Alrighty, I made a terrible terrible error tonight. I had my 142 w/ D-jet running and was going to check the idle RPMs and had my multimeter hooked up to the coil and the battery ground. Little did I know it loose and while the engine was running the negative battery cable came off. Many many expletives were uttered and I jumped to turn off the engine as it was still running fairly well. I hooked the battery back up and it wouldn't start....
It seems to be acting like it did when i had the dizzy unplugged and the injectors weren't firing. I took out the plugs and they barely a faint smell of fuel so i figure only the cold start injector is firing. I hear the fuel pump kick on for a few seconds when I move to pos 2, and also I can hear the clicks when I move the throttle.
SO what did I possibly screw up when i took the cable of, a sensor, the ECU, my mind, all of the above?? Any help is greatly appreciated.
