Closed Thread
Old 05-17-2010, 05:35 PM   #576
stylngle2003
stylngle2003's Avatar
this is so much win
225s versus 275s
-Billy
1990 Mazda Miata (track toy)
stylngle2003 is offline
Old 05-17-2010, 05:39 PM   #577
doucheNozzle
doucheNozzle's Avatar
Is that civic towery's DD?
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
doucheNozzle is offline
Old 05-17-2010, 05:40 PM   #578
stylngle2003
no, i was trying to show the relationship between 225 and 275 tires, and how awesomely wide they are
Old 05-17-2010, 05:46 PM   #579
towerymt
the real Towery
towerymt's Avatar
Was hoping to find some 15x10 27lb aluminum off-roading wheels on ebay, but no luck finding them in 5x4.25" so far.
towerymt is offline
Old 05-17-2010, 05:47 PM   #580
towerymt
the real Towery
towerymt's Avatar
I think these are 10"s but I have to ask him to be sure.
towerymt is offline
Old 05-17-2010, 06:25 PM   #581
You see these?
http://www.summitracing.com/parts/CL...7542/?rtype=10
15x9. 6.5 back space aluminum.. 200bucks those are 13lbs each...... w0000000000000000000000000000t
The 15x10's they have listed are 14 lbs each...
http://centerlinewheels.com/wheels_f...=364&size=i_15 x 10
For flat hub wheels like that might be easy to drill another pattern
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
blkaplan is offline
Old 05-17-2010, 06:27 PM   #582
MrBill
fige=500Dollar Mistake
MrBill's Avatar
some guy at work is throwing away chevy 15x7 wheels from his dune buggy.
They are awesome and might include tires. do you want
Someone say crazy rays?
MrBill is offline
Old 05-17-2010, 06:43 PM   #583
towerymt
the real Towery
towerymt's Avatar
Originally Posted by blkaplan View Post
You see these?
Should go good down the strip, but will they hold up to autocross?
eww, no. My dad has (2) 13x6 Corvair wheels and (2) 15x7 Camaro wheels that would fit my wheel adapters. The 15x7 is HEAVY like a truck wheel. 13" is LOL. He used adapters to mount them to a 65 Beetle 35yr ago.
towerymt is offline
Old 05-17-2010, 06:53 PM   #584
Listed as street & strip. Only 1500 lb load rating. Which is close on your car but should be ok. Might call and ask them? Or just guinea pig it up
blkaplan is offline
Old 05-17-2010, 07:24 PM   #585
towerymt
the real Towery
towerymt's Avatar
No, they're for "steet and drag". I'm not driving on the 'steet' and I'm not drag racing. Maybe "steet and drag" means ProSolo?
towerymt is offline
Old 05-17-2010, 07:32 PM   #586
maybe "steet and drag" means prosolo?
yes
blkaplan is offline
Old 05-17-2010, 07:34 PM   #587
towerymt
the real Towery
towerymt's Avatar
yes
They're fine for the launch, but all the bolts pop when I make the first turn? Hmm...
towerymt is offline
Old 05-17-2010, 07:36 PM   #588
morganpartee
Simply JB weld all suspected weak spots.
Almost out of the Volvo game!
2011 Ford Ranger
1997 Miata, Supercharged
2002 Suzuki DRZ-400S
2013 Yamaha FZ6R
morganpartee is offline
Old 05-17-2010, 07:42 PM   #589
keep removing weight from the car until its light enough for them.
blkaplan is offline
Old 05-17-2010, 11:06 PM   #590
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
at both solutions
DNAsEqUeNcE is offline
Old 05-18-2010, 02:14 AM   #591
klr142
Turbo, what?
klr142's Avatar
I haven't mounted these wheels on anything yet, but they are BBS 16x8.
Wanna trade for some LMs?
klr142 is offline
Old 05-18-2010, 01:05 PM   #592
towerymt
the real Towery
towerymt's Avatar
Only if they're 15x10 LMs.
Test drove it around town today, stopped at Autozone for some power steering fluid, and then a couple blocks from home the clutch cable finally popped on the 1-2 shift...hmm, it's in 2nd gear, so I drove it home with no drama. As I came around the last corner I accelerated a little to slide it out of gear, and rolled it back into its parking spot as if nothing was wrong.
Picking up an OEM cable tonight and will swap it in the morning if I can find the big iron block that fits over the end of the cable. I went back to the scene and found the rubber block that goes in the end of the fork, but I couldn't find the metal retaining washer. I certainly heard the ringing sound as it ejected out the back of the car, though. The Spec Stg3+ PP gives quite the heavy pedal...when the cable isn't broken.
towerymt is offline
Old 05-18-2010, 01:25 PM   #593
Wagner
Tbricks MIG Welding Champion
Wagner's Avatar
Not going to a hydro clutch, because it's too much of a hassle to get the parts, or because it might weight a bit more?
The blue top mounts look nice. Are they some universal pieces, or are they designed for the 240? Do the holes on the perimeter allow for combined camber/caster adjustment?
Cops pulled me over. Papers, they said. Scissors, i replied. Still i did not win. Go figure.
Wagner is offline
Old 05-18-2010, 02:31 PM   #594
towerymt
the real Towery
towerymt's Avatar
I would consider a hydraulic clutch. The pedal is quite heavy now, but not bad enough that I feel I must change it. I don't drive the car in traffic much, but when I do, I feel it in my left leg.
I've had the car since 132k miles and it has 247k now and I've never changed the cable. I doubt it was replaced by the previous owners based on the maint. history. I had already bought a new cable with plans to change it when I did the swap to the heavy pressure plate, but I didn't. So I was going to do it when I did the T5 swap (maybe next month). I knew it was likely to break, being original and seeing about twice the force as stock.
You can buy the camber plates from Tom Smith in Florida: http://forums.turbobricks.com/showthread.php?t=201500
The holes don't allow for infinite adjustment, but from any of the configurations that will line up with the holes in the strut tower, adjustments can be made to camber by sliding it in or out along the factory slots in the strut tower. It's a one piece design, so there are some limitations, but it's very light and the bearings are nice. To fit the bearings in the plate, the plate must be heated. I did the first one in the oven and it was tricky. We did the second one with a torch and it was much easier.
towerymt is offline
Old 05-19-2010, 01:48 PM   #595
towerymt
the real Towery
towerymt's Avatar
Replaced the clutch cable. Clevis pin at the pedal was worn halfway through, so I looked around for a pin and forgot I had one in a spare pedal set. Instead, I used a #10 x 2-1/2 machine screw. Cut off the end to just use the smooth section near the head, drilled a 1/16" hole, and it works fine for now.
Since the end of the old cable broke off, I lost the rubber piece that goes over the end of the cable and I lost the metal washer that slips over the end of the cable. I went back and found the rubber piece, but couldn't find the washer. So now I'm using a sway bar endlink cup washer that's about 3/16" thick. I cut a notch in the side and it fits the end of the cable. Works for now til I get the right part that was on back order.
Ready for Carlisle? Almost...
towerymt is offline
Old 05-19-2010, 03:10 PM   #596
WeezilUSA
WeezilUSA's Avatar
I need to re-do my clutch cable I think... Its looking a little suspect on the cable itself... but I have never had any of these rubber things or washers you speak of... available from the dealership?
1983 242 ICSCC GP Race Car
WeezilUSA is offline
Old 05-19-2010, 05:44 PM   #597
towerymt
the real Towery
towerymt's Avatar
You have the end of the cable hooked onto the clutch fork? Yeah, not supposed to be that way. There's a piece of rubber, almost cube shaped but more rectangular and it has a hole in the center. Press it over the ball-end of the cable. Then pull out enough slack on the cable by adjusting it, or use big channel locks to pinch the clutch fork to compress it and then slip the metal washer over the cable. The slot is only wide enough for the cable, not the steel shaft at the end of the cable. The mid 80s cars had a big C shaped block of cast iron that had the hole in the center and a slot to slide it over the cable. At some point they used an even bigger, heavier version, perhaps on the 740. Early 240s just used what is basically a washer with a tapered hole and a slot in the side.
I had one of the C shaped metal blocks, but I may have used it on my daily driver. When I got the car, it just had the end of the cable hooked onto the clutch fork. The factory installation should work better over the long haul because it spreads the load over the entire end of the clutch fork.
towerymt is offline
Old 05-20-2010, 01:18 PM   #598
norcal505
Location: Los Angeles, CA (SGV); Chicago, IL; San Diego, CA; SF Bay Area, CA
mike, can you please ask the owner whether he's on any forums, or what his suspension specs are?
1991 BMW 318i (Old Shell RIP, Now Re-shelled & Reborn)
1983 Peugeot 505 STI
1992 Volvo 245 Euro Delivery
norcal505 is offline
Old 05-20-2010, 01:32 PM   #599
towerymt
the real Towery
towerymt's Avatar
Test drive was a success. After adjusting the new clutch cable, I put a piece of rubber hose over the threaded metal sheathing and tightened 3 small clamps over the hose. This is to keep it from self-adjusting. The pedal feels better than before...it's smoother through the whole range of travel (obviously). Also, pedal effort has been reduced, which I was hoping for based on what Bne experienced.
Swapped the front bars between cars, so the '87 has the 21 now and the DD '92 has the 28. Quite a weight savings there...
Drove the car to work today, too. This car corners like a snake in a rat hole.
towerymt is offline
Old 05-20-2010, 02:28 PM   #600
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
That means it's good right?
Fake Race Car
Karl Buchka is offline
Closed Thread
