Old 02-13-2020, 10:02 AM   #301
Jack
junkman
Jack's Avatar
Originally Posted by matt b View Post
It's what continues to draw me to Jensen built P1800's eventhough Jensen did a horrible job of assembling them. (sooooooo much lead....)
A friend claims he has the ability to reproduce rubber seals, I'll shoot him a text and will let you know what he says.
Awesome, thanks for doing that. My other option is to send one out to www.steelerubber.com and see if they can match something.
Speaking of early stuff, yesterday I learned that the front engine crossmember and control arms on b16 amazon are the same as the Jensen 1800s
and because new page needs picture. Here is the passenger rear side vent window I pulled.
I love you even more Jack.
Old 02-13-2020, 10:14 AM   #302
JohnMc
JohnMc's Avatar
Heh, I wonder if there was a significant weight difference between the Jensen P1800 and the first 1800S cars.
I've seen *thick* lead from the factory on other types of old British cars. At least it doesn't fail like bondo, even after 50 years.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 02-14-2020, 10:29 AM   #303
matt b
Spoke to my friend who makes seals and he says it's beyond his abilities.
Lead.... When I start a thread on my next P1800, you'll see just how bad it is. Door openings, all around the windshield, etc... My guess is 5-8 lbs or more per car.
Old 02-22-2020, 01:51 AM   #304
Jack
junkman
Jack's Avatar
thanks for asking. I talked to several sources and most people haven't even heard of these. I'm going to send one out and see if I can get something matched
switched over to the early style handles, I been meaning to do this for a while now
Installed driver rear popout, ofcourse I now need new gaskets and and door panel
took it for a drive and some sunset photos. The rear window blows lots of cold air, it's going to be great in the summer. I just love the way it looks
Old 02-22-2020, 02:17 AM   #305
evolvo67
evolvo67's Avatar
Here's another source of rubber seals. They'll send you 3" samples to try. The catalog has good drawings of cross sections, too!
http://www.restorationspecialties.com/
Bored member
Old 02-22-2020, 04:07 PM   #306
Shifted
Shifted's Avatar
If the inner panel trim is at all salvageable (even temporarily) peel it off and use the rotted fiberboard as a template to cut a new one. Reattach trim, wait for something better.
People just aren't smart.
Doing something because you enjoy it is a must in life.
Originally Posted by ME II View Post
Without mistakes there is no learning.
"The table is tilted folks, the game is rigged. And nobody seems to notice, nobody seems to care..." -- George Carlin
Shifted is offline   Reply With Quote
Old 02-23-2020, 11:35 PM   #307
Jack
junkman
Jack's Avatar
sweet i'll check them out
ehh new ones are $93 each and super nice. Will just order some
and because pictures - I love late winder and spring around here. The blossoms are super early because no rain... will probably be terrible for farmers
Old 02-24-2020, 08:08 PM   #308
R32RennSport
Outlaw Amazonian
R32RennSport's Avatar
Looking good! I'm really digging the wheel/tire combo. Classy rig.
Steven
1966 Outlaw Volvo Amazon, 2004 VW R32 Golf
R32RennSport is offline   Reply With Quote
Old 03-18-2020, 11:25 AM   #309
Unqualified
Great build, and fantastic work trying to put everything back to the way it should be. Just got done reading the entire thread, bravo!
Unqualified is offline   Reply With Quote
Old 04-10-2020, 01:18 AM   #310
Jack
junkman
Jack's Avatar
Thank you both.
I have been busy working on other cars and doing some random remodeling so I haven't made time to work on this car in a while
I finally got around to rebuilding the rear seat bottom. Car came to me with a coupe rear seat bottom - they are wider and the structure is entirely different. Please keep in mind that because I didn't yet order new rear seat covers, I used the old coupe cover, with old foam... TEMPORARY PERMANENT
It's surprising how hard the sedan rear bottoms are to find.
One on left was completely falling apart, one on right was full of rat ****
both sides are exactly the same
made the center part out of some home remodel leftovers
glued carpet on where the springs sit - factory used some soft stuff similar to what you would put under a residential carpet. I figured this was stronger
Then I started to staple away, hard to get to the center springs. Factory also used staples. I recreated the gap at the bottom, both of my seats had it, maybe for fabric to have a place to fit
There's 3-4 springs on the side that I could not get with my stapler, I just used cable hold downs. looks like **** but it's plenty strong, plus it's what I had on hand.
test fitting - success
Then came the temp job, used a towel instead of horsehair, and reused the coupe cover but tucked it in on the sides. Looks like crap but at least the seat functions for now.
does anyone know where I can get the rubber piece that goes around the seat bottom ?
I also started to working on a spare nose piece I have. Someone took a mid model one and added tabs (poorly) to make the late model grill fit
I got it sand blasted
minor dent and the TERRIFIC job by previous owner
PO also added a drain hole, theres some minor rust spots on bottom corner
after primer I cut the tabs off and welded the holes, straightened out a few spots also
quick primer before bondo
bondo time
left it at this; I need to go back and skim it again
Old 04-10-2020, 01:24 AM   #311
James M
Bored member
James M's Avatar
Garage door weatherstripping
Old 04-10-2020, 01:25 AM   #312
Jack
junkman
Jack's Avatar
get out Jimmy!..not even close
you can see kind of how it looks - black piece on right
Old 04-10-2020, 01:50 AM   #313
James M
Bored member
James M's Avatar
Photo of one in action so I can pretend to be helpful
Old 04-10-2020, 10:59 AM   #314
matt b
I may have that piece here, I think it's been moved 49 times around the garage. Is it the same as the 2 door version ?
Old 04-10-2020, 01:04 PM   #315
evolvo67
evolvo67's Avatar
Actually having drain holes will keep the water from just laying in the bottom of the nose piece and rotting, because it will drain out. I drilled three holes in mine right at the very lowest point, works well. JMO
Old 04-10-2020, 02:12 PM   #316
sspony
sspony's Avatar
I drilled a hole in the very center on the bottom at the lowest point of mine as well. I noticed it kept filling with water, not anymore!
Potential, potential, potential....
65' 122s (weekend cruiser) http://forums.turbobricks.com/showthread.php?t=308197
67' 122s (Rallyx racer)
82' 242 dl
83' 242 glt (v8 turbo swap project)
sspony is offline   Reply With Quote
Old 04-10-2020, 07:39 PM   #317
Jack
junkman
Jack's Avatar
thank you for mailing it to me
but there's already a factory drain hole ?
IN OTHER NEWS I MADE IT TO THE IPD CONTEST. I guess starting a thread paid off
my entry. cast your votes https://www.surveymonkey.com/r/CZHMZSZ
Old 04-11-2020, 01:39 PM   #318
Duder
Comes with a free Frogurt
Duder's Avatar
Hoopty With Sunset Plates
...new REM song title maybe
Old 04-12-2020, 02:30 AM   #319
Jack
junkman
Jack's Avatar
Nice
today got headlight buckets and heater box powdercoated
the springs to adjust are a huge pain to install, I wonder how they did it at the factory. Took me forever to install them correctly
adjustment bolts, cleaned - you can see a dirty one
these are the springs - make sure they are all facing this way
done
heater box
what glue/adhesive do you use to secure all the heater box gaskets ?
Old 04-12-2020, 12:08 PM   #320
matt b
Same putty you use for the fenders.
RV Butyl tape, it's $10 for a roll that may be enough for the 55 heater boxes you now own.
Old 04-12-2020, 01:12 PM   #321
Jack
junkman
Jack's Avatar
That part I got but for the little vents in the boxes ?
Old 04-12-2020, 02:33 PM   #322
matt b
Nevermind, saw that you said the gaskets and not the box edges. Use 3M glue: P/N 08008 it's the weatherstrip and gasket adhesive. $10-$13 in most auto parts store.
Old 04-14-2020, 04:51 PM   #323
Shifted
Shifted's Avatar
Did that clock bulb condom work out?
Old 04-15-2020, 12:15 PM   #324
matt b
Did you get my box ? I sent Vodka to PA that same day and it got there yesterday
Old 11-19-2020, 02:17 AM   #325
Jack
junkman
Jack's Avatar
I still need to get one. Im sure it will work fine - Toyota used those
where's my VODKA?
Been keeping away from this car - still drive it all the time just haven't been able to work on it much. Getting loads of parts ready for installation
decided to get my parts powdercoated in "primer" Ends up being cheaper/easier/faster - (dash was maybe $20)
I ordered a dash pad replacement back in march but then decided to just redo the whole dash, steering column --- so much for keeping it simple
coated in grey. I just finished sanding it in 400. I decided to place the clock like the original 57 model - right of the radio and no grab handle
what adhesive is recommended to glue the dash pad in place?
before
steering column - before
after
got the front crossmember welded up - speed holes because of just how fast this thing goes. It came to me like this. (actually it was the only straight one I had at the time and after talking to my engineer friend who has been building race cars/bikes since the 60s he said it will still be strong enough - but he wants me to build a whole new xmember along with CAs) stock is 32lbs, this welded up was a tad under 30
we'll see
PC in primer - needs some body work still
todays grocery run
