Closed Thread
Old 08-11-2010, 12:24 PM   #926
towerymt
the real Towery
towerymt's Avatar
Mounted a 275/35/15 on a 15x10.5 BBS E50 flatbase wheel. Pokes a bit too much on the rear adapters, so I'll have to figure out how to mount these. Might pick up the pair of 1" adapters for sale now.
towerymt is offline
Old 08-11-2010, 12:30 PM   #927
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
That is ridiculously hot.
Fake Race Car
Karl Buchka is offline
Old 08-11-2010, 12:33 PM   #928
crap my pants.... they need changing
we need wheel / tire combo weight... stat!
I dont know why anyone would think a 10.5 is too wide for that tire
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
blkaplan is offline
Old 08-11-2010, 01:10 PM   #929
towerymt
the real Towery
towerymt's Avatar
32-35lb via bathroom scale. Hard to say for sure. A new tire is 20lbs, so says Tirerack. This tire is used. Wheel should be 13-16, but I didn't put the wheel together bare to weigh it. I'll do that with the next one.
towerymt is offline
Old 08-11-2010, 01:32 PM   #930
WeezilUSA
WeezilUSA's Avatar
Holy smokes. That. Looks. Awesome.
1983 242 ICSCC GP Race Car
WeezilUSA is offline
Old 08-11-2010, 02:12 PM   #931
amerbritcan
Hnnnnnng
amerbritcan's Avatar
wow. That is a TON of tire.
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
amerbritcan is offline
Old 08-11-2010, 04:24 PM   #932
towerymt
the real Towery
towerymt's Avatar
No, that's less tire. Section width, tread width, height, and weight are less than what I have now. Only the wheel width has increased, from 9.5 to 10.5. These tires are kind of small for my car, so they should benefit from the wheel width. The sidewalls are also really soft. They work well on E30 BMWs on 10"+ wheels, but they tell me the pressure need to be run a bit higher than usual. I use ~32-34psi on my 275/45/16. I'll probably start at 38psi cold on these 15". I used to run up to 41-42psi hot on my 225/45/15 R3S04 to keep the edges from cording because I didn't have a lot of camber.
towerymt is offline
Old 08-11-2010, 05:05 PM   #933
WeezilUSA
WeezilUSA's Avatar
I can't believe how light those are too... My 16" street wheels w/ 225-50's weigh 48lbs via bathroom scale.
Old 08-11-2010, 05:06 PM   #934
your wheels are heavy!
my 18x10.5 lm's with 305 30 18 R comps only weigh 44 lb each
the 15s make them seem like boat anchors though
blkaplan is offline
Old 08-11-2010, 05:09 PM   #935
WeezilUSA
WeezilUSA's Avatar
Perhaps it was the scale? We weighed Kyle's LM's with the 235's on them or whatever they have, and they were right at 50 lbs, as were my Works with 225-40-18.
Old 08-11-2010, 05:14 PM   #936
kyles are 19's so it makes sense they are going to be heavier. Diameter adds alot more weight then width does.
blkaplan is offline
Old 08-11-2010, 05:38 PM   #937
towerymt
the real Towery
towerymt's Avatar
The spun lips on the 15"s are really light. A one piece cast wheel is MUCH thicker in the same area. Plus the spokes are integrated into the lips, so there's more material required.
My C4 Corvette wheels w/V710 tires were about 8lb heavier than the Work wheel w/Hoosier. Same size for each, but the Work is two piece with a really light rim. Tire weight difference was slight...most of it was in the wheel.
10.5" width, ~11.5" overall, 6.5" backspacing = ~19mm offset. Therefore 1" adapters should work well with these on the rear, and I can move the 35mm adapters from the rear to the front. 10.5 (-16)mm front gives 5.1" backspacing. On a 15x7, that's like ET28, so I may need the 5mm spacer on the front...going to be really close. If it's too close, I can just use the 51mm adapters on the front, but I don't want them sticking out more than what is necessary.
towerymt is offline
Old 08-11-2010, 09:22 PM   #938
Stereophile33
Stereophile33's Avatar
Hot
in quasi-retirement...
Stereophile33 is offline
Old 08-11-2010, 09:30 PM   #939
jfleganscca
jfleganscca's Avatar
As a fellow autoxer who is also pretty drunk, I have to say that I am stupid jealous!
Sold Low 'n Slow: 1988 245 DD N/A M47, K&N cone filter, IPD sport springs, IPD Panhard Bar and Torque Rods, IPD Sway Bars(the older gold ones)
Sold 1984 242
2001 V70 2.4 Wrong Wheel Drive
2006 S60 T5 Wrong Wheel Drive
jfleganscca is offline
Old 08-11-2010, 09:54 PM   #940
badvlvo
Bad for Babies
badvlvo's Avatar
I'm liking this, making me more willing to cut the car to squeeze the goods in the fender.
Died at age 35
badvlvo is offline
Old 08-11-2010, 11:14 PM   #941
towerymt
the real Towery
towerymt's Avatar
Front wheel/tire is ~30lbs on the bathroom scale..
Front tire comes in at 17lb on the bathroom scale, so the wheel is around 13lb as a 9", so maybe 14lb at most as a 10.5". I'll get one on an accurate & precise scale before I put a tire on the last one.
towerymt is offline
Old 08-11-2010, 11:22 PM   #942
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Sure!
Saweeeeeeeeet!
DNAsEqUeNcE is offline
Old 08-11-2010, 11:40 PM   #943
towerymt
the real Towery
towerymt's Avatar
Not taking it to SE (duh).
towerymt is offline
Old 08-11-2010, 11:43 PM   #944
DNAsEqUeNcE
†John3:16
Old 08-11-2010, 11:51 PM   #945
kahluaTDI
kahluaTDI's Avatar
Lulz
SEO Baby!
Home Inspections in SW Washington
kahluaTDI is offline
Old 08-12-2010, 12:32 PM   #946
towerymt
the real Towery
towerymt's Avatar
towerymt is offline
Old 08-12-2010, 12:32 PM   #947
Porterhausen
Porterhausen's Avatar
**** hahahaha.
More camber?
Porterhausen is offline
Old 08-12-2010, 12:36 PM   #948
**** ya
blkaplan is offline
Old 08-12-2010, 01:27 PM   #949
towerymt
the real Towery
towerymt's Avatar
Yes, please. I'd like about -3.5 degrees. No idea what I have now. Thinking about adding a spacer between the camber plate and the strut tower to allow the top of the strut to slide under the sheet metal. I'll need to trim the camber plate, but that should do the job.
towerymt is offline
Old 08-12-2010, 02:39 PM   #950
stylngle2003
stylngle2003's Avatar
IiLlLl
-Billy
1990 Mazda Miata (track toy)
stylngle2003 is offline
Closed Thread
