Closed Thread
Old 08-06-2010, 01:44 AM   #901
doucheNozzle
doucheNozzle's Avatar
I probably need more camber on the front, but I need to take temps again.
What are you at right now? -3?
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
doucheNozzle is offline
Old 08-06-2010, 01:46 AM   #902
kahluaTDI
kahluaTDI's Avatar
I agree. Just needs that mad tyte - front camber and some war stripes. And side mirrors not folded in.
Do you ever travel to other regions to play? I'm not sure if there are any close but I would imagine one or two in virginia or baltimore wouldn't be too far away. It's always nice to go somewhere else and get a change in scenery. Especially when you start getting bored of your course designers.
SEO Baby!
Home Inspections in SW Washington
kahluaTDI is offline
Old 08-06-2010, 01:29 PM   #903
I can dial out understeer with more rear spring rate. With the 325lb rear springs, the car had definite oversteer. After lowering the rear and softening the springs, it's probably tending towards understeer, but it really just drove nice. Turns in well and the front grips, but the rear stays in line. On my last run I went off course and then tried to toss the rear out, but the front wouldn't grip enough on the slick sealed asphalt. I want more rotation so I'm bumping the rear springs back to 300 for the next event.
My opinion has been that the rear bar only adds weight. I can't see anything good coming from a rear bar with the rest of my setup. On a near-stock 240, rear bar is fine.
I probably need more camber on the front, but I need to take temps again. Didn't get a chance at the last event, was too busy checking my rear tire rubbage.
I wouldn't dial out the understeer with more rear spring rate. I would dial it out by keeping the front tires on the ground. If you can maintain contact patch on both tires you will get a lot less understeer. Get the front lower, more supported droop travel...
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
blkaplan is offline
Old 08-06-2010, 01:43 PM   #904
adrianpike
adrianpike's Avatar
war stripes war stripes war stripes
I'm looking to buy, PM me if you've got any of it: LS bits, 93 850 bumper, ford 8.8", T5 WC, T56, Mustang IRS
Adrian is omniscient, you will never escape his wrath. - 500dollar744ti
doug was here
adrianpike is offline
Old 08-06-2010, 07:05 PM   #905
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
AND group A spoiler!
DNAsEqUeNcE is offline
Old 08-07-2010, 12:42 PM   #906
towerymt
the real Towery
towerymt's Avatar
A different shot with the rear tire higher in the air, from a different photographer
Lotta sidewall hiding under that fender
towerymt is offline
Old 08-07-2010, 12:54 PM   #907
WeezilUSA
WeezilUSA's Avatar
Don't knock the side mirrors being folded in. I'm a convert
Before the last event we had borrowed a camber gauge and so we weren't guessing on the alignment quite as much. With my camber plate maxed out on the passenger side, It was off the gauge at over -6*... which explained why braking felt a little compromised.
1983 242 ICSCC GP Race Car
WeezilUSA is offline
Old 08-07-2010, 01:10 PM   #908
towerymt
the real Towery
towerymt's Avatar
I'd question the gauge. This was about -5.5 I think, with the super duper long kaplhenke extended drift spec control arms. There was daylight under the outside shoulder of the tire. Horrible idea...
http://www.pbase.com/blkaplan/image/46683974.jpg
towerymt is offline
Old 08-07-2010, 04:06 PM   #909
yea -5.5 was way toooo much
blkaplan is offline
Old 08-08-2010, 03:21 AM   #910
WeezilUSA
WeezilUSA's Avatar
Huh... Well we were all pretty damn drunk when adrian put the gauge on.
Old 08-08-2010, 09:54 AM   #911
towerymt
the real Towery
towerymt's Avatar
How much caster did Adrian have when he measured the camber? Was it varying between positive and negative?
towerymt is offline
Old 08-08-2010, 07:04 PM   #912
towerymt
the real Towery
towerymt's Avatar
Three's company. The helper on top of the tender will keep the tender & main pressed together at full droop so the coupler won't fall out, therefore I've removed the need for zip ties to hold my springs together.
Did some more clearancing...plus added 1/4" spacers between the hub and adapter. The tires won't rub, but they might fall off...just hope Bne is driving when they pop!
towerymt is offline
Old 08-09-2010, 02:13 PM   #913
how does the lug engagement look with the spacers between the hub and adapter?
still have hubcentric engagement?
blkaplan is offline
Old 08-09-2010, 03:03 PM   #914
towerymt
the real Towery
towerymt's Avatar
Still hub-centric. 10.5 turns w/o spacer, 6.5 with spacer. That's just shy of 1/2" engagement, and it was a little over 1/2" before. I thought the rule of thumb was at least as much thread engagement as you have diameter of the fastener? They torqued to 80lb-ft so I hope it's enough. I'll retorque when the tires come off to change them at the autoX. Still need to mount the hoosiers on both sides at the rear and check clearance. Still have to hammer on the drivers side and grind the trailing arm.
One option would be to face the base of the lug holes in the adapter to remove the taper, drill out the hole larger, and use a long shank lugnut that goes into the adapter...similar to what the BBS require. That would give a lot more thread engagement.
towerymt is offline
Old 08-09-2010, 03:16 PM   #915
A class 10 12mm nut is 10mm tall. As long as you can torque it without stripping the threads, it "should" be ok. .5" engagement is probably ample
blkaplan is offline
Old 08-09-2010, 03:56 PM   #916
towerymt
the real Towery
towerymt's Avatar
They're 1/2"x20tpi, but it sounds OK to me too.
towerymt is offline
Old 08-10-2010, 12:40 AM   #917
towerymt
the real Towery
towerymt's Avatar
http://dac.smugmug.com/My-Autocross-...63802240_Hvy4D
towerymt is offline
Old 08-10-2010, 12:43 AM   #918
ZVOLVO240
ZVOLVO240's Avatar
What were you doing in that event?
- Will Z
1989 244 DL - - - Beige N/A
1988 245 DL - - - Original owners/Dad's Car
1991 244 Turbo - DEAD
ZVOLVO240 is offline
Old 08-10-2010, 01:26 AM   #919
towerymt
the real Towery
towerymt's Avatar
Winning. Bne was smoking.
Me, driving with reservation
towerymt is offline
Old 08-10-2010, 01:37 AM   #920
ZVOLVO240
ZVOLVO240's Avatar
Well I meant what kind of an event was that? A free for all or something? I ask because rarely do I see tire smoke and your car in the same pics.
Old 08-10-2010, 01:42 AM   #921
towerymt
the real Towery
towerymt's Avatar
Strict autocross with a hint of Bne losing self control and car control all at once. I still don't know how he got so out of shape in a car that's so easy to drive.
towerymt is offline
Old 08-10-2010, 08:24 AM   #922
DNAsEqUeNcE
†John3:16
Can I have a go in the drivers seat at SE?
Old 08-10-2010, 09:10 AM   #923
I thought i already clearly explained this, I went off course earlier after i got to the off camber slalom going way too hot. At that point I wanted to just push the car and go as fast as possible to see what it was like.
blkaplan is offline
Old 08-10-2010, 09:13 AM   #924
I like this one
blkaplan is offline
Old 08-10-2010, 11:14 AM   #925
towerymt
the real Towery
towerymt's Avatar
Sure!
towerymt is offline
Closed Thread
