Mungulz
- Dec 30, 2012
- Sydney Australia
Did a few things recently. Its a 240 with an na b230f
Changed the fuel pressure reg and the car was running great, seemed to pull incredibly hard to the limiter.
Changed the injectors with 850 ones, running incredibly well there too.
Changed the alternator regulator as it wore out, car starts running ****. 13.5v running with load at idle.
Sometimes it will stop making power and just hold 4k, other times it will start weak and slowly build power. At its peak it still doesn't feel as good as it was before
Feels like a blocked cat but it isn't (don't ask why)
Fuel filter says it was changed in late 2011 so I doubt that's an issue.
I generally use **** fuel, e10, but 95-98 octane makes no difference.
Distributor cap was changed, coil lead changed, 1-4 leads old and could be suspect.
Plugs are new, 1000km old if that, but it runs rich and burns oil so they could be Fowled already.
I changed the o2 sensor, well actually my mechanic did, and I still get a 2-1-2 code. Unplugging o2 makes no difference.
Today checking for codes the box was flashing very fast and wouldn't show any codes, not even 1-1-1.
