#276 |
junkman
![]() not a fan of LED
I like the glow of old bulbs ![]() |
#277 |
![]() What size is the bulb?
#278 |
junkman
#279 |
![]() Approximate diameter in mm? Wedge or bayonet?
#280 |
junkman
![]() wedge.
~9mm wide ~9 mm tall ![]() started to polish up the door sills. well just one before ![]() after about 10 min on a buffer ![]() Clock was gummed up with old oils and some dirt, I had to take it apart and just clean and lube. Basic explanation of this clock. Its a windup mechanism that every few min gets wound up by an actuator. So it uses almost no energy wind up mechanism (red arrow +) moves down toward actuator point as the clock unwinds (yellow -) When it red touches yellow, the actuator (green) pulls the arm (yellow) toward itself pushing the windup mechanism (red) and the clock is wound up for few min ![]() (no scribbles) ![]() the wind up mechanism was constantly activated because clock mechanism was stuck
cleaned everything and now have a working clock
normally the arm gets pushed up more but I had my wiring in the way
#281 |
![]() I believe that's a bayonet style bulb in a holder with a male spade connector.
See do it come out. |
#282 |
junkman
#283 |
![]() No problem.
![]() https://www.bulbtown.com/category_s/1346.htm Or here: https://www.amazon.com/Dark-Green-Co...6STD4RAKMVJYZJ You could also get some green paint and thin it down, then dip bulb until required greenness is obtained. Last edited by Shifted; 01-16-2020 at 04:51 AM.. |
#284 |
Keep it clean...
![]() That clock is just rad, great find by your lady friend. Also, what a difference on the door sill, I love the amount of detail you’re putting in.
Derek 1 Owner - 85k mile 1980 242 Recaro LX Bs - 16" ARE 398s - 25/25 Sway Bars - Bilstein HDs - SuperPro Poly/STS Derlin Bushings - MSD - R Sport Wheel -Project Thread- Follow on IG: @vol242vo |
#285 |
![]() Polishing aluminum back to its former shine is so satisfying. Nice progress, looks great.
#286 |
Bored member
![]() Looks like it's almost ready for another run up the mountains, this time hopefully without losing an axle mount
#287 | |||
junkman
![]() nice I will get that
![]() ![]() Quote:
![]() Just installed a machined timing cover with b23/230 crank seal ![]() did a valve adjustment, regaped the plugs, tuned the carbs, installed a rare Mallory electronic dizzy, runs great again. I need to mount the coil in properly ![]() went for a drive ![]() ![]() ![]() ![]() ![]() ![]() |
#288 |
![]() Looks like an awesome place to cruise the old volvo!
Potential, potential, potential.... 65' 122s (weekend cruiser) http://forums.turbobricks.com/showthread.php?t=308197 67' 122s (Rallyx racer) 82' 242 dl 83' 242 glt (v8 turbo swap project) |
#289 |
junkman
![]() my favorite drive around here.
today I installed a Bosch coil the right way. I still need to clean up the wiring. One of these days I need to take everything out and repaint in there ![]() wired up a windshield washer pump, it even works. I polished the plastic a bit too ![]() |
#290 |
dude
![]() Damn that water is flowing from last time we were there!
#291 |
junkman
#292 |
junkman
![]() I got tired of it droning at 65-70 so I had a shop weld in a magnaflow - omg so much quieter now
looks like I need to tighten the rear swaybar link on driver side ![]() |
#293 |
junkman
![]() going to install these - rear vent windows for sedan
does anyone know if you can make the regular gaskets work with these? ![]() ![]() |
#294 |
![]() Never seen these before, that's interesting. I doubt the regular gasket will have the right provisions for the swivel shaft (for lack of a better term). Have you checked in a parts catalog for an OEM part number ? You can send that P/N to VP and they'll match it up with what they have.
#295 | |
junkman
![]() Quote:
#296 |
The Librarian
![]() Rear door vent windows were only available on B16 Amazons.
The part numbers for the seals are 657925 & 657926 but they're NLA. We must have spoken telepathically (either that or you spoke to my brother). |
#297 |
junkman
#298 |
#299 |
junkman
#300 | |
![]() Quote:
A friend claims he has the ability to reproduce rubber seals, I'll shoot him a text and will let you know what he says. |
