Old 05-16-2019, 12:09 PM   #1
xDread92x
xDread92x's Avatar
Default AC Compressor Question
I was doing some research and it seemed many say the rebuilt ac compressors are junk. I guess mainly because they are rebuilt poorly. They have a 1 year warranty which helps. I cant afford a new one by any means and I'm on the verge of an AC rebuild in the 240.
Thoughts?
Image and video hosting by TinyPic
xDread92x is offline   Reply With Quote
Old 05-16-2019, 02:32 PM   #2
I've never used a rebuitl a/c compressor of the rotary type. But if the company will warranty their work and the warranty replacement isn't a horrible process. Then that may be worth a try. I bought a new one when I redid the a/c on my 93. It was only $265 for a new one that was a bigger stronger compressor than original.
What refrigerant you are using matters. If you are going to R134 you are better off getting a new compressor designed to run at the higher pressure. The old R12 compressor used on R134 isn't going to last very long.
Old 05-16-2019, 03:14 PM   #3
xDread92x
xDread92x's Avatar
Yea these refurbished compressors are only R134A compatible so that shouldn't be an issue.
Old 05-16-2019, 03:16 PM   #4
intothelabyrinth
intothelabyrinth's Avatar
What is the problem with the one on the car?
1986 245 Auto (RIP)
1986 245 Auto (RIP)
1988 245, M47 (My Daily)
1989 245 Auto California Car
1993 245 Classic (Bro's Daily)
1999 V70 T5 Auto (Girlfriend's Daily)
1988 245 ('93 B230FT project)
Instagram
intothelabyrinth is offline   Reply With Quote
Old 05-17-2019, 12:41 AM   #5
xDread92x
xDread92x's Avatar
Clutch wont spin while belts are running. Pulley spins but clutch doesnt.
No cool air blows out at all
Old 05-18-2019, 06:45 AM   #6
TestPoint
TestPoint's Avatar
Jump the low pressure cutoff switch. It the clutch engages you need Freon. If not, you need a compressor.
Ford V8 Conversion Manual -
Old 05-18-2019, 12:24 PM   #7
xDread92x
xDread92x's Avatar
Is the test wire the one coming from the top front of the compressor with the male end?
