Old 08-31-2019, 04:28 PM   #51
soclosenotnear
Don't propus wheels use adapters? Take the brakes into consideration when getting spacers/adapters? What brackets do you plan on using?
Old 08-31-2019, 04:54 PM   #52
Chumley360
Yeah I'm running 25mm adapters all around. I haven't decided on the adapters yet. I'm going to try custom brackets with Benz/Brembo 4-pot calipers that I've got laying around. They are similar in size to the R calipers, I don't have the measurements in hand ATM but I have done the comparisons. They'll work with the stock R rotors. If I don't feel like dealing with them or get short on time I'll just go with a traditional R conversion. Just wondering on the wheels, I really like them and would prefer not to change them. But I'll need tires soon so now is a good time to change to a larger wheel.
Got boost? Yes! Got manual? Yes! Got gear? Yes! Got V-8 power? No
1995 940t
Chumley360 is offline   Reply With Quote
Old 09-01-2019, 03:47 PM   #53
Chumley360
Got the coil and driver mounted up, replaced the spark plugs and made some custom plug cables. The car runs, but runs poorly. I checked the pinout from the WS-board, and if I swap those two the car turns into a cranking no-start. So I'm pretty sure I've got my wiring and firing order correct. I went ahead and swapped the coil & cables for the stock dizzy back and the engine runs 100% smoother. I did that mainly for peace of mind to make sure that the new plugs weren't damaged and that it's not extremely poor idle during the re-learn with the new chips. Tomorrow I'll ohm out the custom cables and pull the ignition box back out and check over my connections. Dollars to doughnuts I screwed up a connection on the WS board.
WS-coilbracket WS-coilbracket3 WS-coilmount WS-coilmount3 WS-igndriver
Old 09-02-2019, 12:01 PM   #54
Chumley360
Went back trough everything and nothing jumped out as wrong, so I pulled the EZK and just redid everything. That seems to have fixed the issue. I guess 30 years of using my hands as hammers hasn't given me the steadiest of hands these days, but that's life. I still need to pull the dizzy, pop in the Dee Works plug, change the oil and figure out what my exhaust has started to vibrate against at idle/low speed. That's for a different day, now it's time to enjoy whats left of this three day weekend.
WS-mountedfull
Old 09-13-2019, 02:57 PM   #55
Chumley360
Got the distributor out, Deeworks plug in, installed the AC compressor tensioning bolt & lock bolt, and started painting the valve cover.
WS-dizzyoutWS-dizzyplugvalvecover1valvecover2
Old 09-14-2019, 04:22 PM   #56
Chumley360
So the original plan with the valve cover was to paint the whole thing that green color, then just hit the raised top of the letters in the orange I've been using. But after looking at it today I think I'm going to leave the top of the letters green and paint that whole center raised panel and oil fill area orange. Guess I'd better figure it out by tomorrow.
Old 09-15-2019, 01:55 PM   #57
Chumley360
Finished up the valve cover and found that the exhaust was rubbing my chassis plate. Clearanced the plate so hopefully I won't have that issue anymore, might end up making a third motor mount but hopefully not. My tape off skills are kinda weak, so I had to do a bunch of touch-up to the lettering on the valve cover, but I think it looks good enough. I'm not going for show car, just cleaned up and a little more visually appealing. I still haven't figured out exactly what drivetrain I want in this car. It'll probably just end up staying stock and gotten rid of before I finish it. I've got to get some tires for this one and my Wrangler needs the front end rebuilt, and I've got a kid showing up anytime in the next few weeks. With all that happening I think all my "big plans" will stop.
valvecover3valvecover6valvecover5valvecover4
Old 09-17-2019, 04:10 PM   #58
Chumley360
Cover is back on, oil is changed, time to get the chassis plate back on and changer some dash bulbs.
valvecover7
Old 10-27-2019, 12:39 PM   #59
Chumley360
I've been working a little on the spoiler I've got. One of the nutserts broke off and the bolt head had to be ground off and both lens bolts snapped off. I'm going to use well-nuts and stainless steel hardware as the replacements. I also had to repair some damaged wiring, soldered the new wires this time. I'm also going to have to epoxy fill and re-drill the lens mounting holes. I used a spot weld drill bit to cut the heads off the mounting bolts and that took a little much out of the holes. It was all I had available at the time though. Now I just need the humidity to die out so I can paint the thing.
20191017-114206 20191017-114211 20191017-114215 20191017-125232 20191017-125240 20191026-141257 20191026-141300 20191026-141304 20191026-141314
I'm a two tanks into my newly chipped ECU/EZK, but I've got some issues still. At full throttle/boost I still run rich, 9.0-9.5 AFR, I'll be checking for vacuum and/or boost leaks this week, hopefully. Also I noticed that at full throttle and boost at 90MPH/5400RPM I've got a buzzing coming from what seems like the ECU location. I'm half wondering if my Swedish supplied chips suck, maybe I'll be able to get TLAO to respond to PMs this time.
Old 11-10-2019, 04:36 PM   #60
Chumley360
Id been on the fence about IPD springs or coilovers for this car for a while, then IPD ran them on sale for $170 and I said "F*#k it". I got the rear springs installed today, I'll start the fronts tomorrow maybe. Just a push the bumper test revealed them to be firmer than my cut OE springs. Hopefully I'll be happy with them.
20191110-12353720191110-14132220191110-141401
Also got a couple coats of primer on the spoiler. First coat was epoxy primer, then two coats of filler primer. I'm going to let that set up overnight take some 2k W/D sand paper to it and hopefully get a good coat of paint on it tomorrow.
20191110-12404720191110-12522720191110-145429
Old 11-10-2019, 06:10 PM   #61
Vol242vo
Keep it clean...
Vol242vo's Avatar
Looks like your making real good progress. I like how you hang your dewalt drills, creative!
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 11-11-2019, 01:53 PM   #62
Chumley360
Thanks! I'm in a smaller garage space now, so I had to get creative with some of my tools. It's nothing new, but works well for me.
On to today's activities....I pulled the RF strut assembly to put in the new springs and the bearing exploded. Normally I'm a bit better prepared, but as the bearings are relatively new and low miles I wasn't expecting this. Of course no one in town has them in stock, so 2-day air from FCP for some new SKF units.
20191111-11102620191111-111023
On a little better note the spoiler is coming along well. The first coat of paint is on and the second coat is drying. It's not too poor of a color match, I had no illusions that this would be an easy paint to get 100% matched. The second quote got it a little more green than just the first. I'll get some more pics once it dries.
20191111-10320620191111-12100720191111-121013
Old 11-13-2019, 04:25 PM   #63
Chumley360
It's too cold for me to paint, strut bearings are still "Out for delivery", and rain the rest of the week.....uhg. But at least after the second coat of paint the spoiler looks less blue.
20191113-151311 20191113-151325
Old 11-16-2019, 10:18 AM   #64
Chumley360
Hoo-ray, UPS has lost my strut bearings. That was a slightly painful interaction with them, their customer service sucks. So no fault to FCP, but I re-ordered them from Ben's shop. I guess on the upside the weather is too crappy to work on stuff.
Old 11-23-2019, 03:08 PM   #65
Chumley360
Still dealing with UPS for a refund, I'm pretty sure they are purposely difficult just to make you not go through with claims. But in the meantime my new SKF bearings showed up and the car is back on all fours with the IPD springs installed. Hopefully I can get the spoiler finished this week.
Old 11-28-2019, 11:18 AM   #66
Chumley360
Got everything back together last weekend. I think that I'm going to start focusing on a few interior things for a while now.
20191122-15434120191123-095111
So IPD springs on Propus wheels with 225/45r17. I need to get tires soon and I'm thinking about moving to 225/50r17s. It's not much different, but the roads here suck and I think the little extra sidewall can't hurt. Anyone have any pics of that tire/spring combo? Will they rub or foul in any way?
I've been thinking about what I want to do about the radio in this car, it works but I just don't like it. I thought about just adapting a cheap double din Android head unit the dash, but I really don't like the shifter to screen location. I'm not sure where I want this car to go after this drivetrain wise, but I think a manual is in it's future. So to kind of skirt the whole double din 7" screen thing I drew up a plan for a 5" screen Raspberry PI system. This is mostly a thought experiment to keep my mind busy at work for a day.
20191125-14181820191127-101826
It all fits within the inside of the current trim dimensions. I also drew one up with a 4.3" screen, but I think I like the 5" better. I even found a small bluetooth button that can fit into one of the steering wheel horn button spots.
Old 12-14-2019, 01:00 PM   #67
Chumley360
I've had this done for a while now, but didn't have the time to post the pics.
20191207-111349 20191207-111354 20191207-111406
I want to make a piece of trim to help hide a poor repair to the headliner, then I think I'm moving on to the radio.
Old 12-14-2019, 05:34 PM   #68
Vol242vo
Keep it clean...
Vol242vo's Avatar
Looking good!
Old 12-14-2019, 11:10 PM   #69
Chumley360
Looking good!
Thanks!
Old 01-01-2020, 04:36 PM   #70
Chumley360
So I'm kinda lost with this project, Originally I looked for a car with an auto to build a cruiser since I needed something to fill the gap between a 350Z and Wrangler JKU. Well fast forward and I've got a kid, sold the Z, and bought a WK2 Grand Cherokee. I don't need the cruiser, anymore and am eyeing other stuff, an inevitable fate for a car enthusiast. Now I want a manual, would like a few more revs and maybe two doors. Also I'm starting to worry about the age on the air bags making them a safety issue. I could swap to antique plates, forgo state inspections and delete them, but I see people abuse those tags so often I just can't do that. The price of sourcing the parts for a manual swap seems off and the same applies to full drive train swaps. So I'm stuck. I like the platform well enough and am not against keeping it, but i'm having trouble getting the motivation to do any mods to fix the "issues" I have with it too. Maybe the honeymoon is over, I don't know. but I'm definitely lost on the project. I'm hoping to get a shot of something to push me one way or the other soon. Sorry for the sad rant, just how stuff is.
Old 01-01-2020, 05:18 PM   #71
Vol242vo
Keep it clean...
Vol242vo's Avatar
If this is a ‘project car’ and not your DD or family cruiser with the kids and doesn’t ‘spark joy’ or you don’t find yourself getting out of the car and looking back at it as you walk away from it....I’d say sell it and get something that does. Once you do, the car itself will motivate you enough to want to work on it, and enjoy the ‘headaches’ your project WILL throw at you.
There’s my
Old 01-02-2020, 06:58 AM   #72
Chumley360
There’s my
That's about my thought completely. If I had the cash to pick up something else I'd just drive this one into the back yard and wait for motivation, or lightening, to strike.
Old 01-18-2020, 04:22 PM   #73
Chumley360
As I'm pondering what I'm gonna do with this one, a question hit me about 780s. Did the 780 come without SRS air bags over the production run?
