What is the best tire size for a lowered (front springs cut) 242 Turbo that will not rub with virgo rims, 205 / 55 / 15 or stock ?
205 55 or 205 50. You will like the gearing better with the 205 55 for a turbo application but you have much better tire choices in 205 50.
Why would the gearing be better for a turbo with 55? I'd rather run the shorter tire to effectively have shorter gearing and get into boost quicker in first gear.
Why would the gea0ring be better for a turbo with 55? I'd rather run the shorter tire to effectively have shorter gearing and get into boost quicker in first gear.
how much shorter can 1st get
True, its been a long time since I've had an M46. With the T5 and 3.91 rears that was a sweet combo. I would have liked 4.10 gears even
-and since I dont really give a **** about AutoX, getting into boost as quickly as possible was always my goal. I can see the point though if thats what makes your willy stiff.
Hence the oversized turbo? 3.91, M46, and 205/50 isn't going to do much in 1st gear. It should boil the tires if you're making a little bit of power, which makes getting into boost faster kinda pointless, right?...getting into boost as quickly as possible was always my goal.
Think I will go with the 205 55's. All good info from all, I appreciate it !205 55 or 205 50. You will like the gearing better with the 205 55 for a turbo application but you have much better tire choices in 205 50.
Daaaaaaaaaaaaaaaaamn, that's a LOW profile tire...i dont see any reason why a 205/55/15 wont fit. me & a buddy are in the process of building a 240 wagon that has been slammed 7 we plan on putting 205/15's on it
