Old 02-12-2013, 02:40 AM   #301
volvobrage
Traded this for some welding with a friend, will shine it up a little bit and maybe use it for something on the car
31.01.13
Cutted out some reinforcementplates for the front suspension, not sure if I will use it tough
volvobrage is offline   Reply With Quote
Old 02-12-2013, 02:43 AM   #302
volvobrage
To boxes in the mail today, this is for the front
And my threadtubings for the front suspension
Also visited the workshop so finished welding the rear fender
Last time this "transision" was never perfect and it bothered me..But now I think it looks good!
Old 02-12-2013, 02:46 AM   #303
volvobrage
Attached the rear fender to the lower quarter panel
Trimmed the edge
Finished welding and grinding under
With the wheel onThe wheelarch looks much better now!
On the other side I will do like this, saves me from one welding/grinding and alot of adjustment with the insert piece..Should have tought about this before
Was not sure what to do about the tires, but I have decided to go for 265/35On the picture its 255/35
Old 02-12-2013, 02:50 AM   #304
volvobrage
Spotted the lower piece here, looks not straight but I will trim the edge on the underside after weldingIts to low no
Spottet the lower quarter panel and trimmed it to fit
Spotted
Cutted the same piece out of the inner wheelhousing on this side also, looks much better!
Was planning to start on the front fenders, but one of the looked a little crocked..After some grinding I found out it was garbage
Old 02-12-2013, 02:59 AM   #305
volvobrage
Got the threds on the front suspensionThe pipe was almost 1mm to small in the inside diameter, but I managde to fit it after alot of grinding
Old 02-12-2013, 03:00 AM   #306
volvobrage
WeldedAlso cut the bracket for brake lines of
Old 02-12-2013, 03:05 AM   #307
volvobrage
Started on this just to have something small to do..Everything looked like the brown part before sanding
Some wounds
Looks like this inside
After splitting
Its lying in a box with whitesprit over the night now
07.02.13
More splitting, found to m4 z-screws
The withesprit did a good job
09.02.13
Finished sanding everything except the "hook"..Hard to capture on cellphone pictures, but it has a cool "flat" surface
Old 02-12-2013, 03:34 AM   #308
2fast242gt
Do you have a cobalt?
what is that??
1983 242dl
*6.0 lq4 swaped* Build thread
Old 02-12-2013, 03:59 AM   #309
volvobrage
Originally Posted by 2fast242gt View Post
what is that??
Its a lid from an old volvo truckWant to use it for something cool, not quite sure what yet..
Have moore bodywork pictures also, will post them later this week
Old 02-12-2013, 04:34 AM   #310
2fast242gt
It could be a good stash place for greenery lol
Old 02-12-2013, 05:04 AM   #311
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
looks like an exhaust flapper ;)
Old 02-12-2013, 07:34 AM   #312
volvobrage
Haha:p One of my friends also tought it was an exhaust flapper
09.02.13
Tested to widened one of the front fenders since I needed new ones anyway(this one is rusted and have been chrased)
15mm in the top, but I think it was little bit to much..Not sure if I will widen the new ones or not, time will show..To fenders from a USA() imported car are on the way = no rust!
Beside from that I think it looks good, but hard to see with this hight and rims in the front
Finished welding the lower quarter panel
Last check with the wheel on
Drilled for welding
Marked for the new piece
While I was waiting for the welding paint to dry I trimmed the lighthousings
Looks strange on the pictures, but I think it looks good in reality
Spotted the new piece
Testing with the wheel again, been on and off "a couple" og times the last month
Nices ending on the lower quarter panel here, need to fix the other one the same
Old 02-12-2013, 07:36 AM   #313
volvobrage
Finished welding the rear fenderBut need to weld it to the lower quarter panel next weekend
Small problem, the lower quarter panel have a smaaaal angel going up in the endIt really bugs me, but nothing to do about it so I just have to live with it
Old 02-12-2013, 09:58 AM   #314
Rectilinear
Longitudinally Mounted
Rectilinear's Avatar
Keep up the great work, it is truly inspiring!
Originally Posted by A Random CL Ad
A Volvo 240 does not have a slow zero to sixty time. Nor a fast one. It reaches sixty precisely when it means to.
Rectilinear is offline   Reply With Quote
Old 02-13-2013, 07:02 PM   #315
AllisonCustoms
AllisonCustoms's Avatar
Great work! I wasn't planning on widening my own car - Until I saw yours.
Jeff - 242 T6
“The bitterness of poor quality remains long after the sweetness of low price is forgotten” – Benjamin Franklin
AllisonCustoms is offline   Reply With Quote
Old 02-19-2013, 02:42 AM   #316
volvobrage
Thaks guys!Your comments are truly inspiring to me!Its nice when people like the modifications I doHope the finish product will look good..
12.02.13
Put the last ballbearing spacer in the lathe today
Finish!
Welded the original hole where the pipe are attached with welding to the spindel and welded the hole I made when drilling out the old welding
Cutted away the brakeline brackets and grinded start-stop on the weldings
Old 02-19-2013, 02:44 AM   #317
volvobrage
Last picture togheter before I press the otherone togheter to
Got this grinded away, so the worst job is done
Started on a intake manifold for a friend, so that took alot of time..Have welded what you see on the picture, need to assemble the plenum and weld that also
Old 02-19-2013, 02:45 AM   #318
volvobrage
Welded on an bungs and plate on the top and bottom of the radiator for a friend
And intercooler - intake pipe for another guy
Old 02-19-2013, 02:51 AM   #319
volvobrage
Got this on friday, brand new cover with brand new lid for the original fog light switch
Welded the rear fender to the lower quarter panel
Cleaned up the edges inside and made ready for the new covers
Welded the innerfender to the outer fender again
Tested a front wheel, 20mm spacer + 6mm washers..Little bit to wide, but I want to go for 20mm laterOnly put the washers on beacause I was to lazy to cut the wheel bolts shorter
Should be enogh space for coilovers here with 20mm spacers also
Neds a bit more lowering
Temporary paint..Good space in the wheelhouse
Finished both the covers for the inner fender
Mounted this so I didnt need to **** my pants when I rolled the car out from the workshopThe downhill outside the workshop is not buildt for lowered cars
Old 02-19-2013, 03:32 AM   #320
Arn02
Arn02's Avatar
Originally Posted by volvobrage View Post
14.02.13
I want to be your friend too! :D
Great progress again. One of my favorite blogs.
Ambitious but rubbish.
The 245 GT
The Euromurican
Arn02 is offline   Reply With Quote
Old 02-22-2013, 08:39 AM   #321
volvobrage
Thanks!!Is really cool you like my project
20.02.13
A friend helped me and ripped my tire of the second rear rim..Have been doing some math and these rims are 18x10" et25..But I have 26mm spacers on the last pictures..So when I one time in the future will order custom rims I could with a 10" wide wheel with et-1
Old 02-23-2013, 07:06 PM   #322
volvobrage
Cutted of the bracket for brakes line on this leg also
Pressed it togheter 30mm
A friend on work fixed this for me!Hope it will look cool on the car
Old 02-23-2013, 07:11 PM   #323
volvobrage
Drilled and welding paint
Welded on
Grinded..Think the "marks" on the plate looked cool after mounting!
Trimmed the edge on the lower quarter panel
Spotted the outer fender for good
Temporary paint
Fixed the angle a little bit here, looks better now i think
GOing to use this after all, think the cut is good enough to use it even tough it was cut in a hurry
Cut here
And here
After a little knocking I got the fender on..I hope that it will stay right after I weld the splits I made after I weld it while the fender is in press
Old 02-23-2013, 10:13 PM   #324
FunkyStankyChicken
Rad Panda
FunkyStankyChicken's Avatar
Love it, keep up the great work!
‘02 V70xc
‘96 F350
‘93 525it
‘88 325is
‘84 533i
‘79 242
FunkyStankyChicken is offline   Reply With Quote
Old 02-24-2013, 06:10 AM   #325
Dirk242
+1. Good thread.
'98 Volvo V70
Dirk242 is offline   Reply With Quote
