So I have fixed numerous issues with my car since I bought it. Parasitic drain, repinned ignition switch by previous owner, non working speedometer, odometer, radio, power locks, and power staying on after ignition was off for circuits 1-3. Well the car is now running at 100 percent, all maintenance done, new suspension, AC update with parallel flow condenser, every fluid leak fixed, plus quite a few updates. Now all I'm left with are the rear power locks not working, which is weird because they did which I first fixed the power locks. Oddly enough they worked and the passenger lock didnt work. Fixed it and then the rear locks stopped a few weeks later at the same time. Any ideas? Just looking for a common issue before I pull the panels next weekend.
The other other issue is the cruise control. I have had my cluster out about 30 times and the dash has been pulled but the cruise never worked(then again the speedo didn't work when I got the car). Is there a test procedure for the speedo? Are there any wires that can be unhooked on the cluster that can cause this? I know my brake switch works and it is an automatic. Can the neutral safety switch cause an issue? It randomly has problems but I have bypassed it through the engine bay(I have a manual swap planned so I didn't want to buy a new one).
