Old 10-18-2013, 06:03 PM   #201
haltechsupra
haltechsupra's Avatar
Move the water pipe after the water pump, either make a hose or weld a different angle on it so its not so close to exhaust manifold. Smallest diameter water pump pulley?
If you had the audacity , to doubt my veracity, and even to insinuate, that I scrupulously prevaricate ,such an insignificant question. Then you must hallucinate before you comprehend.
haltechsupra is offline   Reply With Quote
Old 10-18-2013, 07:09 PM   #202
satanburns1
Satanburns2
satanburns1's Avatar
I forgot to add that its underdrive pulley.. So which OEM WP pulley should i go for?
Originally Posted by zdriver123 View Post
If you want to do it right the first time why the hell you on Turbobricks?
But please, ask me again if I even race bro.
Originally Posted by Justin View Post
Try peeing on your feet - it is what everyone suggest when I had issues with mine and it seemed to go away after a few months of peeing on my feet =)
satanburns1 is offline   Reply With Quote
Old 11-11-2013, 07:32 AM   #203
Joikale
Hi
I have never heard anyone here in Finland who would have popped freeze plugs out by high revving/heat. Do you use proper antifreeze liquids? There's plenty of people who have 500-800 hp engines and still never heard of this issue...
-Joikale-
Joikale is offline   Reply With Quote
Old 11-14-2013, 04:16 PM   #204
Joikale
There's also a thing that proper antifreese liquids do, it won't let things get corroded, bad thing is corrosion fills radiators and that really does not help with cooling. It also lifts boiling point of liquid so there will be less pressure problems.
One guy whom I bought a brass volvo 140 radiator told me that clean radiator filled up with water will completely drain in about 10 secs, if it takes longer it's blocked. And that guy fixes radiators for living...
My friend told that he knows couple of cases of freeze plugs popping out due ****ty antifreeze liquids.
I do not know but I think you're just wasting your money on smaller/bigger pulleys or antifreeze plug kits, just use proper liquids.
Just my thoughts...
-Joikale-
Old 11-14-2013, 05:51 PM   #205
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Pretty sure the guys who have had issues with them popping out (Ken, Kenny, Nathan, etc.) are using proper coolant, as they know better.
RIP
Mark Baldwin aka blue850t5 7/19/18
Nick Fengler aka fengler 8/6/18
74 144 B20
90 745Ti
Old 08-25-2014, 09:30 AM   #206
Mungulz
I popped one out twice.
Both times sitting on the rev limiter sideways in grass, but it DOES happen.
I had about 30-40% Glycol.
Mungulz is offline   Reply With Quote
Old 08-27-2014, 12:29 AM   #207
PromiseRing
Banned
Originally Posted by Karl Buchka View Post
That bolt+washer thing is really ****ing clever. John, du är inte alltid så dum som du luktar.
You are not always as dumb as you smell*
PromiseRing is online now   Reply With Quote
Old 10-31-2014, 07:21 AM   #208
thebrokenmould
thebrokenmould's Avatar
i may be overthinking this but, if block vibration/squirming whatever you want to call it is contributing to this as previously suggested. would it not be worth while trying to strengthen/brace the weaker areas of the block eg around core plug height etc. or by way of vibration dampening? just a thought
Daily - 1997 940lpt celebration wagon - still far too stock - 230whp/406nm@3800rpm - skidpig.
project build - 1978 mgb gt - 4" drop race springs all round, adjustable rear shocks, homebrew custom exhaust, lotus éclat 14x7j alloys - 85whp at 4800rpm with the ignition timing 20deg retarded because I'm an idiot - target 250whp and a sub 9:30 lap @ nurburgring.
thebrokenmould is offline   Reply With Quote
Old 02-22-2015, 10:53 PM   #209
PromiseRing
Banned
I think a lot of vibrations come from the motor not being 'perfectly' balanced. ie the rods, pistons, and even their bolts arent exactly matched in weight.
Old 02-22-2015, 10:55 PM   #210
hockey930
Spending Money On The 760
I still don't belive that to be the problem in the 400 whp range. These things seem to be messing up on the way down from high rpm not on the way up. Also these seems to be out going pressue that finds the weakest link such as heater core or radiator.
85 760t 16Valve, holset turbo, getrag 265, twin disc
06 V70R 6mt, springs, sways, full exhaust, flywheel
hockey930 is offline   Reply With Quote
Old 05-31-2015, 12:58 PM   #211
_Matt_
Originally Posted by 740tankDriver View Post
someone answer the thermostat question.
I hollowed mine out to keep the seal correct, no more moving parts, temp stays way down...v8 guys use restrictive washers which is the same as hollowing out your thermostat but you would still need the rubber seal to accept it
_Matt_ is offline   Reply With Quote
Old 05-31-2015, 01:07 PM   #212
_Matt_
Sound like a bad head, gasket, or broken Pistons that are creating enough pressure to pop the plugs out..I would do a compression check? Lots of pages in this thread I only read a few.. Has it been done yet?
Old 05-31-2015, 01:10 PM   #213
_Matt_
Something is building pressure somewhere it's not supposed to and I bet it is not due to the size of the coolant chAmbers, do you run an e-fan? Is it blowing the correct direction, is the thermostat frozen, how's the heater core is it leaking? There's a lot of e-fans people use without thinking first. I learned my lesson and put the stock fan back on my car. Sure I have lost a lil bit of pep but at what expense? A cool running motor? ....I'll take that any day of the week
Old 07-15-2015, 05:24 PM   #214
Chilm
Double Dutch
Chilm's Avatar
Default Tight
Originally Posted by nathaninwa View Post
Olov.....would take some time to figure which plug had the pressure. When mine failed the first time....I lost the rear 2 on exhaust and forward on the intake side. There were 3 others that were flush with the block and not even with the chamfer. You have a good idea about tapping the block....but from what I'm seeing...the bores are very close to the plugs so you'd almost need to start the hole...the cut the die up and finish tapping. And with my engine installed....a bit more work than what I wanted. And the valve is only 3/8 pipe.....any larger and the solenoids get huge.
I was thinking, is it allways the plug that is at the place where the cilynder wall is at the closest of the outside wall, sort of "tight squish" so to say.
It could explain some issues imho.
Double Dutch - Build and goodies thread ;P
Volvo 945 - Blue Pearl - LPT Polar 2.3 Limited Edition
B230-FK Turbo - 90+ ported - 15G Ported - Airintake
Erland Cox Regrind - Blabla Chips - 3 inch exhaust
MBC on 0.95 - Wasted Spark - Sponsored by my wife
Chilm is offline   Reply With Quote
Old 07-27-2015, 05:01 AM   #215
haltechsupra
Maybe the correct pattern of flow is to be questioned here. A lot of us are too lazy to tackle a leaking heater core, and as a result have Looped the metal feed line from water pump, to the back of the head on cylinder 4 ( 16 valve head or 8v). Maybe, instead, these two lines should be capped off from each other instead of looped? As in the regular operation of a heater valve. Open valve, water goes through heater core, cools a bit, then back to cylinder 4. Closed valve, no flow to cylinder 4. No super heated heat soak in cylinder 4. Infra red temp gun shows anywhere from 10, to 20 degrees hotter from the head above cylinder 4 versus the always lower cylinder 1 With looped heater hose.
Old 07-27-2015, 05:36 AM   #216
Chilm
Double Dutch
Chilm's Avatar
Default Harmonic balancer
About the blown out freeze plugs it is also my believe that in the case of underdrive pulley's this gould be the culprit. That "thing" is a harmonic balancer with the rubber ring in it. When you take that away it can cause abnormal warping or even brake your crankshaft. (Nathan did in the beginning, I think he had an underdrive pulley).
By the way, why do I read so little about drilling the 5 extra water hole's like the Folkracing guy's do (in case of the 8v). It's done in half an hour and when properly (the right hole sizes) the flow is much more "equal".
I did it and it works, no HG and temp problems so far (fingers crossed).
Old 07-27-2015, 02:15 PM   #217
haltechsupra
5 extra holes in the gasket? Metal ones already have them drilled.
Old 07-27-2015, 04:59 PM   #218
Chilm
Double Dutch
Chilm's Avatar
Ha ha lol, no 5 extra holes in the head.
Old 01-13-2016, 09:10 AM   #219
Chris Wilson
There's no way at all water pressure will blow core plugs, anything like the sort of pressure needed would blow the rad apart, or blow a hose. To me it smacks of block squirm. Even the Motorsport Cossie Sierra blocks would pee oil out of the rear main seal if they were true 500 BHP plus motors used on a circuit with a LOT of boost for sustained periods. Block movement could be sufficient to allow core plugs to move, for sure, on weak blocks used well over their design limits. The Sierra blocks always seemed to have tiny cap heads and washers in either opposing pairs or even tripled around the periphery of each core plug, as well as using Loctite hydraulic seal on them. Whether there had been an issue with plugs coming out, or it was just good belt and braces engineering practice I don't know, I ran N/A converted ones with nothing like the same cylinder pressures or torque capability.The few serious turbo Sierra engines used in circuit work here in the UK were always wet at the back end, and I was always told that block squirm, even on the Motorsport heavy duty castings, was the cause.
In the early days of the Cossie Sierra in competition they had head gasket issues and used to pre pressurise the cooling system to try and help them through a race. They ran special rads and hoses to withstand this coolant system pressure, but I never heard of them popping core plugs. I think they may have gone to Reinz gas filled rings later.
Has anyone any photos of a red block band sawed open, width wise and longitudinally? It would be interesting to see where the material was, and was not!
I do this to heads that are new to me, to see where one might hit fresh air or water before porting a good or new casting. For years people in the UK used to say you must not remove the hump in the exhaust ports on Nissan RB26DETT heads, as you'd be into water. I got a scrap head and band sawed it up. The talk was rubbish, the water was miles away. No one had done this before in the UK and people seemed amazed anyone would want to do this. The head was scrap value with a dropped valve.... Go figure!
Chris Wilson is offline   Reply With Quote
Old 01-13-2016, 09:10 AM   #220
Chris Wilson
Old 01-13-2016, 10:42 AM   #221
gashog
gashog's Avatar
My favorite theory is harmonics but coolant pressure can vary 70-80psi from one area of a cooling system to another.
Here comes the BOOST!
gashog is offline   Reply With Quote
Old 01-13-2016, 10:53 AM   #222
Stiggy Pop
Stiggy Pop's Avatar
Skimmed thread to try and find a consensus - but what size water pump pulley are people using in conjunction with an underdrive crank pulley and an electric fan?
John the cap head/washer mod for the freeze plugs is a great simple solution.
'79 242
943 pickup
Old 01-13-2016, 10:58 AM   #223
Chris Wilson
70 to 80 PSI?????
Old 01-13-2016, 11:08 AM   #224
John V, outside agitator
It seems late B230 blocks they went to shallow CUP type plugs rather than the disc "saucer' type..I've seen a bit it a step for the discy saucer type to nestle up aginst, but nothing saying a little Dremel action couldn't remove thatr so the later cup type could be pounded in. and the the allen/washer dealie used.
I also believe it is block squirm..Redblocks are good but they are not the end of the world.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 01-13-2016, 11:51 AM   #225
Chris Wilson
Is there a particular core plug that pops out? I have read of ones near motor mounts popping out in some other engines due to the stress induced during a hard standing start, especially with solid engine mounts. Solid engine mounts with a rubber gearbox mount would be a particularly bad scenario!! I am a firm believer that solid engine mounts in the typically floppy as a wet paper bag saloon car shell are asking for trouble. Engine blocks are not designed, pukka race engines in single seater applications apart, as stressed chassis members.
