.
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 05-13-2019, 01:26 PM   #11
Jack
junkman
Jack's Avatar
Rebuild kits are cheap and easy to install
Edit; you’re doing it wrong
Donít bother, I would literally rather throw them away than give you the pleasure. I will never sell to you.
Old 05-13-2019, 01:37 PM   #12
300+hp on the shelf club
I've bought my parts for a rebuild from Gpop shop. Wasn't a cheap kit but wasn't over $100 either. Another choice they provide is a chra for exchange.
Old 05-13-2019, 02:04 PM   #13
iHateVolvoPeople
Edit; youíre doing it wrong
I took extra caution as to do it properly, and followed a rather in depth video. It was just a **** rebuild kit.
Old 05-13-2019, 02:22 PM   #14
smoothdurban
I do my own stunts
This is the sound
https://youtu.be/xyclA81HXHI
Old 05-13-2019, 04:04 PM   #15
Fa182
Stage 1
Fa182's Avatar
Sounds like the wheel is scraping? I would take the intake hose off and see / feel / hear if it's scraping.
It could be that the hot and cold side are not perfectly aligned when you tightened the clamp.
Old 05-13-2019, 04:11 PM   #16
Mbeas96
Mbeas96's Avatar
A rebuild kit for 100 bucks and a whole chra assembly for 100 bucks is a different story lol
I'd go for the kit and do it yourself rather than buying a cheap center cartridge
Old 05-13-2019, 04:51 PM   #17
smoothdurban
I do my own stunts
I checked the compressor side and it is not scraping and spins freely.
I will pull the turbo and leave the turbine housing attached to the manifold and hopefully some more will be revealed.
Old 05-14-2019, 03:09 AM   #18
Jack
junkman
Jack's Avatar
Carbon buildup
Old 05-14-2019, 07:41 AM   #19
iHateVolvoPeople
Carbon buildup
I’ve seen this too. Lots of buildup on the turbine backing plate causing the wheel to rub. You can pop it off and wire wheel it.
Old 05-14-2019, 12:30 PM   #20
Jack
junkman
Jack's Avatar
you cant even rebuild them. Best for you to get a golf
at this point this turbo is probably crap
Old 05-17-2019, 10:13 AM   #21
smoothdurban
I do my own stunts
Ok so i finally got around to removing the turbo from the turbine housing and I didn't find a smoking gun. However on the plus side the turbine blades were not in contact with anything.
After talking to Herman at Cherry turbos he recommend the mating surfaces between turbine housing and the CHRA be sand blasted, to ensure you get as clean / tight as a seal between these components as possible.
Not wanted to shoot a bunch of sand around my engine a settled for a dremel with a wire wheel.
After cleaning the surface as best I could I reassembled everything and everything is quiet as it should be.
I am pretty certain that noise was the heat shield wasn't seated properly and it was rattling around.
Needless to say I will not be in the market for a 19T just yet. . . unless someone has a screaming deal.
Cheers!
Old 05-18-2019, 07:29 AM   #22
dbarton
Dejected by Volvo
dbarton's Avatar
Wait! That ringing is supposed to be there. It's critical to proper spool.
Did I get to you in time?
Old 05-18-2019, 08:45 AM   #23
smoothdurban
I do my own stunts
Too late its blown :(
Do you sell those electric turbos Dave?
